Question about Sony Playstation 3 (PS3) Console
IIt won't come all the way on it is showing a yellow light
    President:
  • 1,139 Answers
Sadly this is usually a sign of the Yellow Light Of Death (YLOD). When the PS3 was originally made Sony used lead free solder in their consoles. Lead free solder is not as flexible as normal leaded solder and over time due to expansion and contraction because of heat given off by the console's components lots of PS3's failed. You have got a couple of options, you can either have the console professionally repaired which is going to cost around £50. If the console is out of warranty Sony will only replace it for a cost of around £130. As a last resort if you are good with electrical items you might want to have a go at repairing it yourself. If you google YLOD you will find plenty of guides that will instruct you on how you can repair it yourself.
Please bear in mind that once a console has the YLOD there is NO guarantee as to how long a repair will last, it could be a couple of hours to a couple of years.
I hope this information helps you and I hope you get your PS3 up and running soon.
Posted on Nov 27, 2010
Binoculars power on, then immediately off NIGHT OWL OPTICS NIGHT VISION BINOCULARS NOXB5
Hello there. Are you pointing your NV binoculars at bright light, if so, please stop. Therefore, if you are not then possibly the iit (image intensifier tube) is bad, or the auto shut-off is also shorted. Night Owl Optics are in El Paso, TX. Call Night Owl up, they won't tell how to fix it. But they will tell where to send it. "It is proporitary" which mean, they are the one to fix it. Sorry, stewbison.
Jul 10, 2011 | Night Owl Optics Optics
How do I determine what model number my Intermatic timer is?
The timer enclosure is plastic and reads part number 2T2921A. The label under the enclosure part number faded and is illegible. IIt ods have a yellow dial. I checked both units at the HW store and they are identical to me. The wiring diagrams on the Intermatic side are also identical. I need to determiine somehow if mine is 220 or 120V. Thanks.
Nov 02, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
It blows very cold air when you stop,heats when you are going. 2005 Nissan Altima
look under your rear side cubby there should be some wires take the black ones with the yellow but it together and iit will be fixed or take it to the shop DUHHHH
Oct 11, 2009 | 2002 Nissan Altima
The top burners work but the oven is not heating up
Hello, This is going to be a problem with your igniter/glow bar. Over time these get old and although you may see it glowing iit still may be bad. Your igniter should glow a brillient yellow and should ignite the gas within 15 seconds of the valve opening.
here is a link showing pictures of typical igniters.
http://images.google.com/images?hl=en&q=ge%20oven%20ignitor&um=1&ie=UTF-8&sa=N&tab=wi
If you have any other questions or concerns please feel free to comment again...Good Luck! Mike
Aug 24, 2009 | Amana Kitchen Ranges
My stove does not light. THe brolier and the burners work fine
Aug 18, 2009 | GE JGRP17 Gas Single Oven
We have a National Little Tikes Hummer 2 model 451K. Where can I get replacement tires for this model?
IIt took a while to find the parts, but I asked the guys at
http://www.shopjandl.com/
They had the parts and also helped me with my repairs.
Hope this helps
Jul 15, 2009 | National Little Tikes Hummer Yellow
I have the 55" phillps rear projection tv
Common problem with this model. Goto www.TvRepairKits.com to get their chirping TV repair kit.
Feb 24, 2009 | Philips 55PW9363 55" Rear Projection...
My mp4 wont turn on iiGHT,W3LL iiT WAS W0RKiNG AT FiRSST AR3 WAT3V3R BUT 1 DAY iiT JUSS Di3D 0UT TH3N iiT W0ULNT CHARG3. nD N0W iiT W0N'T 3V3N TURN 0N. (SADD GURL) BbY**
first you should have a working computer.then you should hold the middle for bout 3 sec. then if it won't turn on then it's probaly not charged.
Jan 20, 2009 | Philips GOGEAR SA6045 MP3 Player
My Xerox cpoier # 604P1837 is showing FaultCode # 062-380 How do I clear it & what does it mean?
I would think you could fix it by turning the machine off , disconnecting all the cables from the scanner and document feeder, then reconnecting them tightly. Turn back on, If not here is the info on the fault.
At the adjustment of CCD output after power on, CCD does not make a correct output which it should when it receives a specified amount of light.
arrwup.gifInitial Action
  • Refer to BSD 6.3.
  • Power OFF/ON
arrwup.gifProcedure Check the lamp, lens, mirror and the white correcting plate for abnormalities such as contamination and deterioration.
Abnormality such as contamination or deterioration of the lamp, lens, mirror or the white correcting plate is found. Yes No Unanswered
Replace the lamp, lens, mirror or the white correcting plate.
Execute Component Control[062-002 IIT Exposure Lamp].
The Exposure Lamp ( PL 11.6) lights up. Yes No Unanswered
Check the connections of P/J703, P/J702 and P/J723.
P/J703, P/J702 and P/J723 are connected correctly. Yes No Unanswered
Connect P/J703, P/J702 and P/J723.
Check the wire between J702 and J723 for an open circuit or a short circuit (BSD 6.3 Flag 4).
The wire between J702 and J723 is conducting without an open circuit or a short circuit. Yes No Unanswered
Replace the Lamp Wire Harness ( PL 11.6).
Measure the voltage between the IIT/IPS PWB ( PL 11.3) P723-1 (+) and GND (-), and between P723-2 (+) and GND (-) (BSD 6.3 Flag 4).
The voltage is approx. +24VDC. Yes No Unanswered
Replace the IIT/IPS PWB ( PL 11.3).
Replace the Exposure Lamp ( PL 11.6). If the problem persists, replace the Lamp Ballast PWB ( PL 11.6). if the problem persists, replace the IIT/IPS PWB ( PL 11.3).
Check the connections of P/J700 and P/J710.
P/J700 and P/J710 are connected correctly. Yes No Unanswered
Connect P/J700 and P/J710.
Replace the CCD PWB ( PL 11.4). If the problem persists, replace the IIT/IPS PWB ( PL 11.3).
Apr 23, 2008 | Xerox WorkCentre M123 Copier
Sony Playstation 3 (PS3) Console Logo
14 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
