Question about Maytag 24 in. PDC3600A Built-in Dishwasher
Door not a-ligned.
Our dishwasher shuts on one side but the other seems too high and you have to jiggle it to one side to get it in, does run, but if you don't latch it the door will come crashing down all of a sudden.
    Genius:
  • 1,122 Answers
Take bottom plate off,look under dish washer inside on both sides,there should be to springs one on each side that holds the door brackets,make sure both springs are on,you can also tighten the door with these springs just my moving them up or down,thanks-mike
Posted on May 28, 2008
Bosch shv46c03uc
I would check the latch on the door..When you shut the door it makes contact telling the washer it's closed
Aug 17, 2013 | Dishwashers
Hinge cord broken. Need to pull dishwasher out of cabinett
Remove front screws holding washer to cabinet. Jiggle, leveling feet may be stuck
Sep 15, 2012 | LG Dishwashers
Erestanding Equator PLS600 Overflows
May be this time the drain hose has been clogged or the drain hose is at a higher level than the unit or may be the drain pump has stopped functioning.
Mar 09, 2009 | Equator 20 in. PLS600 Free-Standing...
Frigidaire FDB710LCS0 Dishwasher dial seems to stick?
I had the same problem. Turn the HIGH TEMP buttons off. Simply turning them off corrected this problem for me. Mine got stuck in two places and I had to manually turn the dials or the washer would run all night.
Nov 21, 2008 | Dishwashers
Bosch SHY56A Dishwasher
if the door doesn't shut, the push buttons should not work. that way you are not running your d/w with the door open. check the door latch, as it seems to be malfunctioning. if the d/w still does not work, replace the door latch.
Aug 15, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Door wont shut properly and washer will not start
Is this a problem that just happened at once or gradually got worse?
Does the D/W seem to be installed tightly to counter??If it is firmly mounted than you need to take loose the screws that are holding it in place to your counter.Usually there are just 2 of them.Only remove these if the door seems to be hitting something just before it is shut.By opening & closing slowely I need to know if the door seems like it bumps the inside right before its locked.By removing the 2 screws that hold this snug it will allow the squarness of the cabinet to become free & the door will align itself.Alot of installers over tighten the legs & lift the dishwasher into the counter so high that it forces the door to miss the Latch.I'll help you through this ,so let me know ,Thank You!
Apr 16, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Maytag 24 in. PDC3600A Built-in Dishwasher Logo
77 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
