I just recharged my mp3 with my desktop computer and just removed the same without safely removing it from my computer. and now i cannot turn it on to play the music, however, i can see that the light in my mp3 is on.
  • 231 Answers
Dear sir,
this is not a big problem to get worried....
kindly switch off the player,if still you are not able to switch it off,plz see the bottom edge of the palyer,you ll ve a reset pin....take a small ssafety pin and just insert into that hole and press...your problem is no more and the player runs fine.....
thank you.........
Posted on Oct 05, 2010
My son's mp3 stopped playing yesterday. We plugged it into the computer. There's no response from the player and no indication from the computer. the usb ports on the computer work.
Are you plugging it infront or at the back USB port of the computer? Try turning it off first and then plug at the back usb port. Once plugged in, that would be the time you turn the MP3 player on. If the computer still does not detect the mp3 player as new usb device, then i guess the mp3 player must have been fried due to not being "safely removed" from the usb port. Make sure you are safely removing ALL usb devices when disconnecting them from the computer.
Mar 01, 2010 | Audio Players & Recorders
My little sister's Spi mp3 player won't turn on
If you are saying that you had it plugged into a computer, and the first time you used safely remove hardware, and the next time you did not.
Then the device was in the read state and is stuck, you can remove the battery, then put it back in, then turn off the computer, turn on the player
(if it is not working ) plug it into the computer with it turned on, and start the computer, after the computer has loaded windows, check to see if the devise is listed under my computer, if it is try the safely remove hardware and see if it works now.
Feb 13, 2010 | Audio Players & Recorders
Digital mp3 player is not working when we start the player it show starting only on the screen. this problem comes after whem i recharge the player
You have removed it from your computer without using the safe hardware removal mode. Effectively it has **** itself. The only cure I know is to leave it for a few days and hope it rectifies itself. I have been unable to find any other solution, including wiping it and starting again.
Dec 30, 2009 | Audio Players & Recorders
How to download pics into my sandisk
1. Connect one end of your USB cable into the USB port on your MP3 player and plug the other end into an empty USB port on your computer.
2. Double click "My Computer" on your desktop. You MP3 player should be listed as a hard drive. Right Click it and select explore.
3. Double click the "Media or pictures" folder, then drag your pictures into this folder to download them to your player.
4. Double click the "Safely Remove Hardware" button on the bottom right on your screen, then locate your player on the hardware window. Click "Stop." After the popup windows says its OK to remove your device, safely unplug your player.
5. Turn on your player and select "Pictures" on the main menu to view your downloaded photos.
Oct 28, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
How do I download Pictures to MP3?
A generic procedure is :-
  1. Turn on your computer. Plug the USB cable that came with your MP3 player into an open USB port on your computer.
  2. Step 2 Turn off your MP3 player and plug the other end of the USB cable into the USB port located on top of the player. Turn on the player.
  3. Step 3 On your computer, right-click the pictures you want and select "Copy" from the menu that appears.
  4. Step 4 Double-click the "My Computer" icon on your computer. Double-click "MP3 player " or ' MP3 Device" in the "My Computer" window.
  5. Step 5 Open the "Pictures" folder. Right-click and select "Paste" from the menu that appears.
  6. Step 6 Let the files copy. Click the "Safely Remove Device" icon located on the left side of the Start toolbar at the bottom of your screen.
  7. Step 7 Click "Safely Remove USB Storage Device." Wait for a message to appear that says it is safe to remove the device, and then unplug the USB cable from your computer and your MP3 player.
Hope i helped you.
Thanks.
Aug 30, 2009 | Audio Players & Recorders
SwiMP3 was not safely removed and now it is not recognized
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Jun 12, 2009 | Finis Swi MP3 Player
Anko directory error when plugging into my computer
Microsoft error management for error 47 says
When the "safely remove hardware" icon is in the status bar (the by time) disconnet the mp3 player. After a few seconds connect it again. Then reboot the computer system. You will then be able to see the contents of the mp3 payer.
I tried and it works. Also it means the player could be removed without clicking on"safely remove hardware".
Jun 04, 2008 | American Anko MP-2GD MP3 Player
Creative zen micro photo 8gb not turning on.
remove the usb adaptor and remove the battery from the back.
and then put the battery back in and try it
or
http://forums.afterdawn.com/thread_view.cfm/307045
Feb 22, 2008 | Creative Labs Zen MicroPhoto MP3 Player
Icon doesn't show up in my computer
Do a firmware upgrade first. If not allowed, then download the Sansa Connect Recovery Tool from:
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
"Safely remove hardware" is a normal function of Windows - it allows you to disconnect your Mp3 player without messing it up (unplugging any mp3 player while it is still "thinking" is the number one reason for mp3 player failure - always be patient with mp3 players, and try to always use the Safely Remove Hardware feature of Windows).
-Tha Mp3 Doctor
Feb 03, 2008 | SanDisk Sansa Clip MP3 Player
Wont turn on
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Dec 25, 2007 | Mach Speed Trio DA-8033 MP3 Player
22 people viewed this question
 Grubhead
Grubhead
