Question about Sony KDL32EX600 32 in TV
Using HDMI on video 6, not getting sound even with RCA plugs
    President:
  • Sony Master
  • 1,779 Answers
Check the audio settings for hdmi. Their probably set to main.
Posted on Oct 05, 2010
HOW DO I CONNECT MY YAMAHA RX-797 TO MY PC-LAPTOP
does laptop have a 3.5 mm stereo output port for sound ?
HDMI is video
YAMAHA rx-797 is a stereo amplifier audio
so you have a RCA phono input port
you need a 3.5 mm stereo lead to rca phone plug
may look like
http://www.4cabling.com.au/stereo-socket-to-2x-rca-plug.html?utm_source=google_shopping&gclid=CO30uN-Muc0CFUEDvAodscUI3w
with red and white plugs ..
Jun 18, 2016 | Yamaha Audio Players & Recorders
How can I make a NEC Plasma Monitor that was given to me work like a TV that has AUDIO?
If it has no internal sound, then you obviously can't make it function like a TV aside from the picture right? It does have inputs whether HDMI or standard Cable wiring to see TV from a cable box?
You'd need to have RCA cables coming from the cable box (Audio out - white wire I'd figure) going into a stereo near the monitor that has a VIDEO button on it where the white RCA cable is plugged into the Audio In jack.
A stereo receiver or even old sort of stereo with a Video or Auxillary sort of jack with button to activate that jack will allow for surround sound from the stereo coming from the cable box in sync with the video of the TV.
Feb 08, 2015 | NEC PlasmaSync PX-42VP5A 42 in. HDTV-Ready...
I HAVECONNECTED ALL MY SPEAKER WIRES,HDMI CABLEAND CONNECTED THE YELLOW AUDIO CABLE.POWERED UP THE DVD BOX BUT I ONLY GET SOUND FROM TV.the tv is a new 47'' LG.
If you are using HDMI cable you will not be using the YELLOW RCA plug sine the Yellow pug is for composite video. Analog audio uses RED (RIGHT) and WHITE (LEFT) for sound.
How exactly youhave the whole thing setup? through the receiver or just between the TV HDMI port and the HDMI port on the DVD player?
You will also need to setup the HDMI sound set up to send the sound through the HDMI cable or through the audio analog RCA ports.
More info needed. Hook up per DVD and TV user manuals
Jan 01, 2011 | Televison & Video
Video works, but no sound when connected with yellow wire. Also, when connecting HDMI cable i get no picture, only blue scree. Overall i have two problems, HDMI portion of the TV does not work, and...
yellow is for video only, please use also the white and red rca plugs for sound, hdmi problem could be a to high resolution choose 720p or 1080i in de connected device.
Oct 30, 2009 | Polaroid FLM-3232 Television
No digital audo from dvdld in
That's probably just for the video.  Plug in the L & R RCA plugs for the sound or just use an HDMI cable between your receiver and DVD player.  HDMI cables handle everything in one convenient cable.
Oct 25, 2009 | Sony STR-DE575 Receiver
No sound when my computer is connected to my Sony Bravia TV
If your computer has a svga output use input 7 on tv with vga to vga cable and 3.5-3.5 Radioshack 42-2387 cable for audio for best results. If you use the dvi to hdmi on input 6 on tv use 3.5- rca Radioshack part number 42-2551 1/8=3.5mm.
Apr 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Cant get audio from my hdmi rca sockets
The problem is that you are trying to use too many connections at once and it is confusing the system. HDMI connection covers both sound, and video. So, no other connection is needed. Try using only HDMI. If that does not work. Use DVI for video and RCA for sound. Also you may need to change the settings in your PC so that it recognises that it is connected to HDMI, or whichever connection you decide to use.
Apr 16, 2009 | Samsung LN-T3253H 32 in. LCD Television
I want to hook up external speakers to my Acer H213H for when my PS3 is hooked up to it.
What method are you using to connect to the monitor?
If you are using the HDMI -> DVI adapter it does not support sound. HDMI does, but DVI does not.
If that's the way you are set up then all you need to do is use the HDMI -> DVI adapter for your video and use the regular RCA connections for audio.
You can set the video and audio settings in the PS3 with the "Display Settings" and "Sounds Settings"
That way you just use the red and white RCA ends to connect to a speaker system, the yellow won't be in use at all.
Dec 10, 2008 | Acer Computers & Internet
How to connect surround sound system, at the moment its connected through cable, each time we use the dvd player we have take them out of the cable box then into the dvd player, we have a LG 42PC55 tv.
In order of picture and sound quality -- from best to worst:
1. The best way to connect, assuming your TV and A/V Receiver and/or Cable Box have the jacks, is to use a HDMI cable ( this cable is for both sound and video).
2. Use Component Video out to input (3 RCA plugs, Red, Blue & Green) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
3. Use S-Video out to input (1 din plug) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
4. Use Video out to input (1 RCA plug, yellow) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
Be sure to select the correct inputs on your TV and Audio/Video receiver when you are watching TV. For example if you have connected your TV to HDMI 1 and DVD to HDMI 2, you will not see or hear anything if you don't select the correct input on your TV and A/V receiver for the input you want to see and hear.
Detailed connection instructions will be found in your owners' manuals.
Hope this helped you. :)
Mar 30, 2008 | Televison & Video
Dvd installation
Why do you need to connect the rca cables when you get better sound through hdmi?
Feb 20, 2008 | Yamaha RX-V1800
Sony KDL32EX600 32 in TV Logo
41 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
