Question about Noritz 6.9 Gallon Residential Direct Vent Tankless Water Heater - N
Help! We bought out home 3 years ago and have a Nortiz tankless water heater. Recently we heard a dripping sound coming from the water heater and found that the bottom of the unit is leaking. We had a plumber come out and "fix" it. However $300 later the unit is still leaking...... at least a handful of water. We need it fixed but we don't have the money to keep sending people out here to fix the water heate! Please help!
    Problem Solver:
  • 6 Answers
You will need to explain more of where the leak is on the bottom. You have two plastic valves on the bottom and if the clips are not on exactly it will leak and if the person who replaced valves did not use vasoline when they put it back together the could have cut the gasket ring on the inside putting in back together and again it will leak. You have to determine where the leak is coming from to begin with using a flash light to get the exact location. .
Posted on Oct 06, 2010
Rheem water heater rtg95dvn keeps blowing 3 amp fuses
Not for sure what your root cause was and I know it's a little late but I just suffered this same exact scenario on the same water heater. Storms came through, power went out, power came back on and the water heater keeps blowing the 3 amp fuses now. I removed all the cables and plugged them back in one at a time. When I plugged in the Fan Motor connector the fuses blew. Installed new fuses with the connector out, the Fan Motor was putting out 150 VDC through the connector port (on main control). I pulled the control from the unit and Q1 is visible blown and disintegrated on the control board. Obvious control design issue. I've ordered a new control and will put a surge protector on the heater now when the new control comes in. Very disappointed that this was not caught in controls testing within the manufacturers facility. New control is not very cheap. Half the cost of a new Heater. Hopefully the Fan Motor survived the high voltage with the fuses blowing. I'm putting this here for anyone else that suffers the same issue on this water heater or the Richmond equivalents as they use the same control.
Jul 31, 2012 | Rheem Tankless Hot Water Heater...
No hot water? How can we reset?
This happens with Nortiz heaters. They just **** out. Likely the installation is very bad, but the unit can not tolerate that and it just dies. I recommend getting a Bosch 2700 or 715. If you want great efficacy, get the C-800. But follow the instructions! If it is installed correctly and you have the CO2 levels adjusted when it is installed, you will be very happy.
Apr 11, 2010 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Water becomes ice cold in the middle of a shower
Sounds like you have a problem with water flow. Since your ground water is warmer in the summer, you mix less hot and more cold in order to get the same warm temperature. If your hot water flow gets low enough, your tankless will start to "short cycle" in order to prevent scalding. Use one of these three methods to increase your water flow at the shower:
1) Clean your shower head and descale
2) Widen the hole in the showerhead's flow restrictor
3) Remove your flow restrictor entirely
Jan 24, 2010 | Noritz NORTIZ Outdoor Propane Tankless...
Leaking Noritz water heater.... I have a Noritz N-069m water heater. When i purchased the unit 3 years ago, i was told that if i installed a water softner unit it would void the warranty. A year and a half...
Check your water pressure and the diagnostic codes on the controller to see if there is computer failure or another problem with the unit. send me an e mail i might be able to help im a nortiz certified service tech scott@bridgeplumbing.net
Jul 27, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Heater not working
Probably a 12 or 21 code. Neither of which a Consumer can do ANYTHING about. Call Noritz 1-888-382-6568 and they will have a Regional Service/Repair Field Engineer call you and diagnose problem.
This is a sophisticated appliance unserviceable to Consumer but you may diagnose it with the help of the FE for Service Contractor to repair.
N069M-DV was discontinued 3 years ago replaced by N0751M-DV. Have you checked the inlet filter since you bought it? Is it on good soft water? It's a strong pretty dependable unit IF INSTALLED PROPERLY and MAINTAINED.
Mar 02, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Trouble light bilnks 3 times pause and then repeats
You have a 16 error code, abnormal output temperature. I recommend performing a descale to remove hard water deposits in the heat exchanger. This should resolve your issue.
Jan 28, 2009 | Noritz 6.3 Gallon Residential Tankless...
How to fix my tankless hot water?
what is it doing, I would first check the inlet water screen and make sure that it's clean. shut off the water going to the unit and the screen is right after the shut off, unscrew it and clean it. replace and turn the water back on. you can ask for me again if this does not help
Jan 11, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Noritz 6.9 Gallon Residential Direct Vent Tankless Water Heater - N Logo
205 people viewed this question
Top Noritz Water Heaters Experts
jasbo
jasbo
Mack Baxter
Are you a Noritz Water Heater Expert? Answer questions, earn points and help others
