Need to see wiring schematic for Intertherm MGH-055AB
  • 69 Answers
SOURCE: wiring diagram for intertherm ac heating unit
Your best bet is to contact Intertherm and see if you can get the Installation/ owners guide.
Posted on Dec 21, 2008
flatech
  • 111 Answers
SOURCE: NEED A WIREING SCHEMATIC FOR A INTERTHERM AIR HANDLER
http://homeappliance.manualsonline.com/ex/product/headline/m/INTERTHERM/d/Electric%2BFurnace/p/E1EB-017HA
You can serch this site to get manuals for several Hvac Systems.
Also you can share any if you have.
Posted on Oct 24, 2009
  • 146 Answers
SOURCE: need wiring schematic for intertherm model
schematics start around page 20 hope this helps you
mike
Posted on Jun 05, 2010
heatman101
  • 43501 Answers
SOURCE: I need the schematic for
Probably not going to find that anywhere....what do you need?? I can probably walk ya through it..they are pretty simple...
heatman101
Posted on May 10, 2011
  • 37 Answers
SOURCE: I have an old Intertherm gas-fired furnace, Model
Sound like your blower motor is bad, but depending on the furnace age you could have an blower control board that has bad contacts. Need serial number or age of furnace,.Capacitors usually are not the problem, need to replace both motor and capacitor.
I
Posted on Nov 09, 2011
I have a Intertherm model MGH-075-ABWN-05 and the A/C stopped working. someelectrical problem i'm guess.neither the blower fan nor the outside unit are running at all
Check the drain line for a float switch. Remove float and check for water. Do not leave float out, you must clear the drain. Good Luck
May 10, 2017 | Intertherm Heating & Cooling
Got Intertherm Model # MGH-055AB.. It lights for ap 10 seconds goes out then goes out... Over and over again does not stay lit long enough for the blower to start running?? ANY IDEAS HOW TO FIX IT ?
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If the s3 comes on then you have an issue with the unit and i would get a professional to help.
Air Conditioning Boca Raton
Apr 10, 2015 | Intertherm Heating & Cooling
I HAVE AN INTERTHERM MODEL MG-055AB TURNS ON BUT TURNS OF IN A 4OR 5 SECONDS ANY SUGGESTIONS
light pilot then turn blower on by thermostat. if it blows it out bad heat exchanger. if it stays lit shut down & pull burner assembly clean pilot orifice.
Feb 16, 2015 | Intertherm Heating & Cooling
Looking for a gas valve for a intertherm furance model no. mgh-055aacwl-06 ser.number mgh9009-00077
you need to contact your nearest a/c supply house. most company's that sale parts on line will not sale gas valves to the public due to liability.
May 15, 2014 | Intertherm P3RA-048K Air Conditioner
I have an old Intertherm gas-fired furnace, Model MGH-055AB which ceased operating last night. It was quite warm when I arrived home, and when I set the heat up a little, began to hum, but the fan would...
Tom P's answer is generally correct: The motor start capacitor is usually not the problem. However, in some cases, particularly on older furnaces, where there were capacitors of certain make and production run will prematurely fail. This happened in March on a mobile home HVAC unit where both the blower fan and condenser fan motor capacitors failed open circuit. Both caps were of the same Mfg, and production lot.
Here is a suggestion (for you or an electrically inclined friend): Locate a substitute motor capacitor having similar Mfd (or MF) and Voltage ratings. Remove power from the unit. Reach into the blower squirrel cage and spin it to verify that the shaft is not frozen. Pull the wires from the existing capacitor noting color and location. Connect the wires to the substitute capacitor and secure it place. Apply power and turn on the blower. A no start? Motor replacement time.
Nov 08, 2011 | Intertherm P3RA-048K Air Conditioner
Gas Valve is leaking
I am a Nordyne dealer and you can replace your gas valve with a generic valve of your choice. You can try and find a supply house in your area that sells them or you can visit www.myhvacparts.com to find one.
Apr 05, 2009 | Intertherm P3RA-048K Air Conditioner
Wiring diagram for intertherm ac heating unit
Dec 21, 2008 | Heating & Cooling
Heating & Cooling Logo
150 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
