Sanyo DWM-390 DVD Player Logo
Posted on Oct 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I set the region code to 0 in my Sanyo DWM-390?
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Feb 27, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2470312
Points
19564
I have a dvd set. The first disc in the set plays fine. When i try to play the second disc, it gets to the FBI warning and stops. Any suggestions?
FBI warning on disks are normal and is part of content on dvd, this has nothing to do with the fact that it stops playing (just coincidence) there might be a defect on the disc or scratches
My grandfather cant remember the code for parental controls. it is stuck on pg. can it be reset with out the code
Forgotten the parental control password? there is a way around this. According to the user manual (page 34) for this particular model:
Enter "788444" even if 4 digits "----" appears, then press [ENT]
to clear the current password.
Enter a new password and set the parental lock level again if required.
Note: DVD video discs may or may not respond to the parental lock
settings. Make sure this function works with your DVD video
discs.
You need the original unit's remote to do this. It cannot be done without it.
There is a .pdf of the user manual online.
http://tv.manualsonline.com/manuals/mfg/sanyo/dwm390.html
(It is free to download for personal reference in case you have lost your original copy.)
I hope this helps a tad.
Change region code to my Sanyo DWM 400, in order to read DVD of regions 1 and 4. I are in Mexico City.
Sanyo DWM-400
  1. Open tray
  2. Press 5, 7, 9, 2
  3. Select 0 for multi-region
  4. Close tray
if this will not work then. its not possible to change the region
2answers
Need remote
The best bet is to contact Sanyo and to obtain a replacement remote, you can do that either by contacting Sanyo direct or finding their closest authorised repair agent. I don't reccomend getting a universal one as the majority of the time, they do not work. Be prepared to find the remote may be very expensive in some cases. I hope this helps.
Undefined region comes up when I insert any disc into my dvd play
This may be because it is region locked. The following will make the player region free and possibly solve your problem. By making your player region free you MAY be voiding any warranty the player has on it.
  1. Switch on, wait for "no disc"
  2. Enter 11233543254346
  3. Switch off
7helpful
I have a sanyo dvd player dwm-395. how do i unlock it w/o remot
For the DVM-390 model, I believe this solution should work on the DVM-395 model - Push and hold down the Open/Close button until "UN-LOC" appears on the FL display (or "Disc Tray Unlocked" appears on the TV screen).
6helpful
Can't Reprogram the TV Guardian code
Forgotten Parental Control password can be bypassed/cleared by entering "788444" even if 4 digits "----" appears, then press ENT to clear the current password. You can then enter a new parental control password.
Subtitles on Sanyo DVD Player Model DMW-380
For the DVM-390 model, the above problem can be due to the TV Guardian (TVG) mode. I would go to the intial setting options and under Language turn the TVG mode to "Off" and see if that allows the subtitle languages to appear on screen.
1helpful
Dvd regional codes
I have a Panasonic -RA60 that has suddenly stopped working. Every time I insert a dvd from Block Buster It reads (can not be played in your region) Why? Please help!
2helpful
Codes to program a universal remote to this device
You can try the following four digit codes:
0670, 0695, 0873, or 1919.
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
