Question about Refrigerators
My refrigerator ice maker leaks
I have a Fridgedaire Electrolux model GLRS267ZCB1, and the ice maker looks like it has frozen icikles dripping down to the white bin, also beore when i tried to get ice the crusher or thing that turns to break up the ice was frozen in ice so it couldnt move
    Genius:
  • 1,122 Answers
MAKE SURE THE FLAP ON THE DOOR DISPENSER IS CLOSING,SOUNDS LIKE AIR IS GETTING IN AND FREEZING THINGS UP,THANKS-MIKE
Posted on May 28, 2008
I have an electrolux double door freezer on the bottom. the ice maker leakes water from the back and water drips from the dispenser inthe front. the cubs in the tray clump together does anyone help me...
That is simply your dual water control valve found on the back of most refrigerators. If I had your model number I would be able to point out the part number and location. Here is what happens. The water valve begins to slowly leak water that comes to the ice maker when not needed. It moves slow enough that it begins to freeze solid inside the fill tube to ice maker and when the ice maker calls for water there is a big chunk of ice in the way and the water goes everywhere but where it should. Here is a short clip with lots of info, Please Rate and Thanks, Sea Breeze
Apr 28, 2011 | Electrolux Refrigerators
I have an Electrolux EW28BS71IS and I have water dripping from the ice maker. When I take the ice maker tray out it has water sitting in the bottom of it. I can't tell if it might be overfilling the...
i have an elecolux ice maker leaks water into the bottom trays from the back of the fridge and water always drips from the front dispenser. the ice freezes in a solid block can anyone help me please. ew23bc71is3 is the model double door freezer on the bottom tks.
Mar 31, 2011 | Refrigerators
Noticed 3 days ago. The ice tray was frozen solid to the top with water not ice cubes. looks like iceberg all the way back to where water line connects to ice maker. Now water had leaked somehow up to the...
What I have seen in a thing like this is a simple water valve drip. Some of them drip like a faucet. This causes the cubes to stick together and all kinds of grief. I have your service manual.
LG bottom mount ice box service manual
Feb 10, 2011 | LG LRBN20510WW Bottom Freezer Refrigerator
Model gd5shaxLT02 stopped making ice. Looks like
The water inlet valve on the back of unit where the water supply connects opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Feb 28, 2010 | Refrigerators
No ice instead water dripping down into freezer making icicles
If you have icicles, where are they forming at? If on the front of the ice bucket, then look at the dispenser shoot door is closing all the way. The way to check that is to look into the shoot while holding a flash light (or bright light) up into the dispenser from the front side of door. You should see no light.
Now if you have ice buildup around the inside of bucket, mainly from the ice maker to the bucket then you either have an ice maker that is leaking water or you have a water valve that is not shutting off all the way. Suspect water valve if you have ice buildup within water inlet tube on top of ice maker. Frozen water within tube is good indication that water valve is leaking.
Look inside refrig side of refrig, usually located on right top side of wall, you will find a tag with model number and serial number. Need both to get you the right part number for ice maker or water valve.
Oct 08, 2009 | GE Profile PSW26P Stainless Steel Side by...
I have a Jenn-aire JSD2695KES - it is a side by side, a couple of years old with an ice maker. Ice gets jammed in the last ice spot in my ice maker. It has been getting stuck in other spots lately, too,...
That sounds like a frozen over water fill tube due to a leaking water control valve. You may need to pull the ice maker out to see it but what you described is what happens when this happens. If frozen over the water will still come out on some models because there is a split in the top of the fill tube. Or something needs corrected on the amount of water time is OK for your ice maker. let me see if I can find the service manual for your model Be back soon Sea Breeze
Sep 21, 2009 | Refrigerators
Electrolux will not make ice. the water will dispense
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 17, 2009 | Electrolux EW23CS65SS Stainless Steel Side...
RS25AWXEW01 side x side refrigerator has leak at ice maker water drips into frozen ice chute and leaks onto floor and also in freezer compartment
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Aug 13, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
Something is wrong with my icemaker
check supply tube behind ice maker,make sure it is lined up to feed icemaker,also you can pull it out look inside to make sure it;s not frozen inside tube or frig. wall,thanks-mike
May 28, 2008 | Refrigerators
Refrigerators Logo
230 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
