Question about Honeywell Heating & Cooling
I have a -AC message on programable thermastat
    Problem Solver:
  • 18 Answers
If it is showing A/C it has lost control voltage or the 24 volts to operate. Need to check line voltage to furnace and check the control board, if a late model unit, most will have a 3 amp fuse mounted in the control board. If blown need to find out why??
Posted on May 28, 2008
Can drive truck and suddenly ac will shut off and the temp gauge will display the message engine hot ac off,even though the actual gauge reads its cool,this happens even after sitting all day
Hello, when the last time you have had your truck coolant system serviced? The anit-freeze needs to be reomove the coolant system flushed out (cleaned) Also, maybe a sticky themrastat and it will need to be replace along with a new radaitor cap.
. Clean the radiator inside and out---flush the inside with flush cleaner especially designed for auto coolant systems.
Flush the engine block this can be done with the radiator at the same time.
Replace the thermastat
replace the radiator cap with the correct pressure cap. GB...stewbison
Aug 31, 2011 | Chevrolet Silverado 1500 Cars & Trucks
In Fan mode, fan works; but in AC mode, I can hear the normal AC sounds, except the fan never turns on. This is the fan in the lower half of the unit in the inside of the house, which blows the air...
on a call for air conditioning your therrmastat brings the indoor fan on and the out door unit at the same time. Since your fan comes on in "fan" mode, it sounds like you need a thermastat. For temp. cooling just turn your fan switch to "on" and turn system switch to cool and set desired temp. System will cycle off and on but fan will not shut off until fan control is set back to "auto". I suggest replaceing thermastat
Aug 16, 2011 | Heating & Cooling
My AC Switchs wont turn on but the ac is fully charged and the fan works changed the thermostat and still the ac wont work..please help!!
The Thermastat has nothing to do with your AC becoming on at all because the Thermastat has to do with radiator fluids going into the engine to keep its high temperatures in check not your AC. You need to check the connection of the switch with a multimeter to see if current is getting to it and it is not then check the fuse for your AC in fuse box so see if this fuse is blowned. If the fuse is blowned tells me that there is a short in the wiring to the AC switch.
Jun 10, 2011 | 2005 Hyundai Elantra
Ac works at beltway speed but not nieborhood speed
Sounds like your fan is not coming on. You will need to find out why.
Over heating your engine is never good.
Aug 02, 2010 | 2006 Mitsubishi Lancer
No Power to Duo-Term Thermastat
Can you give me model #'s of thermostat & AC unit, as well as upper unit? Number of or at least a description of thermostat, and numbers for ceiling assy should be visible when filter taken off, as well as # for upper unit should be tagged on bottom of unit on roof.
Jul 17, 2009 | Heating & Cooling
Heat pump Thermastats have Terminals RYW/OW2 G C. I run into this a lot with people buying tStats at home depot. To wire three sages of heat you must have correct tstat. one stage cool and three stage heat. You have to have enough wires at the Tstat. I use white first stage brown second and grey or black third. Make a diagram where each wire goes. Remember to trun of air handler power or you will short the transformer or blow low voltage fuse. Yellow cool, green fan, most of the time blue is c unless it is a battery tstat. orange is O. Red R ot power wire. Rusty
Jun 03, 2009 | Heating & Cooling
Ac heat carrier thermastat model no.hh01ad042
GOto the iside unit itself. and remove the door and look for a terminial strip that the thermostat wires from the thermostat connects to and write down the colors wires and the letters they're connected to and connect the same to the thermostat .... they should be... r--red=power w-white=heat y--yellow=cool g-- green=fan! See which wires/ colors they're not using and bend back! Thank-you-very-much!
Aug 31, 2008 | Heating & Cooling
Thermastat malfunction
Generally speaking; R terminal to Y terminal on the back plate. However you may have a transformer problem which would not give you power to the R terminal in the first place. Jumpering R to Y should make the outside condensing unit come on if you have power.
May 08, 2008 | Heating & Cooling
Heating & Cooling Logo
50 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
