Question about RCA 5-cd 300w Stereo System Shelf System
Shuffle I have a new RCA home stereo system, I can not get it to shuffle between discs--what is my problem?
I returned the unit.
Posted on May 29, 2008
Do I need mono or stereo cables for installing graphic eq into home stereo system
You should have two RCA jacks, one for each channel. That would be mono for each channel, not stereo. Each channel works independant of each other.
Jan 27, 2015 | home Audio Players & Recorders
Where is the aux jack for the RCA RS 2620 bookshelf stereo?
The Aux audio L/R input jacks are below the On/Off button on the left side of the front of the stereo's main unit. The headphone jack is just below the input jacks. You will probably need an adapter to split the stereo output from the Blackberry (probably a 3.5 mm stereo jack) to the L/R jacks.
Radio Shack has the manual for the RCA RS2620 here: http://support.radioshack.com/support_audio/doc72/72312.pdf .
I hope this helps.
Feb 04, 2012 | RCA RS2620 80-Watt 5-Disc Shelf System...
How do I connect my laptop to my Onkyo HT-S5100 home theatre system?
You need to stereo on L and R RCA connector. Something like this:
http://www.amazon.com/INSTEN%C2%AE-3-5mm-Stereo-RCA-Cable/dp/B0024CAWS2
Jan 13, 2011 | Onkyo HT-S5100 Theater System
What is it for and how does it work
HI ....
Motorola Bluetooth Stereo Gateway DC800 is used as
Motorola Bluetooth Home Stereo Transceiver
By streaming music to your the Bluetooth Stereo Headphones, the Bluetooth Home Stereo Adapter turns audio devices such as home
stereos and MP3 players into wireless music systems. Just plug the
DC800 into your home stereo or MP3 player with an included RCA
cable or 3.5mm cable and you are ready to go. You can even hook
up to your RCA capable TV!
Thanks .....
With regards
Priya
Sep 26, 2010 | Motorola Mobility Bluetooth Stereo Gateway...
I JUST BOUGHT A NEW LCD FLAT SCREEN TV. HOW DO I HOOK UP THE SOUND TO PLAY THOUGH MY JVC HOME THEATOR SYSSTEM?
TV's are not the best sound sources. They just make flickering visual images.
But if you must, connect theTV's RCA jacks for Audio L and R Out to Aux In. But that will only send stereo (at best) audio from the TV's source to the audio system. If you want better stereo and possibly multichannel sound use the cable box's sound as a source. It should have at least the analog RCA pair (for plain stereo) and maybe a digital audio output, too.
Jan 28, 2010 | JVC TH-A25 System
RCA RP-9515 stereo, CD player won't play
RD probably stands for "Reading Disc" and ND probably stands for "No Disc". If the CD player doesn't recognize any discs, then either the laser is dead or the motor has died. MOst likely you will have to replace the unit.
Mar 22, 2009 | RCA 100-Watt Stereo System With 5-CD...
We have the RCA RS2767i Home Stereo with 5-disc changer and ipod dock. The CD Tray won't eject or shuffle...everything else works fine. It seems the disc tray isn't responding to anything. We read in the...
Let me respond with a possible solution although I'd bet that both of you already tried these.
The reason I checked into this is because I'm looking for a new mini system. I happen to be at Target and they only had 2 models - this one and a SONY. I certainly didn't want to buy the RCA given these problems, so I asked the salesperson, who seemed to have some knowlege.
As far as opening the tray on top, there is a button to push right under the tray. The button has an icon of a triangle on it. This seems to be somewhat of a standard icon for opening the tray or ejecting a CD (my car's CD has the same icon for ejecting a CD).
As far as only being able to get 3 CD's out, there is another button under the tray marked "disc skip". This rotates the tray. When you open the tray, you can only get to 3 of the CD's. When you push disk skip, it rotates the tray one position, so you can get the 4th one out. Another push and now you can get the 5th one.
Sometimes my CD changer doesn't shuffle the disks. If I only have 1 CD or DVD in it and push the tray open button, the disk stays in the unit and the tray revolves to an intermediate position. I push the button to put the tray back and try disc skip; that usually works.
If your problems are not solved per above, then I definitely do NOT want to get this.
Fred
Dec 05, 2008 | Audio Players & Recorders
54 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
