Question about Garland H283 Gas Kitchen Range
Oven pilot shuts off while cooking model H286RC-24
Ive converted this stove to propane the orifices and pilots are clean and new gas is effectively flowing to the oven pilot yet after a period of cooking both the burner and pilot click off. The valve i engage to start the oven pilot seems to kick off. I replaced the thermal coupler still the problem persists. help
  • propain May 29, 2008
    Thanks very much, ill check those possible causes and get back to you.
  • propain Jun 04, 2008
    Well, I tried all of your suggestions, which were great, incidentally, and ended up focusing on the valve. I took it off, and inspected in closely, and to my surprise, found windings from the drill hole in the gas-input side of the valve. I plucked these out carefully, clearing the hole, and re-installed the valve. It worked perfectly up to around 350 degrees and then the burner and pilot shut off on its own again. While still hot, I took the valve off, and the expansion loosened more of the fine windings, again, blocking the hole. After removing these carefully and re-installing the valve, I am pleased to say the oven works perfectly without shutting off the pilot. In short, an obstruction impaired the valves proper functioning.
    Scholar:
  • 68 Answers
You may have an adjustment problem. The pilot flame needs to under the thermocoupler back from the tip just a touch. But ultimately, if the flame is good, the thermocoupler is good, you have a bad valve.
Also make sure that there is no overall gas pressure problems with the unit. A bad regulator can starve a unit for gas one minute, and work the next.
Posted on May 28, 2008
I have a older 40,000 BTU 3 burner natural gas deep fryer. I would like to convert to propane gas. The orifice number is size 32. Do I need to get different orifices to convert? The serial number is...
Hi there.
Burner orifice size for propane gas is number 55. You have to replace all burner orifice with this size if you want to use the fryer with propane gas. Pilot burner orifice should be replaced with propane pilot orifice.The gas valve spring should also be replaced with propane spring kit. The difference between the two spring is the natural gas spring is lighter or thinner compare with the propane gas valve spring.
Regards.
Jul 13, 2011 | American Range AF40 Deep Fryer
We purchased a used Vulcan Steamer model # VSX10GC which was set up for propane. We need to convert it to Natural Gas. How do we do this and how do we get the parts
Please be careful when converting appliances form natural gas to propane. Depending on the equipment there are several changes that need to be made. You will at least have to change burner orifices and convert or replace the gas valve. Some gas valves are not convertible. What many people over look are changing the pilot orifice and on some appliances like braising pans, griddles and char broilers there is a runner tube orifice. The gas valve also needs to be adjusted to the proper manifold pressure and pilot adjustments will be required. I recommend on Vulcan equipment that you contact Hobart Service since they are factory trained on all Vulcan cooking equipment.
Mike
Mar 11, 2011 | Vulcan Hart VSX5G Counter Convection...
Broiler works but oven won't light like it's not
The first thing you want to check is if the small shutoff lever built into the appliance valve has been accidently closed. This appliance valve is either in the back of the unit or under the top near the back. When you converted the stove, you also had to convert this same appliance regulator by flipping the top. Look at it again and see if there is also a small lever on the outside of it. Flip it and see if you get gas to the oven. If that doesn't solve it, did you adjust the oven orifice down? Although some models do swap out the oven orifices, so be sure you used the correct size. Make sure you have enough air on the adjustable air shutter on the end of the burner tube at the orifice. Typically it should be open 1/2 to 3/4 of the way. Since it is a used stove, it may have a spiderweb or bug nest blocking the burner inside, so you may have to remove it to inspect it. Does the oven require a pilot? If it doesn't have electronic ignition, then a pilot has to be lit before the oven will light. If it does have electronic ignition, is it glowing orange at all? These things are a lot easier to trouble shoot when you're looking at it, so I'm just throwing out ideas for you to check. Hope this helps you. I'm a propane guy, so let me know if you need more assistance and I'll try to help you further! Douglas
May 25, 2010 | Magic Chef 31000 Gas Kitchen Range
I just got my (new to me) pre-1990 Wolf 36'' range connected (by a certified pro). 4 burners, 12'' fry top/charbroiler/cheesemelter thingie on left, 4 burners on right, 29'' oven - propane. It has not been...
the oven pilot has 2 setting first setting is for you to light small flame, should not be all yellow if it is it has a dirty orifice inside the pilot hood, you can remove this by disconnecting the pilot line from the hood and removing orifice for cleaning, just rub it with a cloth.once clean and replaced you light pilot and check it out. if its ok turn on oven and secondary pilot will ignite that why it got bigger!! this heats a flame sensor to allow 100% safty vavle to open to let gas into burner so yuo can cook.
Feb 02, 2010 | Wolf Range CHR-0-29-FT34 Gas Kitchen Range
How do you start the oven on a Hardwick propane range?
The bottom part of the stove in the front has a drawer you pull out which has a broiler tray located there. You should be able to fold the door down and use a flash light to look inside . You will find a pilot light set-up there.
The stove I have has the pilot gas on all the time, so as soon as you turn on the gas to the range, the pilot gas is open to atmosphere.
I just light a match and reach in to where the gas piping can be seen and the pilot flame will light.
There is only a small amount of gas coming from the pilot orifice, so there isn't any danger lighting it when the gas is first turned on at the tank.
In fact you may have to wait a few minutes for it to light at first because the propane line maybe full of air. I usually light the top burners of the stove first and by that time the pilot gas for the oven is ok to light.
Jan 05, 2010 | Kitchen Ranges
Delay in oven burner to light after pilot is lit.
Usually delayed lighting on a standing pilot system is caused by a gas pathway that is dirty from spilled food or grease. If you can remove the burner assembly and clean it that will correct the problem. If there is a removable plate above it then you can remove that and get access instead of removing it. Pilot ignitions work by creating a column of gas between the pilot and the burner that is established when the burner is turned on kind of like a fuse. A small tube my be used to establish the column of gas between burner and pilot and it may get blocked with food that overflows. Sometimes the pilot is just located right next to the burner and may get partially blocked or the orifice in the burner next to the pilot may be blocked. Cleaning all this helps. Be very careful with gas. Work in a well ventilated area. Turn on gas very briefly to run an ignition test. Turn off the gas and vent it off if it fails to light in about 5 seconds. Unburned propane drops to the floor and collects. Natural gas rises. Be aware of this when you ventilate.
Dec 23, 2008 | Magic Chef Ovens
Ritetemp propane log
your pilot assy is clogged, disassemble the pilot assy completely and inspect the orifice. there should be a tiny pinhole in the end of the orifice, clean well with small wire brush and reassemble, don't forget to clean the thermocouple while you have the assy out.
Mar 28, 2008 | Heating & Cooling
60" double oven gas Garland stove
We use a Garland from the 1960's and pilot lights ARE scary and should make you nervous. This is why they are no longer allowed in new gas ranges. I mounted an inline gas shut off to the stove where the gas enters (on mine this is right in front on the left side). It turns on and off like a burner and when we are done cooking we simply shut off the gas there. To light the burners or the stove I use one of those long reach lighters. I go to bed knowing that NO gas is coming in.
We love the stove, it makes cooking more fun.
Good Luck!
Oct 24, 2007 | Garland H283 Gas Kitchen Range
Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Garland H283 Gas Kitchen Range Logo
284 people viewed this question
Top Garland Kitchen Ranges Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
