Question about Radio Shack Welding Tools
Bought mini butane soldering iron today filled with butane and used it. It was getting low so i put more butane in it and now i can light it. please help
    President:
  • 1,514 Answers
When you fill the soldering iron with butane you must have it turned so the butane can is held upside down. Liquid butane must be able to flow into the iron. It's most likely that you held it upright and even though gas butane would have flowed in it would not be enough to light it. Only fill it outdoors.
Posted on Oct 05, 2010
Misplaced Manual, what butane container to get.
Any butane will work, but the big name-brands are usually filtered better and less likely to cause problems. The biggest issue is the nozzle -- there are a lot of different sizes. Any Weller butane can will fit perfectly (usually cheapest at the local Sears store), but any can with multiple adapters will also work.
If you have an old can that fits, save the nozzle when it's empty. It should fit a different can if you can't find a can that fits the tool.
Jun 04, 2012 | Weller WPA2 Pyropen Professional Self...
My Pyropen will not ignite
Not enough information. That's an extremely vague description of the problem. There's no way to suggest a fix without knowing more about it.
Does it spark?
Does butane come out of it?
Is the cylinder full?
Do the switches move properly?
How old is it? How much use has it seen?
Is it an intermittent problem, or constant?
Apr 12, 2011 | Weller WPA2 Pyropen Professional Self...
Cant light the thing !!
the one i have, first see if you have fuel in it, if it is full, then check to see that the switch is in the on position, when i put mine in on, it clicks, then it gets hot, also check to see if you have it wide open
Mar 03, 2011 | Milwaukee Tool Weller Pyropen Jr Cordless...
It is a cordless soldering iron by Bernzomatic that uses butane to work
I am familiar with many models of butane powered soldering irons made by Benzomatic. Please let me know what your model and question is.
Jan 04, 2011 | Garden
My Pyropen WPA2 will not ignite I have changed the gas ,it has Butane UN1950 in now and is Half full
Does it spark?
Does the butane come out?
How old is it, and how much has it been used?
Did you put cheap butane in it at some point?
Sep 10, 2010 | Weller WPA2 Pyropen Professional Self...
What power source do i connect my hot devil soldering iron too
That would be a butane source, that unit runs off butane gas.
check out www.hotdevil.com.au
Aug 10, 2010 | Welding Tools
Torch has excessive gas flow at the lowest setting.
With empty tank you can try to unscrew the black parts and clean or tighten the regulating lever.
Jun 18, 2010 | Radio Shack Mini Butane GasPowered Iron
Old Victorian Light fixture needs to be repaired. I think soldering the broken parts together would work, but I've never soldered brass parts (only simple electronic motherboards). Anyone out there that...
to solder brass u just use regular solid solder with a tin of acid flux, but u must use a Small butane fueled pin torch or a large high temperature solder iron to do the heating (this really depends on the size of the material being soldered), the brass must be clean and bright, use steel wool for this these small torches are available from any hardware store, they fuel up with butane cartridges used for refilling cigarette lighters
Jan 18, 2010 | Welding Tools
Mini Ultra
connect 100k resistor to reduce on the current
Jul 10, 2009 | Master Appliance Mini Ultra Butane...
Welding Tools Logo
498 people viewed this question
Top Radio Shack Welding Tools Experts
Bill Boyd
Are you a Radio Shack Welding Tool Expert? Answer questions, earn points and help others
