Question about Briggs & Stratton Garden
Erattic running(hunts) briggs and stratton 10a902 engine what should i look for
  • Briggs & Str... Master
  • 7,482 Answers
Check your fuel filterif you have one.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
We have a 27hp v twin briggs & strattion which back fires and surges when engine is hot
have you tried checking the lean,rich needle on the carb sounds like it's to lean. good luck
Aug 11, 2014 | Briggs AND Stratton Intek Briggs &...
What's the head bolt tension settings
good question. if not in the service manual then you need to know the cross sectional area of the stud and the surface area of the matting surface of the threads then you can look it up in a engineering book.better yet if you know the stud size and grade of bolt ie i assume number 8 or better then you could get a make up torque specification from a hardware store that specialises in fasteners .your gonna be looking in the neighbour hood of 80 to 120 ft pounds. remeber to always cross torque when re installing
Aug 11, 2014 | BRIGGS_AND_STRATTON...
17hp briggs and stratton blowing oil out of dipstick
looks the rings are stuck.when you have head off check piston. john.
Mar 10, 2014 | Briggs & Stratton Garden
Briggs & stratton - after warm up engine idles rough or hunts -runs fine when cold
make sure the intake is not cracked or leaking spray carb cleaner arround gasket and carb sounds like you have a hot condition vacume leak
Jul 14, 2012 | Garden
12.5 HP Briggs starts ok but constantly hunts or oscillates.
check air filter it sounds like its blocked if that dont fix it strip the carb and clean out the running jets with card cleaner dont go poking wire into the jets or you could distroy them
Mar 27, 2010 | Briggs & Stratton Briggs Stratton Intek V...
How do you remove the primer bulb on a Briggs and Stratton model 10a902 engine
On each side of the primer 'casing', there are apatures in the outer. Squeeze these inwards, and the retaining ring and primer rubber can be pulled out.
Sep 27, 2009 | Garden
How do you remove the primer bulb on a model 10a902 Briggs and Stratton mower engine?
Look at the outside of the plastic housing where the primer bulb is inserted, you will see an open area where there are 2 tabs, one on each side, using a small screwdriver, push these tabs inward to release them and slide the whole thing out of the hole including the primer bulb. The new primer bulb normally comes with a new mounting ring if you purchase it from a lawnmower dealer
Sep 27, 2009 | Briggs & Stratton Garden
Briggs and Stratton mower engine carburetta
you can download a manual for it here
http://www.briggsandstratton.com/maint_repair/manual_and_more/doclist.aspx?category=Engines&manual_type=Operator%20Manuals&menu=nav3&subMenu=3
Aug 01, 2009 | Garden
Garden Logo
255 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
