Question about Behringer EuroPower EP4000 2Channel Amplifier
What is causing my EP4000 to start clipping after 2hr and have my highs to go out what am i doing wrong? I have changed cables and have had the same problem
  • 41 Answers
You're amp is probably approaching thermal mode which causes the amp to overheat and eventually shut down or if it has a limiter built in this is due to distortion. You must lower your output volume.
Posted on Oct 05, 2010
I WANT THE REPLACEMENT FOR TRANSISTOR A-06 ,A56 ,KST42
send to shop before you kill your self, this amp has very high voltages in it.
Aug 23, 2013 | Behringer Ep4000 Power Amp Ep-4000 Speaker...
I changed the timing belt on handa accord and now its ideling high and very rough what causes this
you need to lower the idle down to around 750 rpm. there are to cables that go to the throttle body/intake. there is a little clip they sit in along with a nut on each side of the clip. loosen the nut on the side they come from a couple turns. you should notice the idle drop and you just have to fine tune it from there.
Apr 19, 2013 | 1998 Honda Accord
I have just purchased a Magnaox ZV247MG9 and to convert VHS to DVD and my first DVD is blank. All the connections are made and I followed the manual, but am confused as to what happened.
I hope you have resolved this by now but in case you haven't: The only thing I can think of is that the disc was not compatible. Make sure to use one of the discs listed in the manual.
Mar 19, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
I have a Minolta ep4000 copier. The bottom letter tray platform where the paper sits on is stuck in a high position. The copier will not allow that tray to feed paper. I tried to turn the machine on and...
With the draw closed and the machine on is there a small wrench Icon on the control panel lower left. If so touch it screen will change then once on new screen open close the front door, see if that resets your draw electrical.
Apr 07, 2011 | Minolta EP4000/5000 CS/PRO Copier
Tv turns it`s self off and on at random. It also changes from regular cable to dvd at random. If you turn it off when it is on cable, and then you turn it on, it will stay on cable for about 5 min, then...
this fault realy seems like possible dry solder joints in the power supply or high voltage area of the unit, the transients caused during a bad connection can easily change av channels etc,also check all scarts are fitted correctly at the rear as there is a 12 volt line on each scart input which if suffering from a loose scart plug or dodgy cable can switch tv functions.
Nov 03, 2010 | Televison & Video
Minolta EP4000/5000 CS/PRO Copier how do i change my toner
Open the large front door. The toner bottle is at the upper left side. Swing it out by pulling out on the left side. Slide the old toner bottle out of the gray holder. Now take the new cartridge, keeping the hole with the seal on it on top. Slide it into the holder where the old one was. There are 2 "pegs" on the bottle that will clip into a clip on either side. Once fully installed simply pull the plactic tape towards you to remove it from the bottle and swing the new toner back into place and close the front door. Thats it!
On most of the 4000/5000 models the toner instructions are on a label inside the front door.
Good Luck and Thank You for using Fixya.
Jun 03, 2010 | Minolta EP4000/5000 CS/PRO Copier
Help. i connect my sansa clip mp3 player to my pc it says "connected" then i leave it there for 6 hours while im in computer then its still charging and it never ends.... its supposed to make that? another...
you are spoiling the battery.you should not charge it to 6hr,well 1hr-2hr is very suffiecent.
problem with your battery.so use it and recharge it when it says low battery.
recharge it only 2hr not more than that.
Jun 19, 2009 | SanDisk Sansa Clip MP3 Player
High level buzzing
Only the following 3 things could cause this:
1) Tonearm
2) RCA Cables / RCA connectors
3) Cartridge/Styli
Make sure your ground cable is also connected.
- Davis
DJ Pro Audio
www.DJPROLAB.com
www.DJPROAUDIO.com
Aug 04, 2008 | Stanton STR8-100 Turntable
Behringer EuroPower EP4000 2Channel Amplifier Logo
317 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
