Question about Car Audio & Video
Eed to know how to hook up a 12" audiobahn awc 12t 500w sub to my 600w amp w/o frying my amp or sub.... a pic or diagram would be nice
colin324
  • 57 Answers
SOURCE: 2 12" Hitron 600w subs in a BandPass box
Remember that driving a load with an underpowered amp will probably cause more problems than having a more powerful amp that is not running flat out. 200-300W amp would be ok, but I would suggest going for the biggest you can afford. If you crank up the volume on the smaller amp you will probably get a fair amount of distortion, which may actually damage the speakers. A larger amp will not give as much distortion for the same loudness/volume and give better control of the speakers for a tighter bass..
Posted on Nov 21, 2007
  • 45 Answers
SOURCE: unsureness of wiring configurations.
Also- get a voltmeter to check the ohms on your speakers before hooking them up. If you want extra power, and your amp can handle it, you can wire the subs down or in parallel. This is where the voltmeter is needed. check your amps rating and match it closely. For instance if your amp can handle 2ohms mono. You would wire two (single voice coil) 4ohm subs in parallel, and connect that to the amp. But if you have dual voice coil subs you will need to wire the subs differently. For dual 2ohm subs each sub would first be wired (with a thick speaker wire). Take one positive pole on the sub and wire it to the negitive pole of the opposite voice coil. Which should leave a positive from one voice coil and a negitive from the other. With a dual 2ohm subs you will see 4ohms, and with dual 4ohm subs you will see 8ohms and so on. Once you have one sub done you need wire the two subs together and use the same procedure (as if each sub is a voice coil) to determine the overall load on the amp. Your amps Ohm rating will determine which way to wire your subs. Example- If you have dual 4ohm voice coils and your amp will handle a mono 1ohm load. It will put out much more power at 1ohm than if you wired them to a 8ohm load. In fact the power output is determined by resistance (ohms). Except a few amps like JL Audio, most amps will follw this rule. A 100 watt amp that is rated at 100 watts at 8ohms mono, and is capable of a 1/2 ohm mono load (very important). Will double it's output everytime you drop the ohm load in half. i.e.-
8ohms=100watts (all numbers are mono ratings)
4ohms=200watts
2ohms=400watts
1ohms=800watts
1/2ohms=1600watts
1/4ohms=3200watts
THIS INFORMATION SHOULD BE USED ONLY WHEN YOU ARE ABSOLUTLY SURE YOUR AMP IS RATED TO THE OHM LOAD YOU GIVE IT OR IT WILL BLOW UP!!!!!!!
I won my first SPL competition using this formula. I entered a 150x2watt amp class and wired my amp down to a 1/2ohm mono load thus making a 150x2 amp push 1200watts! (I used 2 - dual 2ohm voice coil 15" CV Strokers wired in parallel.)
PLEASE BE CAREFULL!!! there are only a few amps I know of that can do that and survive. The only other downfall (besides reliability, heat, and warranties) is there will be a corresponding drop in sound quality. This begins a whole other subject so I will just say this. This drop in sound quality is sometimes not noticed due to the nature of subwoofers (especially in cars). I hope this adds to the above info and further answers your question. For extra info please contact me @ dynami28@charter.net thanx.
Posted on Mar 26, 2009
  • 84 Answers
SOURCE: need wiring diagram for sub
u should have two pos, an two neg. on the back of the sub run a wire from one pos to the other same with neg. now just run a pos an neg from the box to one side of the sub u should have one side with two wires runing to the pos. an neg. if u need more help let me know bertman285@hotmail.com
Posted on Oct 05, 2009
SOURCE: need wireing diagram for hooking up two as12sq 12-inch square 2
you can run each sub at either 4ohms or 1ohm which means that two of them will run at either 2ohms or .5ohms....be careful how you wire them because most amps cannot handle .5ohms very well and might blow.....to wire them for 2ohms you will need to wire each sub the following way. they have two voice coils make a jumper wire connecting the negative on one coil to the positive on the other coil. what you are left with is a coil with an open positive and the other coil has an open negative. when both subs are wired like this connect the two positive terminals together (1 from each sub) and the two negative terminals together (1 from each sub) now the subs should be wired together at a 2ohm load. run the two positive wires into another combined wire which will run to the positive speaker terminal on the amp. do the same for the negatives
Posted on Nov 14, 2009
  • 155 Answers
SOURCE: 2 12" subs + 600W amp. Turn on, goes boom once, then red light
Is your gain all the way up? If it done this before, sounds like your over working the amp. Make sure your subs ohm load is capable with the amp load to. If they are 1 ohm and your amp is only 2 ohm stable, it would beat for a lil bit then go into protection mode to. Check your wires too.
Posted on May 13, 2010
Hello..im trying to find a diagram on how to wire my subs down to 1 ohm..i have 2 12 in. Audiobahn alum12n..they are currently runnimg at 3 ohms on a hifonics 2500 watt 1 channel amp that only supports 1 2...
Hi, if you wire all voice coils in parallel, you will get down to 1.5 ohms. That is the lowest you can go with these 2 subs. Just hook the amps' positive to all 4 positive speaker terminals and the amp negative to all 4 speaker negative terminals. Please let me know if you have more questions, and thanks for using FixYa.
Mar 22, 2011 | AudioBahn Car Audio & Video
I got 8 terminals on a my 15 audiobahn sub how do i hook at 2ohm load
Yes audiobahn do make a QUAD coil, and some people get confused with the - - + + on the terminal, This is called a dual lug, Check out Audiobahn.com and go to tech suport. Thier you can look up the wiring diagram for this sub... TRUST ME hope this was helpful positive feed back be nice lol
Apr 08, 2010 | AudioBahn AW1206T Car Subwoofer
Is the audiobahn enternal a good sub i got a 12''
i think they are if you look into them the imortal is a bad as sub. but the enternal was design to even hit note the imortal cant.... you gotta make sure you have enough power to give them justice i like the a2300hcx by audiobahn look in to that amp they are nice..
Feb 03, 2010 | AudioBahn ADS12E 12" Sealed Enclosure Car...
Have alpine 10 r subs can insignia 500w amp hook up and how to wire subs
if the speakers are 250 watts each then yes if speakers are less you will blow them cuz of to much power if they are more then you most likely won't be able to push them
Sep 24, 2009 | Insignia 600W Bridgeable Amplifier with...
Subs will not work right.
the subs coils are melted and shorting out so the amp shuts off
Apr 22, 2009 | AudioBahn AW1206T Car Subwoofer
Audiobahn 15s smell and stoped working
google "subwoofer wiring diagram" that will help you out,....you put in how many subs, DVC, SVC, and the ohms of the subs.....good stuff to know b4 hooking up a system....hopefully you didnt fry your subs or amp.....let me kno.....
Mar 14, 2009 | DHD NTX-6612 Car Subwoofer
Sony xplod 1200 watt
i had the same ploblem with my amp then i found out i didnt have a good enough ground. Make sure you groung it to your weel well or some part of the frame. Or you mite be running with a fuse thats pushing to much power i use a 100a fuse 5 gage power cord to power my 1200w xplode and my 2 12" kicker comps. Or if your using two diff kind of subs then you amp is confused in why your asking for 500w on one side and 600w on the other this will also make your amp light come on.
Jan 19, 2009 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Wiring subs
audiobahn.com can help you with the free diagrams under tect support
May 03, 2008 | AudioBahn A4075HCQ Car Audio Amplifier
Audiobahn 12' subs and audiobahn amp
First thing is first. What subs do you have? Audiobahn makes several kinds of 12" subs. What model sub do you have?
Without knowing this, it would be hard to recomend an amp without knowing how much power your sub can handle. Audiobahn makes from very power amps that can put out up to 5000W RMS, but if your sub can not handle that power, then you will blow your sub.
Dec 20, 2007 | Car Audio & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
