Question about Whirlpool GU2400XTP Built-in Dishwasher
Pump shaft leak wirlpool dishwasher DU8000XB-8. what parts are needed
5 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: GE Dishwasher Leaks
You can easily screw up the drain diverter arm trying to replace that seal. Repair is difficult. Pump assembly is rather expensive. (especially considering this was not a top of the line model) You would be much better off replacing the dishwasher. The new GE models are much quieter and have eliminated the center tower in almost all models.
Posted on Sep 02, 2008
SOURCE: GE 24in GSD980X Dishwasher water leak in pump &motor area
I had the same problem. There is no way of replacing seal/joint between pump and motor. It can't be taken apart w/o destroying parts, it only comes as an assembly. Costs around 130$ for pump/motor assy, so it might not be worth it.
Posted on Jun 12, 2009
  • 9 Answers
SOURCE: WIRLPOOL DISHWASHER COLD WATER CLEAN ONLY!!!
HI Nick- the element in the dishwasher dries the dishes and sometimes boosts the heat of the water. Your water should come in already hot, so the problem is either your hot water heater or that the plumbing line was switched to cold by mistake. Or that people are bathing, laundering, etc. and using all available hot water right before you run the dishwasher.
Posted on Sep 12, 2009
heatman101
  • 43501 Answers
SOURCE: Maytag dishwasher model # DWU7402AAB leaking
Here is the part and they will have instructions with the part.....
http://www.partselect.com/PartDetail.aspx?Inventory=2097154&SourceCode=12
You will have to remove the motor and it is possible that you will need more parts such as the pump and drain impellers as they will usually break when you try to remove them.
heatman101
Posted on Feb 21, 2011
What could be wrong with my dishwasher some times my dishwasher drains and some times it doesnt when not it leaks on my floor
it could be a weak pump (ie something is stopping its movement) some pumps are magnetic and anything that can get into the pump shaft can limit its movement, hair or long strands that have gotten past the filter can do this. as for leaking water this can be from the same problem or a seal is not connecting properly, locate the leak and remove and clean and refit, can use some water base sealer, even gasket seal will do, clean and dry the pipe inner and smear a bit on the area were the pipe fits or were the side meet on the area needing sealed. pump is in 3 parts case 1 case 2 with magneto. part 3 its the blade inside with magnetic shaft. disassemble case 1 and remove part 3 should not need to remove case 2. hope this helps
Nov 29, 2017 | Dishwashers
On fourth water pump could the shaft be the problem
do apressure test on the cooling system to determine where the leak is coming from
Aug 25, 2014 | Dishwashers
Dishwasher leaking from bottom
If you are sure this is not coming from the door, then it is probably leaking from the pump. The motor is outside the dishwasher and the pump is inside. The shaft of the motor has to turn the pump, so there is a seal that the motor shaft goes through. You might be able to replace just the seal, or maybe the whole pump or maybe the whole motor/seal/pump assembly. This can be fixed by a handyperson with some serious skills. Parts are available on-line. But it has to start with a pretty serious dis-assembly. The price you would pay to have this professionally fixed is up there comparable to a new cheap dishwasher. Good luck!
Nov 14, 2012 | Electrical Supplies
Magic Chef dishwasher leaking from the shaft hole attached to the drain solenoid, how do I get the shaft out to replace the seal that is bad and causing the leak?
on that shaft is a C clip on the inside of the pump asm. remove that clip and the shaft will come out,in the pump housing between that drain flapper and the solonoin is a seal i would give you the part number for that seal but the model number listed in your question uses a seperate drain pump and doesnt have that flapper/soloniod so please send correct model number and i'll get ya the seal part number.
Aug 17, 2011 | Magic Chef CDB1500AWS Built-in Dishwasher
Magic Chef DU55CA-01 unit runs but when pump kicks on for discharge cyle water leaks on the floor from the what appears to be the solenoid part. The leaking stops as soon as the pump turns off. What part...
Leaking from drain valve shaft seal. If you just replace the seal it may still leak. Replacing the pump is a lot of work and not really worth it to cure a small leak.
Jan 24, 2010 | Magic Chef 24 in. DU6550 Built-in...
Water leaks between motor and pump can't get motor off
hello there this may help you out ok
best regards michael
Leaking Pump in a Whirlpool DU810DWGQ1 Dishwasher by Samurai Appliance Repair Man
function ReferThisPage779b7841ed943a9e880964fef6da376b(){var rtp;rtp = window.open('http://www.tellafriendking.com/refer/?URL='+escape(document.URL)+'&CODE=779b7841ed943a9e880964fef6da376b&JS=1','_blank','width=350,height=530, resizable=yes, status=yes, scrollbars=yes');if((null==rtp)||'undefined'==typeof(rtp) ){alert( 'The \'tell a friend\' window was prevented from opening.\n\nPlease temporarily disable your popup blocker.');}rtp.focus();}document.write(""); rn-spa-g.gif document.write(""); 3548679745_8c188ff0d2_m.jpgLeaking Pump in a Whirlpool DU810DWGQ1 Dishwasher
These are cheesy, inexpensive dishwashers that are prone to leaky pumps, as shown here (click the pic for the larger, annotated view).
3548734637_17f81a0e1b_m.jpgWhirlpool DU810DWGQ1 Dishwasher Pump and Motor Diagram
The problem is usually a leaky shaft seal kit, shown here as Items 7 and 8 (click the pic for the larger, annotated view).
Fortunately, the shaft seal kit is inexpensive; but it can be a ****** to install, depending on how much rust you’re dealing with. May require a destructive removal of the impeller, too, but ain’t no thang ‘cuz the shaft seal kit comes with a new impeller. Here’s a nice, purdy picture of a brand new shaft seal kit. And just to help motivate you a little more, the money you save from replacing just the shaft seal vs. replacing the entire motor-pump assembly is well over a Benjamin. So you go ahead and drill, cut, and chisel all you want on that old impeller!
wpl-dw-horiz-pump-shaft-seal-kit.jpg And Whirlpool just came out with a spiffy new DIY repair manual for this dishwasher, which will assist you mightily in the many repair adventures you are certain to have with this dishwasher:
whirlpool-dw-diy-manual.jpg To learn more about your dishwasher, or to order parts, click here.
Sep 14, 2009 | Kenmore Dishwashers
Nov 22, 2008 | GE 24 in. GSD980X Built-in Dishwasher
Oct 07, 2008 | Whirlpool DU912 Dishwasher
GE Dishwasher Leaks
Sep 02, 2008 | Dishwashers
Whirlpool GU2400XTP Built-in Dishwasher Logo
59 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
