Question about John Deere 3010,3020 Tractor Basic Carburetor Repair
I have a John Deere LX173 which is 12 years old. It will start fine and run for about 5 minutes when it start to backfire then stops. If I let it set for a few minutes it will usually restart and run fine until I'm done mowing. I have replaced the fuel pump and filter. I'm thinking it is a carb problem, maybe a choke problem.
  • 13 Answers
SOURCE: I have a John Deere GX345 with a Kawasaki liquid
Sounds like you may have a problem with Choke adjustment, or perhaps a broken choke cable. Do you have a workshop manual?
Posted on Oct 25, 2010
  • 86 Answers
SOURCE: John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
Posted on May 09, 2009
SOURCE: john deere 111 mower deck. Lift is in stuck in highest position
Looked up detailed isometric diagram w/ parts denoted on John Deere website. FixYa website was a litele misleading. I did not realize that accessing a question posted "for free" would cost me something to get the answer. It's kind of like askin a neighbor as a neighbor to give you a hand and then he sends a bill.
Thanks but no thanks
Posted on Jun 26, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
rwvanlue
  • 486 Answers
SOURCE: John Deere Gx75, kawasaki 9hp motor- oil in carb!
A very common problem with the GX series with Kawasaki engines. The carburetor 'inlet needle' sticks open and fills the crankcase with fuel. When checking the oil, it can be difficult to see the gasoline and the level appears to be OK. Remove the dipstick and smell the oil, you may detect a gasoline smell. Also, drain the oil, and you may find much more fluid than you expect.
The solution on newer mowers was to install an 'in-line' shut-off valve to keep the fuel from syphoning into the carburetor. The inlet needle and seat in the carburetor is NOT replaceable, so a new carburetor is the ultimate solution, but VERY expensive. Installing and using an in-line shut-off valve is more affordable.
Also, this situation is common when machine is transported on a trailer, as the bouncing causes the needle/seat to leak. When transporting, always turn off the fuel supply to the carburetor.
Posted on Nov 08, 2009
This mower backfires. Will not start unless flywheel is advanced manually. Now it dies after running a few minutes. The fuel filter has been replaced, and air filter is not unduly clogged. What gives?...
for openers i would start by having someone check the valve clearances. sounds like you are out of time, and that is a common issue with a mower over 3 years old. if the intakes are opening way to late, and not far enough, you have a problem.
Sep 09, 2011 | John Deere 22HP Hydrostatic 42" Riding...
I have a John Deere 2E leaf blower. Lately it has been hard to start but runs fine once it is up and running. Would it help to adjust the H or L screws on the carb?
The H (High Speed) and L (low Speed) should not typically need adjustment. What happens is the diaphragms get stiff and do not operate efficiently. If the unit is over 5 years old and/or the fuel is not completely drained with the unit run dry at the end of the fall, then I would suggest replacing the diaphragms within the carburetor. This along with spark plug change, air filter cleaning and a check of the muffler to insure it is not clogged is considered a basic tune-up.
Sep 27, 2010 | John Deere Garden
My lt150 lawn tractor is backfiring when the pto is engaged and cuts off in about a min of use, but it runs fine without the pto on.We have drained the gas and put in new gas, and cleaned out the...
Sounds like the float is bad - what happens is the float sits just a little off and when you add the demand of more fuel it skewers the RPM by starving the engine.
Try removing the carburator and either adjusting the float by bending the tab or replace it. As part of this repair i suggest you just replace the needle and seat as well if they are over a year old.
Thanks,
Gary @ Fix Ya
Jul 22, 2010 | John Deere Garden
Our new to us john deere 345 tractor won't keep running
You may try blowing backwards from behind the fuel filter into the gas line. Not to much air pressure though. Make sure the gas cap is off.
Mar 13, 2010 | John Deere A,b,g Tractor Carburetor Float...
Blade wont stay engaged john deere 14 sb mower is 20 years old i have not replaced the belt could this be the problem
I have a john deere 14sb lawn mower that will start and run for about one minute and die wont start again until later.
Jul 01, 2009 | Garden
John Deere 3010,3020 Tractor Basic Carburetor Repair Logo
361 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
