Question about Garden
Instructions/manual for a calibre 3.5 battery charger
2 Suggested Answers
supertech6
  • 513 Answers
SOURCE: Need an instruction manual for a Century 10 amp battery charger
Are you having this problem on a particular battery? Try using it on your car's battery with the headlights on. The headlights should brighten and the unit show 5 -10 amps charging.
A car battery can develop a problem where the battery post gets disconnected from the inside. This is common on batteries in storage or left on charge a long time or used in a car with a defective alternator. The battery is charged but it won't start a car. headlights connected look normal until you turn the key, then the headlights will just go out. This descibes a bad battery.
Posted on Apr 19, 2010
Testimonial: "Thanks for the info. This is a battery for a boat which hasn't been used for two seasons. It has a indicator the should show green when charged. "
New battery and only charge to 45%?
My new battery cam with an eight page manual containing instructions got use in a translated (poorly) version of the Chinese original. Of course I did not need a manual to install a new battery and ran into the same problem as you. Refer to the discarded manual and find one and a half pages on how to initialize a new battery.
OOPS JPG came out too small to read so here is a rough OCR
"User Manual on Laptop Battery
Respected users:
Thank you very much for trusting and using our laptop battery. Before using the battery, read this manual carefully. This instruction manual elaborates how to use and maintain the battery correctly. Batteries are consumables, and have a limited service life. However, we can prolong the life of the laptop battery considerably through correct operation, proper charging/discharging and correct storage.
Calibrate your laptop battery to optimize its performance
Inside the laptop battery is microprocessor software, which calculates the battery volume during the charging/discharging. Batteries must be calibrated from time to time to ensure correctness of the time and the percentage displayed on the screen. You must implement a complete cycle of charging and discharging the battery at the beginning of using the computer, and repeat this cycle every two or three months. The charging and discharging procedure is as follows:
1.Set the Power Supply option first: Right click on the screen and select Property -> Screen Saver -> Power Supply -> Power Use Scheme -> Portable. In all the subsequent operations such as When Computer and Use Battery, select Never. Under the Alert option, deselect Alert for deficient battery and Alert for serious battery shortage.
2.Disconnect the power adapter and use the battery until the computer is powered off due to exhaustion of the battery.
3.Connect the power adapter until the battery is charged to 100%. Before initial use of the computer (or resuming use of the computer after long-term storage), the battery must be charged to full.and discharged for 3-4 times to optimize the performance. The charging process takes more than five hours.
Note: When your battery is calibrated and reaches the best performance, set the Power Supply Options on your computer to the default value to ensure that the computer can send correct alerts to you, for example, low battery alert, and alert before the computer enters the hibernation status.
You must discharge the battery to let the computer power off, and then charge the battery to 100% to calibrate it. Then you can connect or disconnect the power supply anytime regardless of the status of the battery volume. Moreover, you can perform a deep charging and discharging cycle under control of the protection circuit in a time"
Sep 12, 2013 | HP Computers & Internet
Charger not shutting off
Some chargers contain a computer chip that automatically shuts off the unit when a battery is fully charged. Other models continue to charge as long as the unit is on. Review the instructions for your particular charger to ascertain whether you'll have to manually turn off your 3-in-1 charger.
Jun 19, 2012 | GPS
How to set the time for citizen eco drive skyhawk.
Hi, This watch is Calibre C651, same as Model #JR3090-58M (Promaster Air Collection - Blue Angels Skyhawk). C651 is not available on Citizen website, but you can use Calibre C650 instructions. Download PDF manual and follow instructions on page 3. They are pretty detailed, so take your time, and you should be successful. If you don't have the manual, Try this link:
http://www.citizenwatches.com.au/instruction-manuals
Take the four-digit Calibre number (C651 or C650 in this case) from the back of the watch, enter it, and download a PDF of your watch setting-instructions/manual.
I hope this helps you. Thanks, Bill
Sep 06, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
HP Pavilion DV5000 battery charging problem
Sounds like you need to calibrate the battery, it is supposed to be done every 3 months. If it is not done, your battery will display the same symptoms are you describe. Yes, this holds true for adding a new battery also.
Here is HP's instructions on how to do it. You want to scroll down to the section called "Calibrate the notebook PC battery".
http://h20239.www2.hp.com/techcenter/battery/Battery_max.htm
Feb 27, 2010 | HP Pavilion dv5000z Notebook
System diagnostics says needs battery calibration
battery calibration is nothing but it the process to discharge the battery fully.
discharge the battery fully till the system gets off automatically, then only recharge the battery for 100%. make this process for 3times continously
Dec 24, 2009 | HP Pavilion dv1000 Notebook
No instruction manual
For Compass Adjustment search on Google or FixYa
For Temperature calibration:
1. Pull the crown to most extended position (2 notches)
2. Temp hand moves to a default position
3. Move hand in + or - direction by pressing temp or tide buttons (above and below crown button)
4. When done, push crown to 0 position
(I used melting ice water to calibrate and fix to 0 deg C)
For Tide calibration:
1. Pull crown to middle position (1 notch)
2. Move hand in + or - direction by pressing temp or tide buttons (above and below crown button)
3. When done, push crown to 0 position
Hope this helps
Sep 17, 2009 | Timex E Tide Temperature Compass Watch...
Zivan NG3 battery charger diagrams
your NG3 should have been preprogrammed for the type of batteries you are charging. The NG3 has the 3 wires from the power cord. Here is what I have done:
Brown from charger goes to black wire
Blue goes to white wire
yellow green goes to green ground.
Mar 11, 2009 | Ryobi Multi-Volt Battery Charger
Instruction manual
Your specific manual is here.
You can find Sanyo UK owner's manuals here
Sep 13, 2008 | Microwave Ovens
Can only Epson brand Ni-MH batteries be used?
I use kodak batteries and they are fine. the key is find good battewries with a high amp rating. I think the epsons are 1550.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Garden Logo
437 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
