Question about Samsung LN-T4065F Television
My television is taking up to 15 seconds to turn on now. It clicks, make the usual sound, clicks again, then make the usual sound again, and finally turns on. My understanding this is a common problem with this television model stemming with an issue with the capacitors at the power supply. Will the repair be covered by Samsung or will I have to pay for it? Thank you, Joe Mach
    President:
  • Samsung Master
  • 1,779 Answers
Replace bulged caps in the power supply.
Posted on Oct 05, 2010
The t.v shuts its self off
How long does it take to switch off,and is there sound when switching off
Nov 13, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Samsung LN-S4051D slow to turn on.
You are likely to have a module bad....part number BN94-00864A and if you take it out (unpluggs) you should inspect it for capacitors that may be domed or pooched up at the top. If so they should be replaced first before getting the module as the capacitors are about $1.00 each. Do a search for Samsung parts online if you need the module and call them toll free
Mar 16, 2008 | Samsung LN-S4051D 40 in. LCD Television
I have a Samsung HLP4663wx xaa that I just replaced the color wheel to fix the buzzing noise and then had to replace the lamp after 16541 hours so definately got my moneys worth. Had to remove the jumper...
I would assume you need to replace that ballast. Usually the bulbs out live the bulb's ballast (from previous experience)...I've seen DLPS do this type of thing when the bulbs are slow to turn on due to a new ballast being needed.
Thanks and hope it helps!
Jul 07, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
Whenever i plug the unit in i hear a clicking sound from the back of the television it is for about 3 seconds and it usually takes 2-5 seconds before it starts the noise. The power light only comes on for...
Ur tv turn on now,hear alot of clicking?The tv LED light "lamp" on front panel flashes or light up?The tv projection lamp is dead.The Ballast board dead too,if hear alot of clicking?The ballast board help to ignite the projection lamp.
Jul 16, 2010 | JVC AV-56P575 56" Rear Projection...
When I press power, light blinks for about 15-20 minutes, then goes off. Press power again, on solid for 30 seconds, then goes off. Press power again, TV finally comes on.
Your television is in need of repair. Hard to tell what exactly needs to be repaired but when the power light blinks in that way then this is the TV's way to tell you it needs to be serviced.
Apr 25, 2010 | Toymax Magnavox 37MF331D 37 in. LCD TV
Sony kv 27V15: No picture but sound
Hi! the trouble indicates that your television's picture is the culprit, have your unit check by a qualified technician for verification.
Sep 12, 2009 | Sony KV-27V15 27" TV
RCA P52937SG Will not turn on, only makes clicking sound.
I had the same problem with mine. There are two voltage capacitors in there. A low and high. The hig voltage is bad. I had to have mine in the shop. Cost about $400
Sep 15, 2008 | RCA P52937 52" Rear Projection Television
TV requires multiple attempts to turn on
You have discribe a problem that sounds like a powersupply cap. It may also be more than one. LOOK at the board very hard for bad caps.
Jul 26, 2008 | RCA D61W20 61" Rear Projection Television
RCA Television D52W14
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Jan 08, 2008 | RCA HD50LPW175 50" HDTV
The first thing in this unit is to check the ribbon cable that goes from the front control panel to the back ssb board, I would unplug and replug to make sure seated properly. Then try it again. There are alot of screws to take out but worth it if this solves the problem.
Jan 08, 2008 | RCA HD52W58 52" TV
Televison & Video Logo
150 people viewed this question
Jerry Greenberg
Jerry Greenberg
