Question about Amana NED7200TW Electric Dryer
My dryer is only 1 year old and quit heating today. It blows cool air no matter what setting it is on. Please help with any ideas!
    Problem Solver:
  • 31 Answers
If yor dryer is electric check the heating elements with a voltmeter...
Posted on Oct 05, 2010
Hello! Yesterday we cleaned out our home dryer vents. Today the heat wil not come on in our kenmore elite dryer. It tumbles and blows cool air, just no heat. Suggestions? Thank you!
If you have a gas dryer, your problem is probably caused by the ingition panel.Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty.If this helps solve your problem, please come back to Fixya and rate my advice
Jul 25, 2011 | Kenmore Elite HE4 Electric Dryer
No heat, just cool air no matter what the setting it is on.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 03, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I just replaced the motor in my Kenmore Series 90 dryer, When I'm running the dryer with no heat it runs as quite as could be expected for a ten year old dryer, When I run with heat the dryer starts making...
It could be possibly your rear roller bearings expanding with heat causing them to not spin as freely? Im not really too sure but its an idea you dont have many moving parts on the unit. Just your idler pulley, blower wheel, and rollers. Hope this helps.
MJ
Feb 14, 2010 | Kenmore 659 Electric Dryer
DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Feb 13, 2010 | DeLonghi Pinguino PACL90 Portable Air...
I have a 30 year od (Sears) Kenmore Dryer and just
Haven't found a solution nor any help. The only thing I saw was an ad to "upgrade" for a fee to get assistance
Dec 29, 2009 | Kenmore Dryers
No heat in dryer
Hello there Here are some ideas that may help you
- Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
On the back of the dryer near the fan blower housing is a thermal fuse, if this opens up ( no continuity ) the gas burner often quits but the motor will still run. If the thermal fuse is open/bad, always clean, change, adjust the venting system and vent hood first and clean out the dryers air ducts. Sometimes it is a good idea to replace the operating thermostat at the same time.
Thermal fuse parts help link...on blower housing cover, can not be re-set, must be replaced if is open (no continuity between pins).
hope this is very helpful for you
best regards Michael
Dec 23, 2009 | Maytag MDG6400 Atlantis Gas Dryer
Dryer is not heating, only blowing cool air
Its best to take it to an appliance repair man. This is usually an electrical problem related the the board or the relays behind the control panel. Beware though, sometimes its cheaper to buy a new one than fix the old. Hope this helps.
Sep 13, 2009 | Uniden Cordless Phone
5 Year old Kenmore Elite Electric Dryer will not heat.
limit switch either the one on the heating element or the one in the air duct they are easy to check if u know how to use a meter they should read continuity when they are cold and open up at a certain temp
Aug 24, 2009 | Kenmore Dryers
Bryant Legacy Line air conditioning not blowing cool air..
Your outdoor condenser is in heat mode. Check the wires on the thermostat. Sounds like a small wiring problem and nothing else. Good luck. Please keep me posted as to you progress.
Apr 27, 2009 | Bryant 462AJC021BA Air Conditioner
Amana NED7200TW Electric Dryer Logo
120 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
