Question about Texas Instruments TI-Nspire Graphic Calculator
My Ti Nspire touchpad isnt working, i cant make the arrows go up or down. All my other buttons work and this happened once before but it fixed itself but now its been like this for a while.
  • 8064 Answers
SOURCE: My TI-nspire CAS doesn't want to go on! I changed
Try the other recipes from the TI knowledge base concerning a calculator failing to turn on
For the TI-Nspire™ Family:
  1. Remove thekeypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) andremove at least 1 battery from each column of batteries. After 2-5seconds, reinsert the batteries and turn the unit on. This will causethe unit to reboot the operating system.
  2. Remove the keypad(for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove atleast 1 battery from each column of batteries. After 2-5 seconds,reinsert the batteries and LEAVE THE UNIT OFF (do not turn on and thenback off). Hold down [Home] [Enter] [P], and while holdingthese keys, press [On]. The device will boot up as in the previousreset, but will display a menu with the following options. Please tryoptions 1, 2, 3, and 4 in that order. ** The [Home] key is located atthe top right of the TI-Nspire keypad and has a picture of a house onit.
Note:TI-Nspire family model options 2 and 4 above require that the OS be installed. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above.
1. Cancel - The most non-intrusive reset option; no changes are made, the unit restarts.
2. Delete Operating System – The operating system will be deleted without deleting any documents.
3. Delete Document Folder Contents – This will delete the user’s documents, but will not delete the OS.
4. Complete Format – This will delete the OS and all documents for a total erase of memory.
Hope it helps you solve the problem.
Posted on Oct 18, 2009
  • 8064 Answers
Here is what the TI knowledge base says about a calculator failing to turn on.
  • 8064 Answers
SOURCE: Ti-nspire CAS buttons under enter button don't
It depends on the context.
The one on the lower side introduces a space. Used with the CTRL key it inserts an underscore.
The one to the right, with a symbol like a linefeed or newline, this one works in the context of matrices.
Used alone it adds a new row to a matrix. Used in conjunction with the CTRL key it inserts a new column in a matrix.
Outside the context of matices it does nothing.
Hope that this helps.
Posted on Nov 15, 2009
SOURCE: TI-nspire will not turn on
Yes we changed out the batteries on now the TI-84 will not turn on HELP
Posted on Nov 25, 2009
  • 8064 Answers
SOURCE: TI-Nspire 84 Plus keypad problem
Remove the TI84 Keyboard, insert the TI-Nspire keyboard and try to reset the calculator with a starightened paper clip.Calculator has a reset button on the back.
Posted on Feb 01, 2010
Ti nspire cx screen is really dim.
Recharge the battery and see what happens.. Could also be that the autodim feature is fixed to the lowest value (30 s).
Apr 01, 2014 | Texas Instruments TI-Nspire CX Graphing...
The calculator writes 8 all over
During operation of the TI-Nspire handheld it may be necessary to reset the device. Circumstances which may require a reset include; keys not responding, device will not turn on or a garbled display. To reset the device:
• Remove the keypad (for TI-Nspire with ClickPad, TI-Nspire with TouchPad, and TI-Nspire CAS with Touchpad) or the battery door (for TI-Nspire CAS with ClickPad) and remove at least one battery from each column of batteries. After 2-5 seconds, reinsert the batteries but do not turn the handheld on.
For the TI-Nspire and TI-Nspire CAS handheld units with ClickPad:
• Hold down [home] [enter] [P].
• While holding these keys press [on].
For the TI-Nspire and TI-Nspire CAS handheld units with TouchPad and the TI-Nspire CX and TI-Nspire CX CAS:
• Hold down [doc] [enter] [EE].
Please Note: For TI-Nspire Family handheld units that contain rechargeable batteries you can alternatively hold the above keys while pressing the [reset] button on the back of the handheld rather than removing the battery for 2-5 seconds.
• The device will boot up as in the previous reset, but will display a menu with the following options. Please try options 2, 3, and 4 in that order.
• 1: Cancel - The most non-intrusive reset option; no changes are made, the unit restarts.
• 2: Delete Operating System - The operating system will be deleted without deleting any documents on the system.
• 3: Delete Document Folder Contents - This will delete the user's documents, but will not delete the OS. Selecting this option is the same as using the RESET hole on the back of the unit.
• 4: Complete Format - This will delete the OS and all documents for a total wipe of the handheld.
Please note that the second and fourth option will require that the OS will need to be reinstalled
Mar 12, 2014 | Texas Instruments TI-Nspire Graphic...
My TI NSPIRE CX CAS is stuck at the loading screen - it keeps loading and then going back and repeating (only when plugged in). I have tried resetting it whilst holding down EE, doc and enter. When I do...
restarts.
unit.
Please note that the second and fourth option will require that the OS will need to be reinstalled.
Oct 09, 2013 | Texas Instruments TI-Nspire CX CAS...
How to I adjust the brightness of the ti-nspire touchpad?
To increase the contrast (brightness) of the screen of a TI Nspire with Touchpad, press the CTRL blue key and hold pressure. Then press the Plus button. Release both keys when contrast is adequate.
Mar 09, 2013 | Office Equipment & Supplies
My ti-nspire cant solve this second order differntial eq. x''+7x'+12x=4/k and x(0)=0 and x'(0)=4/k,t,x
You have to type:
deSolve(x''+7x'+12x=4/k and x(0)=0 and x'(0)=4/k,t,x)
Then enter. See captured image below
Jan 04, 2013 | Texas Instruments TI-Nspire CAS with...
TI Nspire CX keeps rebooting?
This is the easiest way to fix a restarting TI nspire cx cas!!
Just follow my simple tutorial, I had the exact same thing:
https://www.youtube.com/watch?v=mEYRWhMNGn8
Jan 27, 2012 | Texas Instruments TI-Nspire Graphic...
Hi, can you tell me how I can make a simple program so I can change the Nspire to degree or radian mode without having to go through Settings etc etc? My students frequently make mistakes because it is...
No need for such a program. You can specify the angle unit for a calculation regradless of the angle unit currently set as default.
For the TI Nspire with Touchpad.
Calculate the sine of 30 degrees.
Press the trig> button next to = on the left side of keyboard.
Select sin and press ENTER
Type in 30
Press the key with the question/Exclamation marks.
Use right arrow to highlight the degree symbol.
Press ENTER. No need to close parenthesis.
The answer is displayed as 0.5.
To enter an angle in radian (regardless of the angle unit set as default.
Do as above to type in the function
Type in the angle.
Press the small button marked with Pi and arrow (To the left under the EE button)
Use the arrow to highlight the small superscript r.
Press ENTER
For TI Nspire with ClickPad
Press the trigonometric function key.
Enter the angle
Press the key with infinity symbol, beta, degree (below the Clear button.
At the top of the list where the Pi symbol is you will find the degree,radian, and gradian symbols.
Append the one you want and and press ENTER.
Sep 07, 2011 | Texas Instruments TI-Nspire Graphic...
How do you put the batteries in?
  1. Remove the keypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove at least 1 battery from each column of batteries. After 2-5 seconds, reinsert the batteries and turn the unit on. This will cause the unit to reboot the operating system.
  2. Remove the keypad (for TI-Nspire Family or TI-Nspire CAS Touchpad) or the battery door (for TI-Nspire CAS) and remove at least 1 battery from each column of batteries. After 2-5 seconds, reinsert the batteries and LEAVE THE UNIT OFF (do not turn on and then back off). If the TI-Nspire/TI-Nspire CAS is a Clickpad, hold down [Home] [Enter] [P], and while holding these keys, press [On]. If the TI-Nspire/TI-Nspire CAS is a Touchpad, instead hold down [Doc] [Enter] [EE], and while holding these keys, press [On]. The device will boot up as in the previous reset, but will display a menu with the following options. Please try options 1, 2, 3, and 4 in that order. ** The [Home] key is located at the top right of the TI-Nspire keypad and has a picture of a house on it.
Aug 26, 2011 | Texas Instruments TI-83 Plus Calculator
I have a Ti nspire and its running slow. I would like to erase all my old data and start fresh. how do i do this
First remove the batteries, then replace them. After doing this, if you have the touchpad version, press Doc, EE, Enter, and On at the same time. From the maintenance menu you then click reset. Or you could hit the button on the back of the calculator, whichever works for you.
Feb 15, 2011 | Texas Instruments TI-Nspire Graphic...
I have a TI-nspire CAS calculator. When it is switched on it begins loading and then comes up with System Error. What do I do?
You should ( a suggestion) reset the OS by pressing the button on the back of the unit.
If that does not work, you may consider reinstalling the OS. The procedure as described in the TI Knowledge Base is as follows.
What steps are required to reinstall the TI-Nspire family operating system?
To reload the device’s OS using a computer with TI-Nspire Computer Link:
• Connect the TI-Nspire device (with the Nspire keypad) to the computer using the USB Standard A to Mini B cable.
• Open the TI-Nspire Computer Link software. The select device dialog should appear, and detect the device.
• Either drag the OS file (available in the ‘downloads’ area at education.ti.com) onto the TI-Nspire File Browser portion of the window, or click Tools -> Install OS.
To reload the device’s OS using another TI-Nspire or TI-Nspire CAS device:
• Connect the two devices using the USB Mini A to Mini B cable. The end marked A should be inserted into the sending unit, while the end marked B should be inserted into the receiving unit.
• On the sending unit, access the document chooser by pressing [Home] [7]. Once in the document chooser, press [Menu] and choose 9:Send OS…
NOTE: Users can only send an OS to a unit of the same model. Users cannot send an OS from a TI-Nspire to a TI-Nspire CAS.
Please see the TI-Nspire guidebooks for additional information.
Hope that helps.
May 08, 2009 | Texas Instruments TI-Nspire Graphic...
Texas Instruments TI-Nspire Graphic Calculator Logo
74 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
