Question about Dell Latitude D600 Notebook
Installed new hard drive get invalid system disk message will not boot now what
  • 3,940 Answers
With a new hard disk drive, 1st reset BIOS defaults, to ensure it is detecting the drives properly
Then boot to your windows Disc, (F12 to get boot menu) select boot to optical drive and press enter.
If the windows media is Dell Branded, then you should have no driver issues and the OS will be pre-activated. If Retail non-OEM windows, you will need to have the PID to register/activvate it
Posted on Oct 05, 2010
Invalid system disk
The computer TRIED and FAILED to boot from the hard-disk, and now is expecting you to insert a "bootable" CD-ROM into the optical drive. Replace the "dead" hard-disk.
Dec 01, 2013 | Compaq Computers & Internet
At boot-up I get "invalid
1) Go into your bios by pressing the Delete key.
2) Navigate to boot disk priority.
3) Set this to Primary master disk drive (The drive that your operating system is installed on.
4) The save and exit.
This should stop the message from coming up and solve your problem.
Please rate this solution by clicking on the thumbs up at the top right of this solution, it is much appreciated.
Thanks.
Nov 01, 2010 | ASUS A7V333 Motherboard
When my laptop boots up it says operating system not found
Not good. Check your bios for correct drive for boot up, but it sounds like yoru hard drive is not being read....
Oct 26, 2010 | Acer (ACERMOTHERBOARD)
Ibm deskstar model dtla-307015 invalid system
For some reason, the computer isn't able to read the hard drive and Windows isn't being found. If this computer has a floppy disk drive, make sure there's no disk in it. (Some people still use floppies, and the normal setting for systems with floppy drives is to try booting from that drive first. You may have a disk in it that isn't bootable.) Other possible causes are hard drive failure, a virus or other malware program has damaged the drives boot sector, or a motherboard problem. The most likely cause would be the hard drive; as a mechanical device they are more prone to fail than other parts.
Mar 08, 2010 | IBM NetVista M42 PC Desktop
IBM THINK PAD 390X LAP TOP INVALID SYSTEM DISK
check that you have no floppy disks in the drive and also no usb memory sticks/Hard drives plugged in as if they are and are not bootable you will get the error you describe
Dec 11, 2008 | IBM ThinkPad T40 2373 Notebook
Cd/dvd problem on toshiba m45-S165 laptop
Is you new hard drive lager than you old on and was the disk drive a factory replacement cause with those disks if you even change just that they will not work
Dec 09, 2008 | Toshiba Satellite A45-S250 Notebook
Trubleshoot Motherboard
More than 70% of all computer problems are related to cabling and connections. Ensure all cables are connected and connected firmly. IDE and floppy ribbon cables and power cables can often go loose. Ensure microprocessor, memory modules, and adapters such as video card are inserted correctly and didn't "pop-up" due to vibration.
System has no power at all. Power light does not illuminate, fan inside the power supply does not turn on, and indicator light on keyboard does not turn on. PROBABLE CAUSE DIAGNOSIS SOLUTION
Power cable is unplugged. Visually inspect power cable. Make sure power cable is securely plugged in.
Defective power cable. Visual inspection, try another cable. Replace cable.
Power supply failure. Power cable and wall socket are OK, but system is still dead. Contact technical support
Faulty wall outlet;circuit breaker or fuse blown. Plug device into socket know to work and test. Use different socket, repair outlet, reset circuit breaker or replace fuse.
System inoperative. Keyboard lights are on, power indicator lights are lit, and hard drive is spinning. PROBABLE CAUSE DIAGNOSIS SOLUTION
Expansion card is partially dislodged from expansion slot on the motherboard. Turn off computer. Take cover off system unit.
Check all expansion cards to ensure they are securely seated in slots. Using even pressure on both ends of the expansion card, press down firmly on expansion card.
Defective floppy disk drive or tape drive. Turn system off.
Disconnect the cables from one of the floppy drives. Turn on the system, check to see if the keyboard operates normally. Repeat until you have located defective unit. Contact Technical Support.
Defective expansion card. Turn computer off.
Remove an expansion card. Make sure expansion card is secure in expansion socket.
System does not boot from hard disk drive, can be booted from floppy disk drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
Connector between hard drive and system board unplugged. When attempting to run the FDISK utility described in the HARD DISK section of the manual you get a message, INVALID DRIVE SPECIFICATION. Check cable running form disk to disk controller on the board. Make sure both ends are securely plugged in; check the drive type in the Standard CMOS Setup (in your motherboard manual).
Damaged Hard Disk or Disk Controller. Format hard disk; if unable to do so, the hard disk may be defective. Contact Technical Support.
Hard Disk directory or FAT is scrambled. Run the FDISK program, format the hard drive(See HARD DRIVE section of manual). Copy your backup data back onto hard drive. Backing up the hard drive is extremely important. All Hard Disks are capable of breaking down at any time.
System only boots from Floppy Disk. Hard Disk can be read and applications can be used, but booting from Hard Disk is impossible. PROBABLE CAUSE DIAGNOSIS SOLUTION
Hard Disk boot program has been destroyed. A number of causes could be behind this. Back up data and applications files.
Reformat the Hard Drive as described in the Hard Drive section of the manual. Re-install applications and data using backup disks.
Error message reading "SECTOR NOT FOUND" or other error messages indication certain data is not allowed to be retrieved. PROBABLE CAUSE DIAGNOSIS SOLUTION
A number of causes could be behind this. Use a file by file backup instead of an image backup to backup the Hard Disk. Back up any salvageable data. Then do a low level format, partition, and high level format of the hard drive( see Hard Disk section of your manual for instructions). Re-install all saved data when completed.
Disk formatted on IBM PS/2 will not operate with this system. PROBABLE CAUSE DIAGNOSIS SOLUTION
The IBM PS/2 uses a different format than other computers. IBM PS/2 disk format will not work in an AT type computer. Format disk in the AT type computer insert disk into the IBM PS/2 and copy the files you wish.
After install an expansion card (network card, tape drive card, etc.) the system no longer works properly. PROBABLE CAUSE DIAGNOSIS SOLUTION
No power to monitor. All or part of the system may be inoperable. The new card may work but a mouse or COM port may not work. Change the interrupt or RAM address on the new expansion card. See the documentation that came with the new card in order to change pin settings. many expansion devices come with proprietary software that will assist you in doing this.
Screen message says "Invalid Configuration" or "CMOS Failure." PROBABLE CAUSE DIAGNOSIS SOLUTION
Incorrect information entered into the configuration (setup) program. Check the configuration program. Replace any incorrect information. Review system's equipment. Make sure correct information is in setup.
Screen is blank. PROBABLE CAUSE DIAGNOSIS SOLUTION
No power to monitor. Power connectors may be loose or not plugged in. Check the power connectors to monitor and to system. Make sure monitor is connected to display card, change I/O address on network card if applicable.
Monitor not connected to computer. See instructions above.
Network card I/O address conflict. See instructions above.
Problem PROBABLE CAUSE DIAGNOSIS SOLUTION
Memory problem, display card jumpers not set correctly. Reboot computer. Re-install memory, make sure that all memory modules are installed in correct sockets. Check jumper and switch settings on display card. See display card section for information of settings.
Computer virus. Use anti-virus programs (McAfee/PC-cillin, E-port, etc) to detect and clean viruses.
Screen goes blank periodically. PROBABLE CAUSE DIAGNOSIS SOLUTION
Screen saver is enabled. Disable screen saver.
Keyboard failure. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keyboard is disconnected. Reconnect keyboard. Check keys again, if no improvement, replace keyboard.
No color on screen. PROBABLE CAUSE DIAGNOSIS SOLUTION
Faulty Monitor. If possible, connect monitor to another system. If no color, replace monitor.
CMOS incorrectly set up. Call technical support.
Floppy drive lights stays on. PROBABLE CAUSE DIAGNOSIS SOLUTION
Floppy Drive cable not connected correctly. Reconnect floppy cable making sure PIN1 on the Floppy Drive corresponds with PIN1 on floppy cable connector.
Error reading drive A: PROBABLE CAUSE DIAGNOSIS SOLUTION
Bad floppy disk. Try new floppy disk.
Floppy disk not formatted Format floppy disk(type ENTER)
C: drive failure. PROBABLE CAUSE DIAGNOSIS SOLUTION
SETUP program does not have correct information. Boot from drive A: using DOS system disk. Input correct information to SETUP program.
Hard Drive cable not connected properly. Check Hard drive cable.
Cannot boot system after installing second hard drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
Master/Slave jumpers not set correctly. Set master /Slave jumpers correctly.
Hard Drives not compatible / different manufacturers. Run SETUP program and select correct drive types. Call drive manufactures for compatibility with other drives.
Missing operating system on hard drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
CMOS setup has been changed. Run setup and select correct drive type.
Certain keys do not function. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keys jammed or defective. Replace keyboard.
Keyboard is locked, no keys function. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keyboard is locked. Unlock keyboard
If a problem persists, please search for a solution or post a question in our tech support forum in our Help Desk.
Oct 19, 2008 | Computers & Internet
Disk boot failure, insert system disk and press enter
The drive should be set with jumpers or cable select to be primary master. Some pc & drive combinations don't like cable select, others insist on it. Try both, one at a time.
Jul 15, 2008 | Western Digital (WDXB1200BBRNN) 120 GB...
Consustently get "DISK BOOT FAILURE _ INSERT SYSTEM DISK AND PRESS ENTER" message
use xp sp2 bbootable disk and simply run a repair installation it should heal your system
Oct 17, 2007 | Mach Speed (MSNV-939) Motherboard
Media Test Failure, Check Cable.....
This is an Invalid / Non System Disk error.In your Bios settings change the "First boot device" option to your hard disk.If you have only one hard disk set it to "HDD 0"
Other causes of the problem are:
  1. Floppy or CD that is not bootable is currently in the computer.
  2. Hard disk's power or data cable is not connected properly(loose contact)
Oct 12, 2007 | Acer Aspire L310 (ASL310UD631A) PC...
Dell Latitude D600 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
