Question about Sport & Outdoor - Others
OPERATORS MANUAL FOR NAVICO ES120 DEPTH SOUNDER
SOURCE: I need a replacement transducer for a Navico DS 200 Depth Sounder
my ds200 has stopped
if i find it only way to replace you can have the removed transducer
cheers colin jewellersbench@talktalk.net
Posted on Dec 09, 2008
SOURCE: Depth sounder
the transducer has to be in the water or attached to the inside of the hull if fiberglass with no air between the hull and the transducer. It doesn't transmit thru air.
Posted on Mar 13, 2009
the kowalski
  • 86 Answers
SOURCE: Owners manual
You can find the owners manual here:http://www.raymarine.co.uk/products/instruments/st60-plus-series/e22075-p/?esctl369867_asset=6656
Posted on Jun 03, 2009
TechnoMarine
  • 132 Answers
SOURCE: furuno 4100 depth sounder shows depth twice what it really is
check your gain setting try auto gain and try manually gaining back to see if it resolves, if yes, send unit in to furuno, if no, ducer is probably at fault.
Posted on Jan 16, 2010
TechnoMarine
  • 132 Answers
SOURCE: depth sounder problem
If the transducer is mounted off of level, an error is introduced due to angle. It is a fixed percent offset, say 10%. so 10 feet reads 11 and 100 reads 110. There is an offset function to read depth below ducer, depth below keel, and depth below waterline, but these are fixed amounts in feet, not a percentage. Look at the transducer when it is operating, boat angle considered.
Posted on Jan 19, 2010
My Garmin 498C will not show the contore of the bottom or give me a depth reading. The GPS works and will show me charts but, not the sounder option though.
You need to check to see if the depth sounder transducer is connected or functioning. It might be turned off, the connectors may be bad or the transducer is bad. I don't have the 498 manual in front of me but I think there is a test function under the setup menu. I'd check my connections (the usual suspect) then run that.
Garmin tech support is pretty good/quick. So don;t be afraid to give them a call.
Aug 29, 2010 | Garmin GPSMAP 498C Sounder GPS Receiver
I have a gps Map 498-depth sounder not working? Have new transducer from Garmin-it flashes "00"-it is not connected to boat yet (transducer)-need it be or can I put in a bucket of water (need it be in...
If the transducer is out of the water, you will not get a reading and see the flashing depth. You should hear and feel the clicking in the transducer when out of the water and working properly. Are you getting a temp reading when out of the water?
May 16, 2010 | Boating
Furuno 4100 depth sounder shows depth twice what it really is
Aug 01, 2009 | Furuno Ls4100 5" Mono Lcd Fishfinder Temp...
Hummingbird gps ns25
Hi!
here's a user manual/installation manual for your sounder:
NS25
If the depth sounder portion works, I would suspect the settings are off (check first) or the gps circuit needs repair.
Best of luck!
Mike
Sep 02, 2008 | Hummingbird Humminbird 1155C GPS Receiver
Faria Depth finder
I've found this manuals in Faria's site:
Depth sounder:
http://faria-instruments.com/site_manuals/IS0091F.pdf
Bombardier Depth Sounder:
http://faria-instruments.com/site_manuals/IS0138_C_digital_depth_sounder_owners_manual.pdf
Depth Sounder, Flushmount:
http://faria-instruments.com/site_manuals/IS0141c.pdf
Depth Sounder, Flush Mounted, Remotely Switched:
http://faria-instruments.com/site_manuals/IS0229_A_Digital_depth_sounder.pdf
there are also other useful manuals in the bottom of the page:
http://www.faria-instruments.com/downloads.php
Jul 14, 2008 | Faria Boating
Si-tex cvs 106 mk11echosounder
To re-program the Si-tex CSV-106 depth sounder to feet/meters/fathoms: Push and hold down the MENU key while turning the unit on (POWER key) to enter a special menu. Release both keys after you hear two beeps, almost immediately. Use the LOWER ALARM key to select the desired unit for depth, then turn off the depth sounder. That's it, just turn on again to see the change.
There is also another menu (for testing sounder) available by pressing the MODE and turning on as above.
Apr 26, 2008 | Computers & Internet
Navman 4150 fishfinder
Depth: Could be for a number of reasons, too deep for the sounder - check the manual for it's max depth. Dirty water, sounder unable to penetrate through to the bottom. Weed or other debris covering the transducer. Transducer on a swing mount & being pushed out of alignment then dropping back in once stopped.
Speed: Is the speed readout controlled by a GPS or paddlewheel? If it's GPS, check the power connection of the sounder, may be loose which would also cause the depth to 'drop out'. If it's paddlewheel, you're down to bad connections or faulty unit.
Oct 16, 2007 | Navman Fish 4150sx GPS Receiver
Sport & Outdoor - Others Logo
495 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
