Question about Roadmaster (VR500CSBT)
I have a new aftermarket deck but when I hook it up and all wires are hooked up correctly but my deck is not lighting up.My dimmer and illumination isnt hooked up and also my inside lights arent coming on in the car unless I open the door.Help anyone!Thanks
    Problem Solver:
  • 4 Answers
Make sure the remote wire which is usually blue with a white stripe is hooked up correctly and if you have a newer vehicle make sure you have to correct wiring harness
Posted on Oct 05, 2010
New stereo won't light up in 97 ford taurus gl,were is the illumination wire
You leave lots of questions: Is the stereo new, if so is it a stock replacement or aftermarket, if not how old is it? Most easy way to find the wire is look for one of the smaller diameter wires, should be blue or yellow, but can be any color. Find a power feed from the battery (12 volt supply), hook up the deck and case grounds to a good ground, and touch the smaller diameter wires one at a time to your live supply wire while checking for light.
Dec 11, 2013 | 1997 Ford Taurus
2001 Civic dimmer not working
It's not high and low beam, it's the dash lights that are dim. I've hooked up many aftermarket radios but never knew it was a no no to hook up the dimmer/illumination orange wires in a '01 civic. I googled it and seen many others with similar issues like mine but nothing exactly like the issue I have.
All the dash lights work, they are dim though. The radio lights work but they are even more dim than the rest of the dash lights. I have check every single fuse under the dash and in the engine bay. The dim controller does not work at all now. I'm guessing that's the issue and from what I read, the dimmers circuit board is in the instrument cluster. Some can fix it, others can't.
I will probably end up buying a used instrument cluster off of ebay, they are not expensive. Hopefully that fixes it since everything else works.
Oh, yes, the brake lights work.
Ted, I think you answered the wrong question...I mentioned nothing about the battery or the low/hi beams
Aug 13, 2012 | 2001 Honda Civic
Cant find out wat color wire to hook up dimmer and illumination wires. when u turn on head lights, the radio comes on
here is the wiring
Constant 12V+White/Green Switched 12V+ White/Red Ground Black Illumination n/a Dimmer Red/Black Antenna Glass Front Speakers 6 1/2" Doors Left Front (+) Blue/Green Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 6" x 9" Rear Deck Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White
Jul 03, 2011 | 1998 Honda Accord
I hooked up an after market stereo and now my speedometer lights don't work. Know why? On my 01 echo.
the bulb could have been bad, yet the aftermarket stereo wiring takes voltage from your dash, hence the illumination/dimmer. really dont need those wires. they hook up to your dash lighting, and draw power from your dash, take those wires out and see if any changes. Id first take the wires out, if no change then the bulbs are probably bad.
Jun 08, 2011 | 2001 Toyota Echo
I replaced the stock radio with an aftermarket one and my tail lights and dash lights dont work now
Most likely you got the illumination wire for the stock radio grounded. The stock radio has lights in it that are connected to the dash lights to illuminate the dials of the radio. Most aftermarket stereos don't have a hook up for that. The wire may have got hooked up to ground. I would check the fuse to see if it's bad. Also you might want to undo the new stereo, replace the fuse, if it's bad, and check the wires for battery when the headlights are on.
Mar 13, 2010 | 1999 Nissan Frontier
I have a 1997 chevy lumina and i'm putting in a new radio but the wires are not hooked up to the old one and i need to find out how to hook up the new one correctly. where can i get the wiring diagram for...
1997 Chevrolet Lumina Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Orange
Radio Ignition Switched 12V+ Wire: Yellow
Radio Ground Wire: Black/White
Radio Illumination Wire: Gray/Black
Radio Dimmer Wire: Brown/White
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5 1/4′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6′ x 9′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Jan 09, 2010 | Car Audio & Video
Installed new CD deck in 07 Corolla, may have shorted something
first check the illumation fuse which to toyota its the panel fuse, check if it is blown. if not take the aftermarket wire harness u wired in with the radio harness and disconnect the orange wire (illumation wire) and see if u have lights again. sometimes the aftermarket orange wire won't work with toyota vehicles. good luck
Jun 25, 2009 | 2007 Toyota Corolla
Dash Instrument Panel Lights are dead - gauges work fine
do you have taillights? most of the time there on the same fuse. also chk. to see if plug is all the way in on your headlight switch.
Jan 21, 2009 | 1993 Buick Park Avenue
Illumination v. Dimmer
Good day,
The illum wire goes directly to the headlight switch and tells it when to light up, where as the dimmer wire is variable meaning it would dim up or down with your dash light control. Dimmmer is usually only need on factory radio's and not aftermarket. I suggest wiring only to the illuum lead and do not connect dim. Also about the clock make sure your red and yellow wires are not crossed, yellow is a constant hot and red is only hot when the ignition is on, so if they are backwards the radio would loose it's memory when you turn the key off.
Hope this helps
Mar 12, 2008 | Kenwood KDC-MP435U CD Player
Roadmaster (VR500CSBT) Logo
94 people viewed this question
Top Roadmaster Car Audio & Video Experts
xxxxxx xxx
Are you a Roadmaster Car Audio and Video Expert? Answer questions, earn points and help others
