Question about Texas Instruments TI-83 Plus Calculator
My calculator won't turn on. I thought it was the batteries so I went and bought new ones and it still doesn't turn on.
  • kakima Oct 05, 2010
    TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
    Does it?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Having gone over five months without a response, I assume the suggested contrast adjustment solved the problem.
Posted on Mar 29, 2011
Key won't turn in ignition on 2006 chevy cobalt
on a lot of these late model computer base cars when battery power get low the computer gets confused. try this disconnect the neg. battery cable. charge the battery. reconnect and try again. my son cobalt battery went bad key was stuck in the igntion. good luck.
Dec 19, 2017 | Chevrolet Cobalt Cars & Trucks
No display at all, does not seem to be turning on, yes I replaced the batteries.....any thoughts?
If new batteries did not solve the problem, the next thing to check would be the battery terminal.
If the battery terminal is rusty, the battery power won't contact and the calculator won't turn on. So, use a flat small screw drive to scratch the battery terminal so that there would be contact.
If the above is not the problem, the next to check would be the wire connecting the battery terminal to the the calculator's main board. There is a wire between the battery terminal and the calculator board. When the battery is inserted, the power from the battery goes from the terminal to the board through this wire. There is a possibility that this wire is cut in-between or is loosing contact. In this case, you need to get a small screw driver and carefully disassemble the calculator in order to check the wire.
If the wire is intact, use a light brush to brush the calculator board as there might be dust on the board.
If non of the above helps, then it means the calculator is dead and needs a replacement.
Regards.
Sep 12, 2011 | Texas Instruments TI-83 Plus Calculator
It's "frozen". won't change from the screen its
Try to reset it by taking out the batteries and leaving to sit for a minute or so, if that doesn't work take out the small battery as well and leave it sit, if you're still stuck you can call ti-cares (800-842-2737) they're generally very helpful.
Aug 05, 2011 | Texas Instruments TI89 Titanium Scientific...
My TI83 calculator hasn't been used in a few
Is it that your "Enter" key won't depress or it doesn't respond?
Aug 05, 2011 | Texas Instruments TI-83 Plus Calculator
My ti 84 plus does not want to turn on, i thought it was battery problem so, i bought new batteries but i stil have a blank screen.
Could it be that your screen has been dimmed in error. Turn the calculator on & press the 2nd key and then the up arrow. This darkens the screen.
If this doesn't work, try taking out the backup battery. It is located in the battery compartment, behind a little door that you must take off with a phillips screwdriver. Leave it out for about 10 hours. If this doesn't work, try replacing the backup battery.
Hope this helps.
Jun 21, 2011 | Texas Instruments TI-84 Plus Calculator
"ON" button doesn't work; calculator won't
In most cases this cannot be economically repaired... the cost to repair would be more then the calculator is worth...
heatman101
Jun 18, 2011 | HP 48gx Calculator
I turn on the calculator and it comes up with the little black thing in the left hand corner. Then it turns off. It doesn't allow you to do anything, it just shuts off. At first I thought there was a...
Your calculator may need to be reset. Open the battery door. There's an internal battery behind a little door with a screw right above the 4 AAA batteries. Take this battery out. Leave it out for about 8 hours then put it and the AAA batteries back in. Hopefully this will solve your problem.
Jul 10, 2009 | Texas Instruments TI-84 Plus Calculator
My TI-83 won't turn on and it has new batteries in it.
try cleaning the contacts and see if there is a rest buttom
Feb 07, 2009 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
51 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
