Question about Vacuums
Thread brakes sometimes it stops i think the trhead is not being led correctly since a little peace of metal looking like a clip or hook came off
  • 6 more comments
  • nettunoninfa Oct 05, 2010
    hi
    the brand is BROTHER model INNO-VIS 750e
    tx
    i need to solve my problem sooner
    any news
    not at all tx for coming back to me
    tim
    is there any way for me to have u back
    g
    rather than breaking it seem to have slipped off i m tring to find it no luck so far but do u have ani idea on how to get around the prob without having to service it
    love
    gianni
    i ll start looking for it now
    would u let me know about the second option cause i m going mad since 2 days now but sdtill cant find it
    love
    President:
  • 2,777 Answers
Hmm ok I can help you with this but need to know the make and model of the unit in question.
Thanks Tim
Posted on Oct 05, 2010
  • 7 more comments
  • Tim Grayson
    Tim Grayson Oct 05, 2010
    Ok I will check into this, please give me a little bit here, if I don't get back tonight it will be first thing in the morning (before 6 am pacific). Please don't respond until I have posted another comment here or it may knock me off the "job" and assign someone else.
    Thanks
    Tim
  • Tim Grayson
    Ook, did you get it solved then?
  • Tim Grayson
    Actually I can no longer help since you already rejected my solution.
    Thanks
    Tim
  • Tim Grayson
    Oh wow I didnt think that was possible, ok looks like you have me back, let me see here, will add another comment in just a moment.
    Tim
  • Tim Grayson
    Ok yes that clip looks like the problem for sure... did it brake off? If so you may need to get it serviced to get it back to working order..
    Tim
  • Tim Grayson
    Oh wow, so you don't even have the part that slipped off? Yikes, let me keep looking into this here :( but I think you will at least need that little part..
    Tim
  • Tim Grayson
    Ok sounds good, let me know if you can find it!
    Thanks
    Tim
  • Tim Grayson
    Also it's possible I can help you get a replacement little piece if need be..
    Tim
  • Tim Grayson
    Oh wow I just realized you must be in England or thereabouts.... In that case it is going to be much easier for you to get the part directly from Brother UK, give them a call at 0845 4309824 and they can definitely get you this piece, or may actually know right over the phone how you can circumvent it...
    In the mean time I am still checking, but give them a call and see what they say. I think they should definitely be open right now still.
    Tim
Royal Series, Necchi, Model # 80331763 bobbin does not take up thread properly. No manual unsure if i am threading it correctly.
You can get Necchi instruction manual from Necchi website: http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Sewing_Machines.htm". Makesure the needle is in the machine correctly- all the way up into the needlebar, make sure that it is threaded correctly, etc. If this all checks out ok,take the bobbin case out of the machine. There are two ears on either side ofthe bobbin case- turn the left one to the left and the right one to the right.Remove the silver ring, and inspect the piece of metal that the ring came off of(looks like a circle with the top cut off). You have to locate the hook whichis the piece that looks like a half moon inside the big round metal piece.Locate the tip of it, turn the hand wheel toward you until the needle is in thelowest position, at this point the tip of the hook should be flush with top ofthe left side of the cut off circle. Checkwhether underneath thread is looping on the fabric. If so then you've mis-threadedthe top, probably haven't raised the presser foot when threading so you can getthe upper thread into the tension. You need to thread the upper part with thepresser foot up. (You can put it down to thread the needle.)
Not picking up thread can be several issues, like bobbin is miswound, bobbincase isn't snapped in properly, you're using the wrong type bobbin, machine isout of time, needle is bent or burred, machine is dirty and in need of dustbunny eviction and a little oil but most of the time the issue is once againmisthreading: sewing machine needles have a front and a back and they have tobe placed in the needle holder correctly. In that case your manual is needed, take all the thread offthe machine (yes, spool off the spool pin, bobbin out of the bobbin case), pullthe needle plate and clean your machine thoroughly, using brush and vacuum (notcompressed air) and oiling per the instruction manual. Put it all backtogether, putting in a 80/12 needle, correctly oriented. Hang on to theneedle thread when you fetch up the bobbin thread.
Each and every seam you start is going to be done this way:
1) Pull the tail of the top and bobbin thread behind the presser foot
2) Put the work under the needle and use the hand wheel to lower the needleinto the work
3) Drop the presser foot
4) Holding the thread tails behind the foot, take a couple of stitches.
5) Drop the thread tails and sew normally. Hope this will help you. Good Luck.
Sep 12, 2011 | Vacuums
Wife has Kenmore 385.12314. Regular use. Normally cleaned and oiled. Needle goes down, but bobbin thread doesn't catch. Needle at bottom of stroke and "half moon" is on top, needle...
Make sure the needle is in the machine correctly- all theway up into the needle bar, make sure that it is threaded correctly, etc. Ifthis all checks out ok, take the bobbin case out of the machine. There are twoears on either side of the bobbin case- turn the left one to the left and theright one to the right. Remove the silver ring, and inspect the piece of metalthat the ring came off of (looks like a circle with the top cut off). You haveto locate the hook which is the piece that looks like a half moon inside thebig round metal piece. Locate the tip of it, turn the hand wheel toward youuntil the needle is in the lowest position, at this point the tip of the hookshould be flush with top of the left side of the cut off circle. If this is notso, your machine needs to be re-timed. If that is the case, I would need to seea picture of the bottom of the machine so that I am able to determine whatneeds adjusting. Make sure you're turning the hand wheel in the proper direction-- the proper direction isthe one that will feed fabric forward under the presser foot.
Make sure the needle is facing in the correct direction -- stitches don't form,or skip badly when the needle is turned around.
Put the bobbin in the bobbin case (right way around) leaving a 2-3" tail.
Thread the top of the machine correctly, leaving a 3-4" tail afterthreading the needle.
Hang on to the end of the upper thread, and use the hand wheel to drop theneedle... continue to turn the hand wheel to raise the needle. Pull on the endof the needle thread and a loop of bobbin thread should come up.
Hold BOTH threads behind the presser foot when starting a seam to preventthread jams.
Aug 17, 2011 | Vacuums
I have needles snapping and bobbin tangle
Try to repair in this order.
1) Your machine likely needs oil. Especially put a few drops of oil on the outside edge of your bobbin holder.
2) Try replacing your needle if you have some spares. If you are using a decorative thread (metalized) use a needle with a teflon lining on the eye (called metallic thread needle).
3) Try buying a better quality thread. Do not use generic thread in a sewing machine (i.e. "made in cheap country" with no brand name)
Please rate me..
May 04, 2011 | Vacuums
My Kenmore sewing machine timing has gotten off. I am sewing a big upholstery project and it starting bunching thread from the bobbin. The thread is so heavy that I had to put some pressure just to get...
Hello
Disassemble your bobbin case which is realy quite easy, clean thoroughly with a brush and air, paying particular attention to any rust that may have formed, and any thread that may have weazeled it's way into small but very incremental areas of your case.
Make sure your needle is not in backwards.The rounded side should be on the outside
. If threading is correct and your tension is properly adjusted , then check the hook for scratches. If you have ever hit the hook with a needle, it will be scarred and will catch the thread every time the upper thread passes around the bobbin case. the hook is the sharp point on the shuttle that holds the bobbin case. If it is scratched, polish it smooth with VERY fine sand paper
Make sure that your thread arm that rises and falls, constantly having tension running through it and that it is in fact staying in place.
Alternate between the metal and plastic bobbins - sometimes the plastic bobbins tend to chip
Dec 04, 2010 | Kenmore Vacuums
I keep replacing the belt and keeps melting and breaks. what do i need to do? everything else is working, the little piece of metal that hooks on the belt gets too hot and melt the belt
i think your talking about the motor spindel,,(the little metal bit?) if the motor is that hot its going to burn out soon, check that the brush is free to turn if its tight free it off its full of grit or fluff also check that the motor turns freely
Dec 02, 2010 | Dirt Devil M084600 Dynamite Bagless...
I have a brother project runway limited edition sewing machine and there is a constant jam with the bobbin threading and I have cleaned it,removed the sewing plate and everything I can possibly think of....
Hi
The usual cause is that there is a problem with the upper threads, often it is not caught in the tension discs. When you thread the machine, make sure that the presser foot is raised - this causes the tension discs to open so the thread can seat itself properly.
Another possibility is that the thread isn't in the take up lever - the hook thingy that goes up and down. Sometimes the thread will just slip out.
Thanks
Aug 05, 2010 | Vacuums
Sewing machine won't pick up bobbin thread
open the bobbin case and see if the hook is turning, if it is it is just a timing problem with the hook and needle, if it isn't tuning you may have a broken gear or timing belt.....It eill need to be looked at or adj by someone who repairs them....Daniel
Jan 05, 2009 | Vacuums
Replacing leaf spring Hoover wheels
If people are still having this problem, please post here and I will take a picture of the correct placement for the metal clip.
Apr 07, 2008 | Hoover U5227-930 Elite Upright Vacuum
I robot discovery
I have takin several Roombas apart with this problem. Basically the sensors on the bumber are blocked so the roomba thinks it is hitting something. I believe this is a design problem because it is so common. If you could see how the bumbers work, there is an infrared sending unit and an infrared receiving unit (they look like little LED's. when the bumper is pressed, a plastic piece moves between the two infrared led's blocking the transmission. This signals roomba to stop and backup. What happens over time is the sending led thing gets dislodged and moves slightly. The receiving led can't sense the signal so it thinks the bumper is depressed.
Hard to explain, but I have fixed the problem by shimming the led back in place and worst case, I drilled the hole in the plastic piece a little larger. Solved the problem and I have recaimed several roombas that were considered scrap. Irobot should fess up to this known problem and issue a fix for everyone of the defective units.
Jan 16, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
