Question about Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Switch off automatically after 20 minutes from initial switch on
    Sergeant:
    Champion:
  • 293 Answers
First check the timer setting from the menu.If no timer setting.The poower supply of your TV have problem.
Posted on Oct 05, 2010
Stoves 720EF oven switches off after 20 minutes
CHECK THAT THE OVEN TIMER IS OFF AND NOT OPERATING EVERYTIME YOU TURN THE OVEN ON IT AUTOMATICALLY SWITHES THE OVEN OFF AFTER 20 MINUTES
Oct 16, 2014 | Ovens
How many qts of oil do i need
Depends on your engine.
1980 JEEP CJ-7 2.5L 4-cyl Engine Code [B]
CAPACITIES
Engine, GM without filter..........2.4 quarts[1]
Wix Filter ........ 51040
Cooling System, Initial Fill..........8.0 quarts
Automatic Transmission, A904, 30RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, A999, 32RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, Total Fill
3 speed A999, 32RH..........8.4 quarts
3 speed A904, 30RH..........7.0 quarts
Manual Transmission, 4-SPD, SR-4..........3.0 pints
Manual Transmission, 4-SPD, T176..........3.6 pints
Differential, Front..........2.5 pints[3]
Differential, Rear..........4.9 pints
Transfer Case,..........4.0 pints
1. Add extra oil when replacing filter. After refill check oil level.
2. With engine automatic transmission operating temperature, shift through all gears.
Check fluid level in NEUTRAL and add fluid as needed.
3. 1984-1992 Models with command-Track, add 5 oz of 75W-90 GL-5 to shift motor housing opening.
TORQUES
Oil Drain Plug.....25 ft-lbs
Manual Transmission T176
Fill Plug.....15 ft-lbs
Drain Plug.....15 ft-lbs
Manual Transmission SR4
Fill Plug.....20 ft-lbs
1980 JEEP CJ-7 4.2L 6-cyl Engine Code [C]
CAPACITIES
Engine, without filter..........5.0 quarts[1]
Wix Filter..... 51522
Cooling System, Initial Fill..........11.0 quarts
TORQUES
Oil Drain Plug.....30 ft-lbs
1980 JEEP CJ-7 5.0L 8-cyl Engine Code [H]
CAPACITIES
Engine, without filter..........4.0 quarts[1]
Wix Filter..... 51258
Cooling System, Initial Fill..........13.0 quarts
TORQUES
Oilman
Feb 02, 2013 | 1984 Jeep CJ7
I have a Paragon 8145-20 D-Frost-O Matic installed in on my walk-in freezer. The ice is accumulated on the fins of the freezer. Now it run for 11 minutes then stop for 3.5 minutes. I think the stop time...
1) Copy following links:
http://waterheatertimer.org/images/8145-work-image.jpg
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
2) Typically the 8145-20 defrost cycle is time-initiated and starts when tripper pin located on outer part of dial passes the time-of-day point.
Defrost cycle terminates or ends when pressure or temperature switch activates. This is also called the cycle limit switch.
http://waterheatertimer.org/images/8145-20-wiring-600.jpg
3) So your situation sounds like the pressure or temperature switch is not working correctly.
4) The 8145 timer also has 'time termination' setting. This red tripper is located on inner part of dial.
Usually the 'time termination' is used as back-up system if the pressure or temperature switch fails so that defrost cycle will not continue melting everything in freezer.
5) To solve problem until pressure-temperature switch is replaced, you can disconnect wire on terminal X, and then set 'time termination' for correct length of time by experimenting.
Dec 27, 2012 | Paragon 8145-20 Defrost Timer
After paper jam, printer won't initialize
try to switch it off unplug leave for 15 min and switch back on.
Jun 30, 2012 | HP P2055DN LaserJet Monochrome Printer
Hp laserjet 3055 has error message on copying "50 fuser error, turn off then on". Restarting brings on the same message when copying.
The all-in-one has experienced an internal hardware error.
1. Turn off the power by using the power switch, and then wait at least 30 seconds.
2. If a surge protector is being used, remove it. Plug the all-in-one directly into the wall socket.
3. Check the cabling connections to the heating element.
4. Turn on the power and wait for the all-inone to initialize.
5. If, the error persists, replace the fuser.
NOTE The device power mustremain off for at least 20 minutes forthe fuser to cool down and correctly reset.
Turn off the power switch, wait at least 20 minutes, and then use the power switch to turn on the all-in-one and wait for it to initialize.
Aug 23, 2011 | HP LaserJet 3055 All-In-One Printer
My tv keeps switching off after about 20 minutes after initial starting. if tv is switched on immediately, then it works for less than 5 minutes before switching off. model: power vision.
I do not knowtis make , but this type of fault is sometimes due to dry joints in the flyback circuit or power supply try resoldering all pins on flyback transformer and chopper transformer, also cheek that the ht voltage is as the makers state. Waring unplug from mains before removing back and discharge ht resiour capacitor before starting repair
Mar 04, 2010 | Televison & Video
Will not connect to the internet
Your router may need to have the firmware updated, or it needs to be reset or unplugged for 10 seconds to reset it.
You can set up a home network and make sure all settings are set to automatic
Aug 25, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
My screen only displays after 4 /5 hrs
Try a different screensaver.
Also look in the display properties by simply right clicking the desktop and clicking properties.
Then locate power management.
the initial seems to be a bad screensaver judging by the 20 minutes, but the 4-5 hours seems to be a sleep mode that bypasses the screensaver issue.
Jul 23, 2009 | Computers & Internet
Why does my GPS system have a difficult time locating satellites?It says ''acquiring satellites'' for about 5 minutes. Then it says it can't locate satellites. Should it continue trying? Why does it do...
this is what my navigon says about gettting the gps to connect.
Initializing the GPS receiver
In the upper right-hand corner of the display, the GPS symbol appears. As soon as
data from at least 3 satellites is received, the symbol changes to (GPS Ready). Note: If possible, position the device with a clear line of sight to the sky to successfully
receive messages from the GPS satellites.
Note: GPS initialization requires data from at least three satellites. If GPS data is not
available, the receiver will not initialize.
Note: It can take up to 20 minutes to initialize the integrated GPS receiver for the first
time.
Note: Each time you turn on the device, GPS receiver initialization begins. When GPS
data is available, reception starts within one minute.
If the navigation device has been switched to standby for more than a week, the next initialization
can take up to 10 minutes.
Jun 19, 2009 | Garmin GPS
Sputters on initial startup and again also 15-20 minutes after shutoff and restart
fuel pump, clogged fuel injectors, bad gas.... could also be a timing problem among other things depending on what you mean by sputtering.... my advice find a shop that will diagnose the car for free( like AAMCO). hope this helps :)
Nov 09, 2008 | 2001 Volkswagen Beetle
Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
48 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
