My Whirlpool Duet (WFW8300SW02) has started making a bad bearing type noise when spinning and not it will not spin the drum with heavy wet loads. The drum is very loose inside. It will spin when empty but not with any type of heavy load. Can you tell me what that would be and what I need to do to repair it? Thanks
gittos73
  • 244 Answers
SOURCE: Replacing the fins on Duet whirlpool washer
most paddles are removed by grabbing hold of the paddle and pull towards the front of the washer which should release them youll need to lift it out when you have pulled on them love
Posted on Sep 12, 2007
Krazytech
  • 725 Answers
SOURCE: New Whirlpool Duet Washer(WFW9300VU02) F28 error
You can call whirlpool for service but the tech sheet f28 has a communication problem from you computer to the motor..
The communication between the Central Control Unit (CCU) and
the Motor Control Unit (MCU) cannot be sent correctly.
Possible Causes/Procedure
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
Check connections of the CCU board within the housing.
Make sure all grounding switches are engaged.
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic Test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing
the MCU connectors.
Posted on Sep 21, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool front load washer, Clicking noise during spin cycle
i would open the door nad with your hand (glove on if preferred), feel around the intereior of drom for prhaps a nails, or hair clip that has gotten caught in one of the many holes in tub
Posted on Dec 21, 2008
SOURCE: How to replace a Hotpoint Aquarius+ WF740 drum bearing?
I had the same problem and it turned out to be the ballast securing bolts had sheared off and the back of the drum had to be replaced
Posted on Dec 24, 2008
SOURCE: Eurotech front loading washer, noisy on spin cycle with load.
My eurotech washer has an inner and outer stainless steel drum. The inner drum is supported in the back by cast aluminum supports. (like many other models). The cast aluminum carodes and weakens and breaks. You may find pices of this in the strainer. Not hard to replace and not expensive but very difficult to get the part. Eurotech has been out of the part for months.
Posted on Mar 30, 2009
Loud noises during spin cycle. Drum is eating up. All springs and shocks appear to be ok
The water seal has worn out and water has gotten into the bearings. You need to call a service tech to have it repaired. It is not a cheap repair. Whirlpool has a repair that replaces the back half of outer tub and a new inner tub or basket one in the same. Another salution is replace the seal and bearings, still a lot of labor. go to utube and a guy does to an LG, but the the repair is about the same for a Duet
Aug 08, 2014 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet makes an awful banging noise when a load of laundry is in the spin cycle. It is completely level and I cannot figure it out.
reach inside drum that turns and try to move it up and down. If there is any movement the spider at the rear of the drum is broken. Will need inner drum and outer rear tub with bearing and seal.
Nov 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is the best way to quiet machine during spin cycle?
if the washer is very noisy in spin mode its likely the drum bearings have worn out,,,try this out first
open the washer door and get hole of the drum at the top ,,now lift it up a little if there is a lot of lift and it drop with a knock when you let it go this is the bearings worn out,,also spin the inner drum with your hand if it makes a grumbling noise its bearings
Aug 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer is making an awful noise and it wont spin like it suppose to what is wrong
your inner drum bearing lip-seal has gone bad and the inner drum bearings are now water soaked and rusted and need replacement,parts are cheap,but depending how long it takes to remove and clean the bearing races and time/labor you will need to check on in your area
Apr 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sounds like a Harley when it spins, still spins though.
If you get a very loud noise coming from the machine, and this noise is louder when it spins faster, then it is not a Harley inside your washer, it is the drum bearing.
The drum bearing is bad, probably drum bearing spider had broken.
On a front load the drum bearing is located at the back of the drum.
To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
You can find parts and diagrams for most models here.
Nov 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer...after problem with it getting out of balance due to not draining and trying to spin with a heavy load, I have since noticed if I place my hand inside the tub..it will spin freely...
Your original problem is likely to have damaged the bearings and the spin tub shaft... the shocks can fail, but that would not affect the fitment of the shaft and bearings.
Apr 21, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement bearings...you'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Load Washing Machine is very Noisy when spin
if it make noise like a train coming in on track,,,bad tub bearing,,,do you see any water leaks back there ..on the back tub or on the base of unit...if so seal damage,,
Dec 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Rattling noise during high speed spin
sounds as if you might have a bad rear bearing, real obnoxious almost painful to listen too kinda sounds. big job, but might have some part warrentee depending on age of unit
Oct 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Loud Noise during spin cycle
drum bearings are gone,it would cost too much to repair,the drum shaft would to be repalced as well.Sorry
Dec 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
