Question about Bosch Water Heaters
Have to keep pressing the reset button for hot water as only cold water comes on
    Problem Solver:
  • 77 Answers
Maybe set on too high a temp. 120f is about right
Posted on Oct 05, 2010
The power button wont come on to heat
Troubleshooting a Tank-Type Water Heater That Won't Start ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
Whether your water heater runs on gas or electricity, it needs a controller to cycle theheat on and off, or the water in the tank would either be stone cold or ... If the buttongoes in and stays in, the thermostat should start working again. ... Screw in a new element, reconnect the wires, refill the tank and turn the power back on.
Troubleshooting Electric Water Heaters in MINUTES ~ Step ...
? 7:01
https://www.youtube.com/watch?v=SlyStHM9Nr0
Oct 4, 2013 - Uploaded by electronicsNmore
AFTER you establish that there is power being supplied to thewater heater .... When the water is cold in the tank the top element will come on first, heating the ... is overly hot and then notice no hot water check the reset button.
Tanklets: Electric water heater problems
Jan 25, 2016 | Water Heaters
Unit stiebel Tempra 24Hot water is running through house but cold water pipe is getting hot. Hot water pipe is not getting hot. When cold water connection is removed and water is turned on hot water is...
follow this steps and fix it. God bless you
If there is no hot water, first push the reset button on the high-temperature cutoff; test the thermostat and replace if faulty (see below). Test the heating elements and replace if faulty (see below).
If there is not enough hot water, adjust the thermostat settings. As needed, reset, test and replace thermostats and heating elements if faulty.
If the water is too hot, adjust the thermostat settings and reset. Test and replace the thermostat or high-limit cutoff (see below).
An electric water heater is a 240-volt appliance that can deliver a fatal shock. Always turn off power to the heater at the electrical panel 585dc480-4881-44a8-afda-7267c0f3de26.jpgbefore beginning work, and verify that power has been shut off. Make sure others in the house know not to restore electricity prematurely. If you have any doubt as to whether electricity has been turned off, seek professional assistance.
Oct 02, 2013 | Stiebel Eltron TEMPRA 24 Tankless Water...
Have to keep resetting E2 is what keeps flashing?
Check wires coming from cold water line valve. Make sure incoming water is above freezing
Jan 16, 2011 | Bosch & Tankless LP Hot Water Heater
Hello we have Bradford hot water tank model #MI65R6DS13. Our problem, I keep having to press the tanks reset switch for us to get hot water. At the same time after I press the reset switch we have hot...
No the top thermostat is the first place I would start to replace. They run about 14.00 more than likely it isn't controling right. Turn power supply to water heater off and replace thermostat.
If you was getting scalding hot and then turning cold without tripping the thermostat it would be the top element working and the bottom one bad.
Bottom element good it will give you luke warm water for a while then gradually turn cold because it's heating the bottom of the tank.
Hope this will help you out.
Oct 09, 2010 | Fasco Bradford White Hot Water Heater...
Our Bosch tankless hot water heater keeps shutting off. We have been having to reset it more and more. And now it shows 130 on it, but the water comes out cold.
Have a Bosch Service Provider inspect the installation. You can locate one at boschhotwater.com or Protankless.com. It sounds like a very poor installation with poor combustion air and poor gas piping.
Jul 08, 2010 | Bosch & Tankless LP Hot Water Heater
Hot water wont get hot
1-First check for power to water heater and remove acces panels on heater to check power at thermostats. Thermostats have a reset button on them that trip and can be pressed to reset.
2- If none of the above have changed any thing and you have power you may have elements gone bad.
If an element is gone at top you will get scalding hot water then go to cold.
If an element on the bottom is gone you will get luke warm water then will get cold.
May 17, 2010 | Water Heaters
My water pipes froze thursday night so friday night when i went to bed i left the tubs hot water turned on and they thawed out about 2am i got up and turned the tub faucets off the water was hot at that...
you probibly ran the hot water tank out of hot water shut off the hot water comming out of your fausets for a few hours and check it again u could also try to reset your tank by pulling off the front cover and hitting the reset button and my last thought is sadly you burnt out your heating elements and they need to be replaced good luck man
Feb 28, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Water Heaters Logo
52 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
