Question about Raypak 130,000 BTU Propane Gas Pool H...
Raypak RP 2100 Model PR3335A-EN display service HL1 Also main power switch on side of unit needs replacing Electronic control will toggle from off but immediatley displays the HL 1 service code -- suggest parts to replace or service company in Houston, Tx
    Champion:
  • 305 Answers
High limit 135 error
Posted on Mar 13, 2014
4 Suggested Answers
john224
  • 1378 Answers
SOURCE: Raypak 2100 ignites then it turns off or shakes bangs HL1
Check the bypass in the header for damage. HL1 along with the banging/popping is too low of water flow through the heater and the water is getting to hot.
Posted on Sep 07, 2009
  • 246 Answers
SOURCE: Raypak 2100 starts then turns off or shake/bangs off w/error HL1
the heater is plump correctly?if yes assembly valve need replacement, if you by pass before dirt may be inside.
Posted on Sep 13, 2009
  • 139 Answers
SOURCE: Service light comes on our Raypak RP 2100 pool heater.
this usually indicates a high limit condition.you must first ascertain if you have a component failure or a true high tempature condition.your model has 2 limit controls and they are both located in side panel on water in/out header
Posted on Sep 19, 2009
ROL keep displaying on my raypak rp 2100
check gas pressure if too low it will overheat replace rollout fusible link if it happens again you might need a vent stack
Jun 23, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I have a RP 2100 Raypak Pool Heater Model number C-R185-EN installed about 1996 and used very little through out the years the front service light is on-- red --the back circuit board fault shows a sensor...
The part number for the thermistor for your heater is 005299B, officially called the temperature sensor IID it is also refered to a temp sensor or temp sensor kit.
John
Jul 09, 2011 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Have an error code GVP
You didn't indicate what model heater you have, but here are some of the fault codes you might see. Could it have been GVO? You can download a manual for your exact model at www.raypak.com
BD1 Board failure
EEP Microprocessor error
FAN Blower pressure failure
FFL Flame sensing when pilot and gas
valves are closed
GVC Gas valve closed
GVO Gas valve open
HL1 High limit switch #1 open
HL2 High limit switch #2 open
IGN Ignition failure
ILO Ignition lockout - Propane units only
PRS Water pressure switch open
ROL Heat roll-out safety switch open
SNS Sensor failure, Water temp. below 36°F
or above 110°F
VNT Vent switch open
Aug 03, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
I have a Raypak RP 2100 R405 pool heater. When I
Yes its faulty PC board.As no Power Coming from the board.Click this link directly to get PC board. http://www.a1poolparts.com/-strse-Heaters--dsh--Parts-cln-Raypak/searchpath/1015892/start/61/total/103/Categories.bok ------------------ To confirm the fault in PC board. Check for exact 24 volts on PC board. One yellow and One Blue wire. --------- For checking transformer check 120/240 volt to transformer(time clock circuit breaker wire connections). Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jul 10, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Sep 16, 2009 | Raypak Pool & Spa
Sep 06, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Raypack RP 2100 The heater doesn't turn on, is there a reset
the electronic heater has an on off switch on the side on older models on the front on newer.the power goes to a transformer this in turn is converted to low power .
Jul 05, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak 130,000 BTU    Propane Gas Pool H... Logo
231 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
