Question about Relic 0504648FA
Relic Sports Watch ZR18009
I purchased the above model watch but it has the wrong manual in it. Is there a way to get the right manual?
  • Anonymous Jul 25, 2008
    I have the exact same problem, wrong manual. Can't get my alarm to"beep" when needed, everything else is easy to figure.
5 Suggested Answers
SOURCE: Watch Band Adjustment
I think maybe we're all too familiar with the little old watchmaker image, loupe in right eye with tiny tools at hand......The links that have the arrows on them are indeed removable, it just takes more force than you might think. I'm in my office, so I used a pushpin (like for bulletin boards) and yep, it took more force than I thought, but the pin did come out the other side. A little tug with needle nose pliers and out it came. Remove link, repeat as necessary. Good luck
Posted on Jan 10, 2008
  • 3 Answers
SOURCE: Remove link form Relic Wrist band
For my relic ZR15372, all I did was take a thin, hard object (a thumbtack in my case) and carefully pushed out the connecting bar from the link.
If you look at the inside of the band of your watch, you may notice that on some of the links (the ones nearest the clasp for me) there is a little arrow pointing at the side - if you look at the side of the links, there should be a little hole, big enough to push a thumbtack into. If you apply enough pressure (again, carefully - no need to stab your thumb or any other part of your body), the connector pin should slide out a little on the other side. Then it's just a matter of pulling the pin out - perhaps a pair of tweezers would do the trick.
Hope this works for you!
Posted on Mar 04, 2008
SOURCE: need to adjust watch band
how to adjust a man's beverly hills polo club watch band
Posted on Dec 25, 2008
escapement
  • 2334 Answers
SOURCE: Mens Relic watch stopped working after battry change
I suggest that your watch has an oxidized contacts and electricity can not reach the movement.
Do as folloes:
Take out the batttery,
Clean (scrape) all battery related contacts till they are shiny (use hardened steel needle for that),
Use the dust blower to get rid off any tiny dust and dirt particles after cleaning,
Refit the battery back.
Now your watch should work again.
If all written above do not help, then there is a problem with your watch and you will need the help of the watchmaker.
Do not forget to rate, please.
Posted on Feb 10, 2009
  • 183 Answers
SOURCE: how to make a relic watch bracelet a little smaller?
No but if this is a mens watch there might be a micro adjustment on the clasp. To adjust press the pin in the clasp and move the pin in or out depending on the position of the pin to make loose or tight.
Posted on Sep 19, 2009
Testimonial: "looks like you were right!"
Need battery number for relic women's watch model zr33940 battery was lost
take it to a store that sells watches they might be able tomatch a watch to it .
Apr 08, 2015 | Relic Watches
Tip
RELIC watch manuals.
RELIC is made by FOSSIL, so the watch manuals are the same as for FOSSIL watches. Find them here: http://www.fossil.co.uk/webapp/wcs/stores/servlet/ContentView?langId=10&storeId=32553&catalogId=20002&page=instructions
on Jan 25, 2010 | Watches
Change battery
mcdevito75 here, Beat Bet, look for a small watch repair shop in your area, the tools needed, time spent, and you could wind up destroying your watch makes a shop your best bet.
Jul 01, 2010 | Relic Sports Watch for Men
Set the date on my new Relic watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all RELIC watch manuals.Rate me, please
Mar 22, 2010 | Relic watch
How to adjust Relic ZR15539 watch band
Depends on the type of band. Is it a twist-o-flex or solid link? Your best bet is to seek out a local watch repair business and let them adjust it for you! Unless you do these often it can be frustrating and you could lose small parts!
Jan 09, 2010 | Relic Watches
Do as folloes:
Feb 09, 2009 | Relic 0504648FA
Relic Watch Battery
http://www.apexbattery.com/relic-watch-battery-watch-batteries-relic-watch-batteries.html ... I've had 2 different sources take me to this same battery, although the Relic model I'm using is a ZR11586. "This battery is for ALL Relics," is what they keep saying.
Apr 22, 2008 | Watches
Relic 0504648FA Logo
120 people viewed this question
Top Relic Watches Experts
Andrew Taylor
Andrew Taylor
Vernon Taylor
Are you a Relic Watch Expert? Answer questions, earn points and help others
