Question about Intermatic Inc. ST01C Digital In-Wall Timer
INTERMATIC DIGITAL WALL TIMER. ITS 15 AMPS AND 6 DAILY ON OFF SETTINGS.......DONT TURN ON
You didn't say if ST01C timer stopped working ... or if you are programming new timer and can't get it to work.
I assume you are programming new timer.
Intermatic: download EZ-instruction and full-manual so you have BIG print.
Troubleshooting in manual covers many things:
1)Press On-off button. You should hear audible click ... that tells you timer battery is good ... do the lights come on?? Load should turn on-off with manual override without programming. If load does not turn on, your wiring is wrong, a breaker is bad, a bulb is burned out, a 3-way switch on same circuit is bad.
2)Solution: review wiring diagrams > the key to wiring is black connects to Hot and blue connect to Load
Solution: If your black and blue wires are reversed, timer will not turn load on-and-off. Change them and see. Red wire is not used in 2-way switching.
3) Conflicts in programming cause timer to ignore program. For example program1 says ON at 7 and OFF at 8, but program2 says opposite.
4) Solution: make a chart of your programs
5) Solution: Reset timer and reprogram again being careful to follow instructions > instructions are tricky
Posted on Oct 05, 2010
What is the intermatic e 1020 used for just moved into a house andits in the bathroom and makes a lot of noise.
The E1020 timer is reliable heavy-duty 24-hour on-off analog timer with replaceable trippers and manual override, rated 12 amps.
This timer replaces ordinary single-pole on-off switch.
Timer has extra white wire that connects to white neutral wires inside box to run timer mechanism, while mechanical single-pole switch does not need this wire.
I don't know what it is doing... maybe running the vent fan periodically, or turning on attic vent fan?
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#E1020
http://waterheatertimer.org/How-to-set-timers.html
For same timer, with less noise, install E1100-1200 aka the KM series in-wall analog timer. Or install digital in-wall timer, or replace timer with on-off switch.
Aug 11, 2012 | Intermatic Timer E1020, Single pole/single...
Self adjusting in wall timer
Timer is not known.
Copy following links to identify timer and download manual
http://waterheatertimer.org/ST01C-program.html
In the manual, you will see directions for resetting timer.
If resetting does not work, then review timer programming carefully to make sure there are no conflicts in the programming such as overlapping days, or inconsistent am-pm, etc
Jun 13, 2012 | Intermatic & Self-Adjusting Wall Switch...
Had to change battery. Since I did this the day will scroll several times and will not let me set the day, nor the time, nor the mode. Is my unit toast ?? As it was working till I changed the battery.
Most digital timers suggest resetting as last-step effort to restore functionality.
This particular timer is reset by removing battery.
Try removing battery again. Otherwise it seems the timer has gone bad.
HB88RC is discontinued product.
Replacement is heavy-duty Intermatic HB800RCL 2-outlet or HB800RCH 1-outlet timer.
http://www.smarthome.com/25078/Intermatic-HB800RCL-Heavy-Duty-Digital-Appliance-Timer/p.aspx
http://www.smarthome.com/48715/Intermatic-HB800RCH-Outdoor-Digital-Timer/p.aspx
Less expensive and less reliable timer Woods 59403 with 1-outlet has quite a few 'timer won't work' questions on fixya.
http://www.amazon.com/Woods-59403-Heavy-Duty-Outdoor-Digital/dp/B002KS7EOK
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
Jun 19, 2011 | Intermatic HB88RC - 7-Day Programmable...
Lost the guide book for setting the timer. please help me with directions to program time for lamp to come on and go off daily. Thanks My email address is ilewis@h2l.com (H2L.com....all lower case)
Check following link to make sure this is your timer:
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/digital%20timers/dt620cl.aspx
Manual for DT620
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt620cl.ashx
This is a plug-in timer with internal rechargeable battery.
If battery will not charge, then display doesn't show, and timer is no good.
If this is not your timer, then add a comment with detailed description of timer for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 04, 2011 | RTO Intermatic DT620CL 15 Amp Indoor...
I need instructions on how to program the timer. Can you sent via e-mailm a copy of the instructions? Thank you.
You posted under Intermatic HB88RC 6 button timer:
Add a comment any time.
Manual for HB88RC
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb88rc%20-%20english.ashx
If your timer is different, check timers on link below to identify your timer.
Each timer on page has manual
geno_3245_165.jpg 6 button 7-day
Dec 10, 2010 | Intermatic HB88RC - 7-Day Programmable...
Where can I buy a new timer, I have looked at intermatic website and a general google
Search for Intermatic digital outdoor timer turns up HB800RCH
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb800rch.aspx
Amazon shows one for $36
http://www.amazon.com/Intermatic-HB800RCH-15-AMP-Outdoor-Digital/dp/B002MUB8A2
Manual says 'plug the desired devices into the timer' >>> so it must have more than 1 plug for your lights etc
Oct 16, 2010 | Intermatic HB88RC - 7-Day Programmable...
Suddenly the timer is not turning on the lights. The screen on the timer says "SOU". ????
Here is link to product manual at Intermatic. Manual shows troubleshooting, but doesn't show "SOU"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers/st01c.aspx
ST01C works on a 3-way circuit > If another switch is involved, or if switch or timer are not grounded properly, it might affect timer. Troubleshoot says disconnect red wire from 3-way circuit, and see if problem continues, and then suggests replacing timer.
Manual says if CR2 batteries are weak, then BATT shows on screen. Also says weak batteries will cause circuit not to work.
Check the CR2 batteries: Timer holds programming while you replace batteries and clean terminals.
ST01C programmable timer works on circuits up to 100 feet >> I assume because it's battery operated >> electrical interference affects the circuit because troubleshoot lists 'buried wire' as cause of failure. I guess nearby electrical devices could affect performance of timer.
Timer is rated for 15 amps which means practical maximum of 12 amps >>> so 120 volts x 12 A = 1440 watts max or 14-100 watt bulbs >> if you are running more watts, or running close to maximum, or if timer gets warm during operation, this would shorten lifespan simply by heat affecting the circuit.
Interesting that the EI600, EJ500 & ST01C battery-operated timers each has troubleshoot section in manual >>> implying these timers are problematic. ST01C has limited 1 year warranty. EI600 has limited 5 year warranty.
ST01C has 40 on-off programs per week.
If 7 on-off events per week can do the job, you can switch to the EI500 [click on EI500 to access manual]
http://www.intermatic.com/products/timers/in-wall%20timers/digital%207-day%20time%20switches.aspx
>>> the manual shows no troubleshooting section. The EI500 requires connection to neutral or white wire, since the timer runs on electricity instead of battery
[you can use ground wire instead of neutral]
http://waterheatertimer.org/Wiretimer.html
You can compare different types of programmable wall timers:
http://waterheatertimer.org/Programmable.html
Sep 11, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I need a printout for instructions to set an Intermatic EJ 500C digital wall switch
I have a intermatic house timer to turn on and off the outside lights We moved in 5 years ago to this house. One evening somehow the lights did not turn on or turn off when programed. I accidentally reset the system by pushing the reset button instead of the on / off button. I dont have a model number of the timer to look up, maybe you can tell me where I can find it on the device? or general instructions on how to set the system to go on when the time is set and of . I was hoping to see if I can find a model similar to one I have. I saw one close but I dont know its the same or not.500c or maybe a model 10 years ago plus. By the way it has a battery conpartment using a single AA battery. The best description I can give you is its white in color...rectangle has a display screeen on top of the unit....and has 6 soft push buttons ....3 on to , 3 on the bottom....top row of buttons has MODE ON/OFF EVENT...RESET the bottom row has DAY...HOUR....AND MINUTE..Please advise
Apr 05, 2009 | Intermatic Inc. EJ500C Digital Wall Switch...
Intermatic Inc. ST01C Digital In-Wall Timer Logo
124 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
