Question about Mitsubishi WS-55511 55" Rear Projection Television
I turn on my tv and turn off 5 secons after - Mitsubishi WS-55511 55" Rear Projection Television
    Sergeant:
    Champion:
  • 293 Answers
Deffective capacitor at power section.
Posted on Oct 05, 2010
How do I stop my toshiba tv from instantly turning off
That sadly is a power supply failure of some kind, most likely. It is shutting down to prevent more problems.
Jan 15, 2015 | Toshiba Televison & Video
Sony Trinitron Wega KV-27FS100 picture on and off
i'd say your tv is unhappy.
unplug for 10 min..and see if that resets it.
May 31, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Get tv out standby
you must test the fuse inside. And after that reset by disconnect the power cable from the outlet by 30 secons. and try again.
Go after to the MENU of the TV, and reset to the factory.
God bless you
Jun 19, 2013 | HP Computers & Internet
Tv will turn on for a few seconeds then turns its self off
Tries tv unplug,replug it back like an hour later.The tv is resetting itself back to the factory setting now.The tv now should work,not than the tv have problems with it power supply board.The power supply board it not giving the tv,the wright voltages to the tv anymore.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 14, 2010 | Sanyo DP32649 31.5 in. TV
My 1994 bronco fuel pump is not working, is there a relay i should check first before removing the fuel pump?
Best thing to do is check voltage at fuel pump harness, have some one turn key on and off every 5 secon's, probe wire's at fuel pump harness, one of the wire's will have voltage for about 3 secon's, if you do fuel pump is getting voltage, some time while cranking engine and hitting gas tank with hammer at the same time, fuel pump will start working again, if it start's, you will still need to replace fuel pump or it will happen again, fuel pump is in fuel tank.
Aug 06, 2010 | Ford Bronco Cars & Trucks
Tv says "no signal" when i turn on PS3
About holding the reset button, I assume you know how to use that trick, you might be missing something, though: Probably you have your TV set to the incorrect input, eg. Connect only the HDMI, set your TV to HDMI input and go with the power button trick (press (youll hear a beep), dont release until you hear a second beep) the system will autmatically display through HDMI, it can take up to 5 secons or so.
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
DTD1363-CAR
Mine does this as well, I would really like to know a fix or if anyone has had any luck with getting theres replaced
Sep 08, 2007 | Disney DTD1363-CAR 13" TV/DVD
TV Stuck in Demo mode
In the tv and with the set turned on press and hold the ACTION and CHANNEL UP buttons at the same time for more than 5 secons.Let Us know how it goes.
Oct 16, 2006 | Panasonic CT-34WX54 34" TV
Mitsubishi WS-55511 55" Rear Projection Television Logo
21 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
