Question about Sony KP-51HW40 51" Rear Projection Television
Kp51hw40 Hi... i read somewhere where you had said that if we order the ics from that parts store you recommend that they would provide instructions and pictures on how to replace the ics. I ordered two but didnt get instructions on removal and insertion. What gives. I can solder, so i guess i will just have to wing it.
  • Ramblon May 29, 2008
    Hi SLinteriors... yes thanks... I emailed them and they shot out the instruction via email... thank you... and I hope your recovery from the tornatoes go well.
  • Ramblon Jun 03, 2008
    Hi SL... I swapped out the ics (2). Still not workin. However, its probably b/c i butchered the job.(poor soldering). I switched to a better desoldering iron and boy it works fast and great. The last pin was murphys law all the way. Wouldnt take solder for nothin. I would take out the board completely for better positioning but those two red high voltage wires wont come out. The service manual says twist and pull but wont budge. Can I clip em? I will resolder again and see. Can I send you the board? If its not the ics what else could it be? But first i will resolder then see. Thanks a mil !!!
  • Sony Master
  • 8,617 Answers
I work for them, we had some tornadoes. just send them an email and they will email them out our computers were down for a few days so they had to ship some without the instructions , but they are emailing out to any one that doesnt recieve them with their order.
Posted on May 28, 2008
  • Sonny Berry
    Sonny Berry May 29, 2008
    We are slowly getting back to normal, the power outages were a big hassel especially at work. Doing projection repairs by flashlight and propane soldering irons is not all its cracked up to be. Good luck with your repair.
Hi there. i have a panasonic dvd-s53 , the power supply ic1021 is blown up , i need to know the number please. thank you.
I am not totally sure since you may not be able to read the number on the original IC - however C0DACZH00006 appears to be one number for Panasonic IC 1021 reference. (this is for the DVD-S47 but it seems to be standard type for this series).
I suggest you contact an authorised service centre or Panasonic directly, and provide the above number IC to them - along with the DVD player model number - if this turns out to be correct, you can go ahead and order the part. Not too expensive and it is not a surface-mounted component. It is available. I also recommend that you replace all the electrolytic capacitors in the SMPS - as several may have leaked, causing the demise of the IC. Don't just replace the IC - and touch up any dodgy solder joints in this circuit.
See how you go. No power supply is irreparable.
Mar 29, 2011 | Panasonic DVD-S53
The blue won't align with the other colors. It looks like a double pic, but it's only the blue that won't align with the others.
HI:
One of your convergence IC have failed. I recommend having both of them replaced as the other may not be far behind to fail also, They are large OP-AMP IC's that control the beam in each of your picture tubes. They may use the part# STK-392-110, google this number for better info on the IC's and where to get them. If you know how to solder and unsolder electronic componets then you can install them yourself, saving you some money. They are the two or three LARGE BLACK IC's mounted on a large metel sink. Typical price for most local shop to repair this problem is $130-$210.00 depending on what IC's part number is installed.
Nov 10, 2010 | Toshiba 42H83 42" Rear Projection...
JVC AV-56WP74 Convergence problem. I've read about convergence problems with the JVC AV-56WP74 and I am pretty confident my set needs the convergence board repair. You mentioned to another user that you...
Hi Dave
Thanks for using FixYa. If the issue is with the failed convergence (STK) ICs which needs to be replaced then, it’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs(STK ICs) which are located behind the black/gray heat sink and also check theresistors as if they are short the ICs might blow again after sometime. Please check this picture:
And yes you are right there are repair kits available which includes repair instructions with the parts, if you want to do it yourself, you can buy and repair it yourself. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 17, 2010 | Televison & Video
Sony kp51ws510 convergance problem
You need two convergence ICs they are both STK392-560 you can get replacementICs at the following link and they provide free instructions with pictures and free tech support to help you with the replacement proceedure.
http://servicemanuals.vstore.ca/
Jul 15, 2008 | Sony KP-51WS510 51" Rear Projection...
I have a convergence problem with my akai PTH5498 REAR PROJECTION TV. Please tell me how and where I can order the part plus how to install it.
You need to replace both convergence ICs they are STK392-040 you can get replacement Ics at the following link and they provide free instalation instructions. Heres the link.
Jun 04, 2008 | Akai Televison & Video
Convergence Shutdown - instructions how to fix?
Yes the STK 392-150 is a better quality IC. You will need to replace both of them. Also if you purchase the ICs from the link i am posting they provide free instalation instructions with pictures and also have free insatant messageing tech available which is completely free. I am one of their support techs and they are a good site heres the link if you want to check them out.
May 19, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic pt-47wx42f
Yes you can get replacement IC STK392-110 convergence ICs at the following link and they provide free instalation instructions with pictures. The Ics are located on the board on the left side attached to a large heatsink. You will need to replace both ICs heres the link.
May 19, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Sony kp51hw40 rear projection wont converge
You need to replace both Ics numbers STK392-560 they are located on large aluminum heat sinks on the D Board. You can get replacements at the following link and they provide free instalations instructions with pics so you can easilly do the repair yourself. Heres the link.
May 10, 2008 | Televison & Video
Toshiba 61H71 blue convergnece cannot be fixed using TV controls
You need to replace both convergence ICs part number STK392-110 this requires basic soldering not very difficult. If you order the new ICs at the link I am posting they provide free instalation instructions with pictures and free tech support so you can do the repair yourself and save about 400.00 heres the link.
Apr 29, 2008 | Toshiba 61H71 61" Rear Projection...
Pincushion(concave top and bottom) on Green Tube
you need to replace the ic chips aka convergence amps stk's avail thru parts store.com John
Sep 11, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
29 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
