Question about Kenmore Kitchen Ranges
I have a Lady Kenmore Stove thats about 15 years old and in good condition. TOnight the stove started beeping and a signal came up on the stove that said F-1 can you tellme what that is and can I fix it or how do I get it to stop beeping. I did strat pushing button and it stoped , then started again again i9n about 5 minutes. It started againbut I do not know aht buttons I pushed to make it stop. Can you help??? Donald Hawkins
  • 5,911 Answers
All of the kitchen range fault codes I could find indicate that this is an Electronic Oven Control (EOC) board failure. You can attempt to unplug the range for about 1 minute, then plug back in. If the fault code reappears, you will need to replace the EOC and/or keypad. If you post back with your model number, I may be able to track down the correct part number for you. This is a simple repair that you can accomplish yourself, if I can identify the part and give you instructions. Post back and let me know. I hope this helps you.
Posted on May 28, 2008
Need knobs for Lady Kenmore free standing stove. do not have model # stove was installed when home was built in 1990
parts need to have the model number sometimes the part with have the number etched on to it
Feb 01, 2015 | Kenmore Ovens
Skytech 3001 won't work
Dec 28, 2013 | Home Security
Electric stove fuse keeps blowing
more than likely the terminal block where the element actually plugs in has been shorted or damaged and every time you start that particular element it trips the breaker. This is a real easy fix, just take your time and you'll be just fine
Jun 19, 2012 | Kenmore Kitchen Ranges
I have a Kenmore Gas self cleaning stove. I have
Try power cycling the range by turning it off at the breaker. Wait 10 seconds and then reset the breaker. Reset the clock. Sounds like the computer in the range needs to be rebooted. Hope this works.
Jan 11, 2010 | Kenmore Kitchen Ranges
What does F-1 mean on the electronic display of stove?
F1 is a failed thermistor control in the control board. Board must be replaced to fix. Part is in vicinity of $120.00
May 20, 2009 | Hotpoint RGB745 Gas Kitchen Range
Kenmore drop in range code F7
Oven control beeps and Electronic control as detected fault condition.
Press CLEAR to clear the display and stop displaysF1,F3, F7 ,or F9 beeping.
Program oven again.If fault recurs,record fault number.
Press CLEAR and contact your Sears authorized qualified service agency.
Oct 17, 2008 | Kenmore Kitchen Ranges
Stove replacement?
All the fault codes I could find on Roper indicates that this is an Electronic Oven Control (EOC) failure. This is your clock assembly. carries the part for about $47. I think for that price, it may be worth the attempt to repair the range, vice replacing one at a cost of hundreds of dollars. Just type in your model number and you can locate the clock assembly under the "Backguard Section" heading as item number 17 (part number WB27M10). I hope this helps you.
Aug 17, 2008 | Roper FGP325K Gas Kitchen Range
Kenmore Stove Glass top
I have a Kenmore glass stove, not sure what the model number is I don't have it with me right now. Yesterday, the timer started to beep and F1 started to flash in the display. The stove top is working, but the oven does not. The only way I can get the timer to stop beeping is to unplug the stove.
Any suggestions as to what is going on with this stove. It's only 4 years old.
Oct 22, 2007 | Kenmore 46123 Stainless Steel Electric...
Kitchen Ranges Logo
256 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
