Question about Whirlpool 19.6 cu. ft. Upright Freezer EV200FXM
The outside coverings feels hot and water leaks from the unit, what causes this problem?
  • 316 Answers
If by coverings you mean the side of the cabinet, that is usually an indication that the compressor is running hotter than normal, could be a bad compressor, compressor fan, a leak of refrigerant, a dirty condenser coil or some other problem possibly. check to see if the fan is running, and if the condenser is dust clogged.
Posted on Oct 05, 2010
Our upright freezer is leaking water underneath and the temp is set on the coldest and the freezer is maining only 20 degrees. It is 14 years old and the brand is GE. Thanks
Many maybes here. Leaking water usually indicates a problem with defrost. You need to remove either the rear wall or the bottom cover inside the freezer. Most will have screws, but some will be a friction-fit. Bottom line is to look for ice, either on the rear wall or the bottom.... wherever the ice is showing. This is where you will expose the evaporator (cold radiator) and drain fitting.
Odds are that your drain is plugged and causing the evaporator to ice-over. Expose this area and look for anything (I've seen peas, price labels, corn and multiple items causing the issue) that is plugging the drain fitting. You may need to turn the unit off for a day to melt the ice in this area. If you do, remove ALL product and place towels at the bottom of the unit to absorb the water that will accumulate. Not doing the towels could damage your floor.
When the drain fitting is exposed, if there is something obstructing the opening, remove it and ensure that the line if not plugged by pouring a small amount of hot water into it. That water should end up in the catch pan below the unit.
If there is nothing plugging it, make sure that the fan is operational. If not, replace it. If fan is good, my advice is to replace the defrost heater, defrost safety control and defrost timer... all of them.
Good luck. If I had a unit as old as yours, I'd not call a tech. I'd replace the unit.
Jun 17, 2011 | Freezers
I want to make a kegerator out of this. But does anyone know where the coils are in the unit.
Plug the freezer in a let it run.
After a short while you will see frost lines inside the freezer.
There will be corresponding hot areas outside the freezer if you feel along the outside of the freezer.
The frost lines and hot areas are your coil routing.
You would tap your holes between coils.
Sep 09, 2010 | Danby 5.5 cu. ft. / 156 liter Chest...
I hooked a used unit up turned it on and got 3 beep any answers
this indicates that the backup freeze timer terminated the freeze cycle. Stayed in freeze cycle 60 minutes. Causes can be: stuck float switch, water valve leaking incoming water, and the more extreme can be hot gas valve leaking, txv not feed properly, low refrigerant charge, or bad compressor. Usually one of the first 2 items are the root cause.
Aug 21, 2010 | Hoshizaki Freezer Commercial Ice Machines...
My Kenmore 9 upright freezer feels warm on the outside, what could be the cause. I have defrosted and cleaned it already and seems to work fine. however i am concerned with the outside temperature. Please...
This is normal. The condenser coils on freezers are typically located in the walls.
The refrigerator in your kitchen has condenser coils that are hot either under the frig or on the back. Freezers do not need as much heat transfer on the coils with the air so they put them in the walls, it is called a warm wall condenser. It may even feel hot to the touch if you happen to feel it near the end of a cooling cycle. It will be the warmest close to the compressor and cool off at it makes it around the cabinet down to the other side.
Apr 25, 2010 | Kenmore Freezers
Panel is hot and freezer does not work!
Check the condenser fan underneath the unit accessable form the back behind the cardboard cover. It should be running when the compressor runs. OR Check the evaporator behind the rear cover inside the freezer. Check for ice build up. . Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control
Sep 09, 2009 | Freezers
Beeping 3 times every 3 seconds
The 3 beeps indicates that the unit was in the freeze cycle for 60 minutes. Causes: 1.) Water valve leaking, allowing water to continually enter the system. 2.) Float switch stuck, sending false signal to board. This indicates ice not being produced. 3,.) Low freon level causing long freeze cycle. 4.) Hot gas valve leaking thru causing warmer than normal evap plates=low production. 5.) Expansion Valve not feeding freon properly to evap plates.
Items 1 and 2 are the most common. Number 3 possible due to freon leak in the system. Number 4 and 5 are usually a very rare occurance.
Hope this helps ya.
Sep 05, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Refrigerator just stopped cooling all of a sudden. neither side is cooling and the freezer side is barely freezing all of food is going to waste help please
is the compressor running ? if yes feel the cooper tubes around , the tiniest one is suppost to be hot if is not hot u have a leak call a tech . if it is hot open the freezer and take the back cover inside of the freezer if the coil is totaly covered with ice you have a defrost problem , check the timer , bimetal and heater
Jun 19, 2009 | Freezers
Water leaking onto ice and outside panel on Hoshizaki KM-500MAE
Remove the cover where the persons finger is and check to make sure that it is not covered with ice. Sounds like your machine iced oup and you will need to clean the coils and possibly replace the thermostat
Feb 12, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Water leaking from underneath the unit
hi thanks for the question is there water inside the fridge or freezer if not then the leak is coming from the drain tray at the back make sure the drain hose is located in the tray not outside the drain tray thanks the appliance doc
Sep 27, 2008 | Freezers
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Feb 20, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
Whirlpool 19.6 cu. ft. Upright Freezer EV200FXM Logo
87 people viewed this question
Top Whirlpool Freezers Experts
christian nielsen
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
