Question about JVC GR-D244 DV Digital Camcorder
White Spot My camera is new - barely used. There is a white spot visible anytime I'm recording or playing back the tape. It's visible both through the eye piece and on the wide screen view. If I zoom in really far the white spot eventually goes off the side of the picture. The spot never gets bigger when I zoom in though. It looks like maybe a pixel is missing or maybe something is inside the lens obstucting the view. I have been thinking of getting a head cleaning tape. Does this sound like something that would help?
  • 1 more comment
  • catzcam May 28, 2008
    I also can see it just when I have the camera on and I'm looking through the lens (when it's not recording.)
  • catzcam May 29, 2008
    Maybe there is something on the sensor like you said because the size of the spot never gets bigger when I zoom. It stays tiny even when I zoom all the way in and it goes off the side of the screen. It's very tiny, like the size of a pixel maybe. Yes I am always in digital zoom as you asked. It's too tiny to tell if it's blurry or sharp. I don't think it's on the lens; I don't know how to "look down the lens" though. I unfortunately don't have the receipt so I can't send it in to be repaired on warranty. They told me it would cost at least $200 just to send it into the JVC repair center without warranty. I really hope I can figure out how to fix it myself!
  • Niels Boehme May 11, 2010
    It seems more like something in the lens. Do you see it only while recording and playing back, or also when you are just looking through the camera?
    Scholar:
  • 125 Answers
If this white spot is always exactly the same, but moves off the picture when you start to digital zoom and not optical zoom, there is probably something on the sensor. You mentioned that when zooming, eventually it moves. Are you in digital zoom mode at that time? (The switchover from optical to digital zoom is automatic, but you can disable it). Is this white spot blurry or sharp? Can you see fringes of the image at the edges? (This would suggest something on the lens).
If there is a piece of dust inside the lens ,you may be able to see it looking down the lens. How big is this spot?
Either way, if the camera is new, can you still return it?
Posted on May 28, 2008
Jvc gr-ax35 only plays black and white on 3 different sources i.e. tv, dvd recorder player and usb capture. could this be tape detrition or dirty video head
i would take it and get it serviced
i think the tape isnt running at quite the right speed perhaps a dirty bearing
usually if you get black and white from a colour video
then its either recorded in black and white or playing back black and white
so if you record then test it using a a vcr and a converter vhs tape box then you can see if its recording in black and white
then youll know its something too do with either the colour carrier etc component of the video its outputing
dont think its a dirty head
but you can clean it easy enough
i use a plain manila envilope and use the inside of its paper
the outside is smooth the inside is rough
its just right to clean the head drum
and some small lint free cloth to carefully clean the mecha
i use IPA isopropile alchohol {get from the chemist}
Jan 10, 2015 | JVC Video Cameras
Tape recorder will no longer play or record
Tape players need maintenance often. You have to replace the belt, clean the rubber roller with Rubber Renue, put grease on the odd spot and clean the head by rubbing clean white paper on it. Any electrical contacts like a volume switch etc need a contact spray to remove oxides etc. This should be done every 5 years or even more often if used more often.
Nov 07, 2013 | Lanier Audio Players & Recorders
LCD screen and pictures go completly white
The camera is defective. But as you've only had the camera three months it still is under warranty. Canon is usually very responsive to these type of problems and will bend over backwards to make things right (probably the most responsive of the camera companies).
Call 1-800-OK-CANON to resolve this issue.
May 25, 2009 | Canon PowerShot SD1100 IS Digital Camera
Vidio recorder when i record it wont play back what is recorded but it will play pre recorded tapes Is it campatable for LG television please model no VR550/07
If it plays back pre recorded tapes then there is nothing wrong with that section of the unit. Does it playback audio and not picture or does it not playback anything.
Also, when trying to playback a recording what is seen of the screen? Snow(black and white dots or wiggly picture?
The unit uses two separate circuits to record and playback tapes. Is any thing else connected to the unit while you are recording? If you are using anything plugged into other ports on the recorder it may not see the camera input causing it to not record anything..
Feb 03, 2008 | Dishwashers
Recording problem on Sony SLV-R1000
The deck needs a good cleaning. Try using a brand new tape and run it on playback for 20 min or so. You could try using a cleaning tape, but many of them are abrasive. If this doesn't work, you need a deck re-alignment which will cost more than your set is worth.
Nov 13, 2007 | Sony SLV-R1000 S-VHS VCR
Blue lines in play mode
This is not a problem with the tape but the camera. The only way to fix it seems to be to find an empty spot on the tape or a spot you don’t care if you record over. Then record for a second then go to video mode and you can play the tape without the blue lines. Or buy something else to play the tapes which should be fine either way. Darn camera !
Oct 14, 2007 | Panasonic Palmcorder PV-GS12 Mini DV...
LCD won't project
You may have a problem with the image sensor device (CCD). From October 3, 2005 through October 2, 2007, Sony will repair, free of charge, affected products exhibiting the above-mentioned problem where it is caused by the image sensor device. Sony will also cover the cost of shipping and handling from and to addresses within the United States and US Territories for service to correct this issue. To see if you have this problem: Power On your camcorder (make sure the battery is fully charged). Check the LCD screen and verify that the display icons are turned on. If you cannot see the icons, press the Display button until the icons are visible. Put a tape in the camcorder. With the lens cap off, record some video. NOTE: Be sure to speak during the recording so the video will contain your voice. Rewind this section of the tape (using tape counter to verify start of your recording). Play back the recorded video and use the LCD screen on the camcorder to view it. You should hear the audio you recorded and the Display icons/text will still appear. If your camcorder is affected by this CCD issue, the picture will either be extremely distorted, or there will be no visible picture (just a blank LCD screen with the display icons still visible).
Mar 22, 2006 | Sony Handycam CCD-TRV318 Camcorder
White spots
In addition, flash lighting dust doesn't make a white spot, but a fuzzy whitish circle (out of focus). The image underneath is still visible, but distorted. These are definitely not flash reflecting on dust.
Sep 07, 2005 | Panasonic Lumix DMC-FZ5 Digital Camera
Jvc 200u problem recording to vhs video tape, from camcorder
Yes, if the camera is a US camera then it is NTSC. That would be your problem, you are trying to record an NTSC signal to a PAL video. THe frame rates and resolutions are all wrong. I am even surprised that it is playing back on your TV okay...
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
JVC GR-D244 DV Digital Camcorder Logo
216 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
