Question about Medion M3 Director 5100 PC Desktop
DVD Drive removal
I need to get the DVD drive out of the computer in order to change it
    Sergeant:
  • 336 Answers
First of all I highly recommend that you do NOT go inside your computer unless you have an anti-static bracelet and if you are not a service technician because of the amount of harm you can do to your computer. But if you wish to continue you open your case, find the drive, remove the cables and then take out the drive. If you need more clarification you can tell me and i will walk you through it with more detail.
Hope This Helps
All The Best,
RCF
Posted on May 28, 2008
Ze4365us will not boot from cd
If your laptop will not recognise any cd or dvd that you put into it - a music or movie dvd- it's probably the actual dvd drive at fault. It means that you will have to replace the optical drive for your computer model. This is quite easy to do.
Before buying a new optical drive, try a last-throw solution. Remove the optical drive and power up the computer. Then switch it off. Refit the optical drive and power up the computer, which may detect the refitted optical drive.
However, if you mean that your laptop will recognise the information on a dvd - such as a Windows operating system - but won't boot up from it when you restart the computer it's probably because the computer is set up to set up to boot from the hard drive first.
To change the boot-up order press either DEL of F2 at start up. Go into the bios settings and look for 'boot up sequence'. You'll be able to change the first boot to dvd or usb.
Mar 06, 2014 | HP Pavilion ze4365us Notebook
I installed a sata dvd drive in my dc5100 sff the boot order recognises it as an ide drive
i dont think it matter if your system detects it as sata or ide, both interface will work in installing OS, the important thing is you changed your boot order. originally it was supposed to boot in 1st drive whichever it is hard drive or dvd drive. go to bios then follow the instruction in how to move the order of boot sequence, mine is SHIFT key then PLUS.
Feb 28, 2014 | HP Compaq dc5100 Small Form Factor PC...
Dvd not working to initiate repair disk- no boot on hard drive
If the internal DVD drive worked previously, try changing the boot order in your BIOS. Depending on your computer, you will need to press Esc, Del, F1, F2 or F10 to access the BIOS. Save the new boot order when you exit the BIOS. If your DVD isn't listed, replace the SATA cable with a new one and make sure that the power cable is fully seated. You can try connecting the data cable to another SATA port on the motherboard. It's possible that the DVD drive failed as well; you can try a different optical driver.
All of the SATA ports should be able to support a boot device unless there is a specific controller/bandwidth sharing issue involved.
If you are using a USB DVD drive, you need to make sure that your motherboard supports booting from USB.
Please add a comment with your computer make/model or motherboard. I can provide more assistance with changing the boot order or determining the limitations of your SATA ports on your system.
Dec 16, 2012 | Computers & Internet
When i start my laptop it goes to a screen an says enter boot disk an press any key..but i dont have a disk...
Sounds like your system is booting from somewhere other than the hard drive or you have a music cd or movie dvd in the DvD/CD drive when you booted the laptop. If so, remove the music cd or movie dvd and reboot.
You want it to boot from the hard drive.
Turn the computer off and press the power button to reboot it. Notice the screen and watch for which key it says to hit to change the Boot Order or Boot Sequence. You have to hit that key when you see the message otherwise it will be to late and you will need to start over. Select the Hard Drive and let it boot up. This is a temporary change and only good for this boot cycle. You'll have to do it each time you boot or you can make it permanent.
To set your boot order or boot sequence permanently reboot the computer and look at the screen to hit the key it says to get into the Bios or System Setup. Hit that key when you see the message or it will be too late and you will have to restart it. When you get into the Bios or System Setup tab over to the Boot Order or Boot Sequence. The normal boot order should be the DvD/CD drive 1st, the Hard Drive 2nd. With this setting you have to make sure nothing is in the DvD/CD drive when you boot the system or it will try to read it as a system disk and give you an error if it can't boot from it. If there is nothing in the DvD/CD drive it moves to the next boot device which is the Hard Drive. This setting is the best because it will allow you to use a Repair Disk or Operating System Disk to fix your computer when the hard drive has issues.
May 20, 2012 | Computers & Internet
I switched my IDE hard drive into another computer that is a little more up to date. computer boots, passes post, shows these options " safe mode, safe mode with networking and command prompt. start...
As the Windows installation is installed on the first computer hardware configuration and now it is moved to another computer hardware configuration, ie another computer. It will not work as Microsoft prohibits moving/changing hardware configurations to the extent of another computer system.
In your case you will have to return the hard drive to your original computer and then backup your files. Then this hard drive needs to be formatted, all data will be lost. Then the hard drive can be install in the better computer and a fresh installation may be performed. However you will need to read the terms and conditions of your Windows License Agreement to see if this is indeed possible.
With regards to the DVD drive, it needs to be connected on the IDE2 port, right at the end of the IDE bus/ribbon. There are 3 positions a longer length and 2 shorter lengths.
Long side plugs into the mainboard, the middle one is left open and the shorter end one is plugged into your DVD Drive.
Ensure that the jumper located between the power and IDE port of the DVD drive is set to the Master Position. The details can be found on the label on top of the DVD drive.
Thumbs up!
Thanking you
damnor01
Mar 15, 2011 | Microsoft Windows XP Home Edition
I want to remove my dvd cd re-writer drive from my hp compaq nc6220 and replace with dvd re-writer drive but need instructions
there two screws on bottom case below the dvd drive, who atach the drive steady, take this out and pull the drive out carefully, normaly use a flat small screwdrive, change it check for new one has the same screw holes positions
Jul 15, 2010 | HP Compaq nc6220 Notebook
How do i uninstall windows vista and making a clean dard drive
You would need a operating sytem cd/dvd (windows xp\windows 7) and a windows COA key. Select your bios to boot from cd\dvd player. Insert the new cd of a different operating system into the drive and restart the computer. It should say press any key to start from cd. Press any key and proceed. You will get to an option to format and install. Format the drive Probably marked C:. This will wipe out the drive and install a fresh copy of whatever OS cd you booted from. Good Luck.
Nov 24, 2009 | Microsoft Windows Vista Ultimate Edition
When I connect my SATA dvd drive my comp continuously restarts. Without it, it runs fine.
hello !
Thats wired is it so  ? ok  go to your computer  set up and  see what's the booting order .
If it starts with cd  rom first  reset to boot from hard disk first  ie its should be in this order
1, hard disk
2, cd rom
3 floppy disk
good luck
Sep 17, 2009 | Computers & Internet
I have a dell inspiron b 130 and my cd rom was pulled out by my son i wanted to know how can i boot my computer from the new cd dvd rom i need to format my laptop
you can configure it on the bios settings of the unit itself (possibly F2 or F11)
Then go to boot sequence then look for the removable device.
Then save your settings and restart your laptop. It should be working now.
Feb 26, 2009 | Dell Inspiron 8200 Notebook
Medion M3 Director 5100 PC Desktop Logo
54 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
