I am working on an HP 4700, Its been printing perfectly for two years. Now its giving a grayish background on all the color prints. The DV color units are constantly changed and are in good shape. whats causing this shading in this machine and how can i resolve this? Thanks
  • 4,737 Answers
There are several possibilities. First the drum's waste ink tank overflown or the cartridge issue, or the fuser not reaching the optimum temperature, or the transfer kit.
First, remove the drum and disassemble it, you'll see a small opening (close with a plastic cap), open it and remove all the Toner in it. You should handle the drum very carefully, and don't ever touch the drum bar. After it's removed, try printing again.
If this doesn't improve the print quality, turn off the machine and remove the fuser unit (it should be located on the back side of the machine), look inside the unit very carefully and clean it with a very soft brush. After it's cleaned and cleared, reinstall it, then try again.
It's also important to clean all the passage, to do this, first open the front tray, remove the drum and the fuser, take a blower (air can) or a vacuum cleaner and clean the passage with whatever you can.
Now reinstall everything and try again.
If the problem persists, you can try reinstalling the printer's driver with the current/latest updated drivers.
Let me know if you have problem.
Good luck.
Thanks for using FixYa.
Posted on Oct 05, 2010
  • Lebanon Raingam
    Lebanon Raingam Oct 05, 2010
    Here's an instruction/tutorial on how to disassemble the Drum Unit.. (click here).
HP 4700 how to remove Purple Lines and dust
Defects in print are most often caused by a bad print cartridge and based on the color you mention I would look closely at the Magenta cartridge. You can clean the dust out with a lint free cloth, a swifter type dirt magent cloth works the best.
May 26, 2015 | HP Office Equipment & Supplies
Hp color laserjet 4700 will not print in color
do self test - configuration print, if ok check your print driver settings
Jun 02, 2014 | HP LaserJet 4700 Printer
Only momo print is comming
run self test, if ok, check print driver settings
Aug 29, 2013 | HP LaserJet 4700 Printer
I have a HP LJ 4700 printer set up to a network. It will print black but not colour
1. Go to menu set as default.
2. Do color calibration.
3. Print PQ test pages, observe the colors, chk
4. Print demo page. chk
5. Print from different file/system..
Nov 28, 2012 | HP LaserJet 4700 Printer
Need only black to print from HP Color Laserjet 4700 printer
on the print page just before printing , go to properties and make black the default color
Jun 04, 2017 | Office Equipment & Supplies
HP 4700 not printing cyan
If your printer is missing a color it could be caused by (off the top of my head) 3 possibilities.
1. High voltage board
2. laser/scanner assembly for that color
3. DC controller might need a firmware upgrade, www.hp.com
Run the PQ diagnostics, check the cyan color
Run the Cartridge Disable diagnostic. Remove all cartridges and take the black cartridge and insert it where the cyan normally is. If the black prints in the cyan slot, your cyan cartridges are bad. If the black doesn't work then go to #3 above. It won't cost any money to upgrade the firmware. If it still doesn't work call in a printer tech.
At this point you may need a printer tech.
Nov 01, 2011 | HP LaserJet 4700 Printer
I have a HP OFFICEJET 6000 WIRELESS PRINTER AND I JUST PUT A NEW BLACK CARTRIDGE IN LIKE A MONTH AGO AND YESTERDAY I PUT IN BRAND NEW "MAGENTA,BLUE AND YELLOW IN I PRINTED ONE PAPER PERFECT ALL THE...
Check ink levels, if showing full go to the printer properties, printing preferrencess,servicess, nozzle clean,..after cleaning the nozzles check print quality..
Sep 08, 2011 | HP LaserJet 4700 Printer
Colors problem
sounds like it could be the head alignment ??
Apr 24, 2009 | HP LaserJet 4700 Printer
Laser Printer Cleaning
Does the dirty background get lighter as you print additional pages? Have you tried a new cartridge yet? Unless your toner cartridge is leaking toner (you?ll see toner on the inside of the printer or leaking out if you remove the cartridge and shake) a simple cleaning is probably not the answer. Let me know and we'll pick up later.
Feb 28, 2007 | HP LaserJet 4100n Printer
41 people viewed this question
k24674
jasbo
jasbo
