I need instructionns on how to remove the power supply from a xerox workcenter pe 120i
  • black_demon_ Apr 05, 2009
    I don't know how to use it. They both it w/out manual. please send me the instructions.
    President:
  • 2,072 Answers
You have to remove the print cartridge and lay it on its side.
Remove the paper tray and all the fasteners in the metal plate on bottom. I think there is about 8 screws. But it is accessed from the bottom, and actually easy to replace.
Posted on May 30, 2008
Buna ziua, Am o mica problema. Am un echipament Xerox Workcentre 128 Pro, am instalat un sistem de operare Windows 7 pe x64. Problema este ca nu reusesc sa setez imprimanta sa imi scoata fata verso....
In Windows 7 - Duplex printing in Xerox Workcenter 128:
Go to the printer in your printer folder in control panel. Double-click on it then select menu option named "Printer" and click "Properties". Hope it helps you. It worked for me.
Sep 06, 2011 | Xerox WorkCentre Pro 123/128 Printer
Workcenter pe 16 open heat error
Bad Fuser. Google a business called The Parts Drop to order.
It is not difficult to replace. Remove the back cover, 4 phillips screws pull out slide the new one in.
I would remove the fuser first though. And check the plastic in the ends of the fuser. If they are melted, then the power supply has failed and you will have to replace both the fuser and power supply. If the fuser looks normal no plastic on the end of the rolls melted, then just replace the fuser.
Mar 12, 2011 | Xerox CopyCentre C20 Black and White...
I need a driver of my printer XEROX WORK CENTRE PE 120i for Win7 32bits and 64 bits.
You can download the Xerox printer drivers from theirsupport WEB site. Please click on this link and
select your model printer todownload :- http://www.support.xerox.com/support/enus.html
Feb 21, 2011 | Xerox WorkCenter PE120i All-In-One Laser...
Una xerox 120i k me da el error ¨sin cartucho¨ apesar de tenerlo instalado, ya limpie todos los contactos y se mantiene el error, si alguien me puede ayudar se lo agradesco de...
Assuming you have the correct consumable for your printer/contract. Make sure you remove any plastic or stickers near the cartridge.
You can also follow this tips. Page 2.5
Reboot the machine removing the power cord.
Aug 27, 2010 | Xerox WorkCenter PE120i All-In-One Laser...
Our xerox workcenter 7235 fault code 024-360 and copy service is disabled
024 360 An error has been detected by the Controller during communications with the Printer. User intervention is required to Power Off/Power On the machine, Field Service is required if the problem persists. Printing is disabled.
http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=WC7228_WC7235_WC7245&Xlang=en_IN&Xcntry=IND
You will have to either get this printer repaired or replace it.
Aug 05, 2010 | Xerox Office Equipment & Supplies
Xerox pe 120i scanner does not work in windows 7
So far there just isnt a Windows driver for that machine
Dec 16, 2009 | Xerox WorkCenter PE120i All-In-One Laser...
Xerox PE 120i workcenter. Error says
you need to remove your paper tray.take your toner carriage out ,yurn the mc and assess
Nov 29, 2009 | Xerox PE120i Laser Printer
Keeps showing "document jam" even though the jam was cleared
Most likely one of the jam sensors was knocked out of its clip. You would have to take the document feeder off and apart to find and reseat it.
Mar 25, 2009 | Xerox WorkCenter PE120i All-In-One Laser...
Workcentre pe 120i memory full
in spec. say's so:
your workcentre Pe120 have only 32 Mb memory.
fax function is equipped with a 4 Mb standard memory.
In spec. shows a 4mb memory is just enough for 320 pages of fax!!!
i think your problem is given from the 32 mb of memory of workcentre pe120, not from fax memory, because the faxes received or delayed is compressed with a very strong altgorithm, and these files is very small.
http://www.office.xerox.com/multifunction-printer/multifunction-under-30ppm/workcentre-pe120-pe120i/spec-enus.html#Memory
a link bellow ; i think is useful:
http://www.xeroxdirect.com/direct/public/products/accessorizer/dsp_accessory.cfm
for a 32 MB memory module (product code is: 097n01434)
Sep 23, 2008 | Xerox WorkCenter PE120i All-In-One Laser...
82 people viewed this question
k24674
jasbo
jasbo
