Question about HP Photosmart R725 Digital Camera
LCD screen blackout
I am experiencing a problem where every picture I take, even on the factory default settings, causes the LCD screen to go completely black. When the photo is processed, the LCD screen comes back on. Has anyone else experienced this issue and if so, how did you resolve it?
I don't think it's a problem, my r818 does the same thing.
Posted on Aug 14, 2008
Automatic screen blackout and No sounds
I presume you are unable to activate the on screen menu after the picture goes, if you can then heat for setup or initial set up and factory reset and see if that clears the problem.
My guess would be it needs a service engineer to look at it there may be a faulty part which fails shortly after power up. If by Off it is just in standby then try pulling the plug out for an hour to let it cool down then if that works do a factory reset to clear any software problems.
Hope this helps.........
Jun 26, 2017 | Panasonic VIERA Televison & Video
LCD not working
If you need them, you can get all the related user manuals/guides from this link; http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=320&modelid=14109 There are a few possible causes for your problem; Faulty LCD screen - check if you can review pictures on it, even if you can't take pictures using the screen. Bad connection - you can try moving the screen into different positions to see if it comes on at any of them - where the connector goes through the hinge is a possible problem site - more likely the connector has come loose at one end or the other. Software problem - Connect the camera to a PC/Mac, and open the "Zoom Browser EX/Image Browser" program. Find the "Set my Camera" window and you should have "reset to factory settings option" (check the software starter guide page 42) You can reset all the camera settings to their factory default value - this has to be worth trying. I would use the warranty - Canon warranty service is usually pretty good - post back with your general area and we can hopefully find you a service centre. Hope this helps :)
Jul 07, 2007 | Canon PowerShot A640 Digital Camera
Am using verizon 9530 unlocked. phone is working, the backlight is active on buttons...!! the screen is not active.. i could answer / receive calls.. can hear the notifications of receiving emails /...
When you get your blackberry screen blackout? After your blackberry 9530 unlocked or a few days after you unlocked your phone? Did you get my point? If you get that blackout screen after blackberry unlocked process try to reset your phone to default factory setting and if still not working try to reinstall your blackberry os, but if you get that blackout screen a few days after you unlock your phone looks like your screen already broken and you need to replace it in your nearest local mobile repair shop.
Jun 11, 2011 | RIM BlackBerry Storm 9530 Smartphone
LCD screen and small viewfinder screen go snowy than white. When I turn the camera on the LCD worked fine, when I than turn it, it was just white. Now it won't even turn on normal. I can still make...
Go to your menus, set all to factory settings or default.
Test the camera by using more of the settings, and notice how it works.
The LCD settings especially are what you want to make sure are set right...not too bright, and of course not too dim either.
Sep 25, 2009 | Canon Cameras
Nikon lcd screen will not turn on
reset ALL settings to factory defaults.also remove meoryh card and batteryh then refix both.then check .
Mar 24, 2009 | Nikon COOLPIX L18 Digital Camera
Periodic tv screen blackouts
The problem is your cable box. I know you said you replaced it, but I work on TV's everyday and, sorry to say this but cable box HDMI outputs have serious issues, like no or intermittent sound and video. I have seen customers exchange their cable boxes 5 and 6 times and still have the problem. Your best bet is to use the component outputs of your cable box, visually you will not see a picture difference between component and HDMI when using a cable box. Your other solution is to get satellite; I have NEVER seen an HDMI issue with a satellite box
Nov 25, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Picture washed out, can't get it right
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Sep 21, 2008 | Akai LCT2715 27 in. LCD Television
Lg 42 lcd tv picture too large for screen after blackout any ideas
Find out the code for the service mode and do a factory reset
Mar 16, 2008 | Televison & Video
In AUTO mode, pictures are all dark!
Yes you definitely can,
Turn on the camera.
The mode dial can be turned to any setting.
2. Press the button for longer than 5
seconds.
The message “Reset settings to default?” appears on the
LCD monitor.
3. Select [OK] using the left and right
buttons, then press the button.
The normal screen resumes when resetting is complete.
To cancel resetting, select [Cancel] instead of [OK].
Dec 09, 2007 | Canon PowerShot A70 Digital Camera
HP Photosmart R725 Digital Camera Logo
82 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
