Question about Bosch Power Tools Sanders Orbital Sanders
Hi. My sander PEX 400AE flicks the velcro pads off. It has hardly been used. I tried cleaning it and using good brand discs. It seems I would need to buy a new sanding plate which I won't do as the same thing would recur after a few uses. Any suggestions? Could I use adhesive pads with it? How to keep the pads on? Any suggestions appreciated. Thanks. Josie
4 Suggested Answers
efs_perpends
  • 1996 Answers
SOURCE: changing the rubber pad on the Bosch PEX 12 AE
I'm not familiar with that particular model, but they are virtually all replaced the same way. There are a few screws through the pad into the base. Simply remove them and screw the new pad on. You'll see that it's quite simple once you get the new pad in your hands.
Just be careful not to strip the head of the screw: use the right size screwdriver tip.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 02, 2009
mikeymiddles
  • 58 Answers
SOURCE: Orbital sander flicking the sand paper off
You did not specify how the sanding discs are meant to be attached to your sander's backing pad.  My experience with this type of problem is material from the sanding process builds up on the backing pad and does not allow the sanding discs to adhere properly.  If you have a velcro type system, clean the hooks on the sander's backing bad by soaking the pad's face in a plate of paint thinner for 20 to 30 minutes then use a wire brush to remove the rest of the paint physically.    For adhesive pads clean the sander's backing pad surface with denatured alcohol.  Do not use isopropryl or rubbing alcohol as this may not be 100% alcohol and could contain a lubricant like glycerin.  When the sander's backing pad is completely dry and clean it will hold adhesive backed pads fine.    Flaky paint is best scraped off before sanding, use a wide putty knife or a paint scaper to remove large flakes before sanding.  This will minimize airborne dust and cleanup.    For best results with adhesives, always keep your surfaces  clean!    Good luck and happy sanding!  Michael Mittelsdorf
Posted on Jan 10, 2009
efs_perpends
  • 1996 Answers
SOURCE: DW411 Can I put a velcro
Dewalt is not going to make an accessory for you to do so, since that sander was designed to use 1/4 sheet sandpaper, and therefore takes standard paper clamped in place. You could make your own base for the sander out of thin plywood or some other suitable material, covered perhaps with a laminate or rubber surface, that would accept PSA (pressure sensitive adhesive) sandpaper, which you can buy in rolls appropriately sized for your sander. Or you can try some kind of after-market conversion kit such as this one (See also here, etc.)
If you really want a hook and loop base on your sander, I recommend you bite the bullet and simply purchase a random orbital sander with a H&L pad. Then you'll of course have to buy the perforated paper discs to go with it....
But you'll easily be able to change grits, and the performance and quality of your sanding will improve.
You might check the reviews in various woodworking magazines before you make a purchase, just so you know what you're likely to get for your money. There's a vast array of machines made, and the quality varies accordingly, and depends to some extent on your budget and intended use.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Dec 21, 2010
Why is my 5" sanding disks not sticking to my sander?
The holes are to suction dust for a vacuum attachment or dust collection bag. The sander will have a very smooth pad almost shiny if it takes stick-on discs (PSA). If not it will be a velcro pad and in that case you need the velcro discs. This description sounds like you have a velcro pad. Sticky discs wont stick to a velcro pad.
Apr 24, 2016 | Sander Tools & Hardware - Others
How do I replace the fan assembly cannot hold armature assembly to get inner bearing out without damaging armature assembly
If you are replacing the fan assembly because the internal thread that holds the rubber/velcro pad has stripped, there might be an alternative.
I had the same problem with my PEX 12AE, which I believe is a similar sander. I found that the hole is threaded a good bit deeper than the screw, so I got a longer screw and so far it's holding ok. If/when that fails, I might try repairing the thread with an insert.
Curious to know how you managed with your sander.
Feb 09, 2012 | Bosch 3107DVS Electric Sanders & Polishers
NEED NEW VELCRO DISC PAD SANDING DISC WAN`T STICK
http://www.hitachi-powertools.co.uk/locator.html
This will take you to the UK dealer locator. If you are outside the UK you will find tabs at the top of the page to direct oyu to other regional sites.
Jun 13, 2010 | Hitachi SV13YB 5" Random Orbit Finishing...
I can't get the velcro pads to stick to my Ryobi RS280VS sander
Sounds like it is time for a new backing pad. Usually the hooks get cooked and/or caked so that they don't have the "claws" to grab the fuzz on the sandpaper. If this is a well used backing pad, the hooks eventually just break off from heat and wear.
Nov 28, 2009 | Ryobi Tools & Hardware - Others
Need to convert pad to hook & loop sys. Is product made to fit this sander pad ?
Thought about what my orbital sander is like, then went to a craft store and bought a large sheet/pad of velcro and cut it to fit the 6" rubber disc pad glued it to the pad and then bought hook and loop sanding discs. And you wondering why I didn't use my orbital sander?? Because I needed to get into tight spaces and the orbital sander is a bit too large for this, plus it's too heavy to use working overhead .
Thanks for your site and for asking if problem still exists. Appreciate it.
"Necessity is the mother of invention" Truer words were never spoken
Els439
May 29, 2009 | Black & Decker Tools & Hardware - Others
Replace velcro pad on rupes random orbital sander need to know how to replace velcro pad please
I have replaced velcro on various sanders , you just take the original velcro off and make sure that the base is very very clean, use turps and metho to clean it with then buy some velcro from a good hardware supplier and really good glue [two pack epoxy is best ] and simply cut to size and then just glue new velcro onto the base of the orbital sander
Apr 11, 2009 | Tools & Hardware - Others
Changing the rubber pad on the Bosch PEX 12 AE
Feb 01, 2009 | Bosch Power Tools Sanders Orbital Sanders
Jan 07, 2009 | Bosch Power Tools Sanders Orbital Sanders
Bosch Power Tools Sanders Orbital Sanders Logo
910 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Jim Parker
Jim Parker
Awesome12
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
