Question about Cameras
Battery won't fully charge at all. Low battery.
  • 98 Answers
Battery may needs replacement.
Advice - It is good to recharge a battery when it is fully drained. And also charging should happen untill the battry is fully charged.
This method gives a battery a long life time.
Posted on Oct 05, 2010
What cause the car want start even if u jump it it just cleick
Start with the basics, here. Check that battery cables are not loose and are CLEAN, on the battery AND the starter. Beyond that, check the battery charge with a volt meter. Fully charged should be 12.5 volts or higher, you will lose starter spin at 10 volts. If the battery is low, hook it up to a charger and charge it up completely. If you don\'t have a voltmeter, go to the store and buy one. If you\'re going to try and fix things like this, you have to have one. If you can\'t do that, remove the battery and take it to someplace like AutoZone. They will charge and test the battery for free. If you can\'t take the battery out, or don\'t have a friend that can, have the car towed to your mechanic.
Here\'s the thing- I can\'t tell you exactly why, but some cars you just can\'t jump start. Happens more on side mount post type batteries. Because you can\'t jump your car doesn\'t mean it won\'t start with a fully charged battery. Now there are other things that could be wrong with you car, that it won\'t crank over and start for you.....but we begin the diagnosis with the battery.
Mar 17, 2014 | 1993 Oldsmobile Eighty Eight
Battery will not charge
li-Ion batteries have a bad habit: whenever fully depleted, they lose a few cells, to the extent that they might not be able to hold a full charge if enough cells are damaged. In other words, repeatedly using a laptop (or any other Li-Ion powered device) to battery depletion can shorten the battery's life significantly. You might want to keep the batteries fully charged whenever possible and avoid fully depleting them too often.
There is also the habit of "re-setting" the batteries by using the "fully deplete-fully charge" procedure. It only applies to niMH or NiCD batteries ( and is used to erase the "memory effect" ) but is damaging to Li-Ion batteries for the reason mentioned above.
so if your battery can not full charge,this mean you need change a new battery for your laptop
http://www.aulaptopbattery.com.au
Oct 05, 2012 | Computers & Internet
Lg gd850 low battery when powering up the phone
Please try fully charging it. If it still won't work, it's time for a new battery.
Sep 03, 2012 | LG Cell Phones
My Nikon Coolpix S2550 says the battery is low when I need to use the flash - but I have fully charged the battery please help
try leaving the camera on to drain the battery down, then try charging it again.. or could be a bad battery
Dec 30, 2011 | Nikon Cameras
Battery won't charge
connect the charger to the socket, then connect the charger to your laptop. if it does not charge remove it for 5mins, connect the charger back. it will work now. sometimes when the battery is fully charged and you remove the charger and connect it back it may not charge until the battery is low;lets say 99%.
Sep 23, 2011 | Advent 4211c Notebook
My coby 705 is very fast to low battery what even if it is fully charge, what should i do?
If the MP3 player battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Sep 09, 2011 | Coby MP-705 Digital Media Player
My philips gogear 4g is pluged in and works but when i unplug it it says low battery and shuts off immediatly it has been left on for 4 hours now trying to fully charge it will not charge is the battery...
If the media player battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 26, 2011 | Philips GoGear ViBE Digital Media Player
My dewalt 18v xrp battery wont take a charge
Depending on how old or more to the point how many times you have already charged the battery, it may be worn out. All rechargeable batteries do reach a point where they won't charge up anymore. If you have fully discharged the battery and tried to fully charge it up again and it won't take a charge or only lasts a few minutes on a charge it may be time to recycle it and buy a new one.
Aug 22, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Sir, my phone is Samsung gts5233w. Since a week it has got some problem with its battery.The battery gets low after 1 day,when it is fully charged.also i cant find "POWER SAVING MODE" in my...
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jul 24, 2011 | Samsung Star GT-S5233 Cell Phone
My laptop wont charge.when its running low at 10% i plug in my battery adapter it says its plugged in but not charging. I can only use it when my adapter is plugged in and i've left my computer sit shut...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
May 02, 2011 | Computers & Internet
Cameras Logo
109 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
