Question about Sony Ericsson G502 Cellular Phone
I WOULD LIKE TO UNLOCK MY PHONE TO TAKE ANY SIM CARD
Unlock sim slot 1 code
a sim card or phone needs a puk code or is locked BECAUSE it is not active,in order to unlock a sim card,or receive a puck code,you need to either,pay the balance owed,buy a new monthly service,open a new contract with a cell service or return the sim card or cell phone to whom it belongs to,we at fixya CANNOT GIVE YOU A NUMBER TO UNLOCK YOUR SIM CARD OR PUK CODE,there is a reason why it is locked,if it was easy to get a code,then anyone could steal your phone and use it and you couldnt stop its use for at least a month.
a phone is jail broken when you alter it to work on a different cell service provider,we at fixya do not jailbreak anything,if it isn't legal,then it doesn't belong here.
Jun 11, 2015 | Cell Phones
Not recognize sim
Did you mean your phone doesn't recognize your sim card even your sim card present on your phone?
Yes,Means,There are three possibilites to get this type of issue.
1.There may be a problem in your Sim card so try another one.
2.Check your Sim whether it's properly inserted or not
3.Your mobile is locked to particular network provider.
If your problem persists,After trying first two ways means definitely Your mobile phone is restricted by some network so try to unlock your mobile phone.You can unlock your mobile phone using network unlock code.It's the best way to unlock your phone.If you need an unlock code for your phone visit SuperUnlockCodes.com I hope it will be very useful to you.
Jul 03, 2014 | Cell Phones
How can you jailbreak a lg g800?
ow to Enter Unlock Codes on LG KB770: Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" Enter unlock code you received and press OK The phone will then reboot and the unlock is complete How to enter Unlock Codes to LG GB250 & GB220 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG GT505: Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG KP100: 1) Insert a not allowed SIM card 2) Press the unlock button 3) Enter the code OR 1. Insert allowed SIM. 2. Booting (Request PIN Code, PIN Code enable) 3. In Idle Screen, Input the hidden number (2945#*20001#) 4. Input the number (above), go back to the idle screen 5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate: 6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:". 7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code How to Enter Unlock Codes on LG KF390 and KF390q: 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Reinsert the unlock code 7) Select OK. Done! How to Enter Unlock Codes on LG Prada (e.g KE850, etc): 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG KE990 / KU990 Viewty: 1. Insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# 3. A menu will pop up, select sim unlock: 4. Another menu will appear, select Network lock. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes on LG KG245 (Vodafone Australia): 1. Insert a Vodafone Australia working SIM card. 2. Ensure the phone is charged and then switch the phone on. 3. Optional Step: If the SIM card has a PIN, enter your PIN number 4. Wait for the phone to power up then enter 2945#*7101# 5. Select Menu , then go to Settings > Security > SIM Lock > Network 6. Select Deactivate and enter the 8-digit unlocking code provide for your handset. 7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) How to Enter Unlock Codes on LG KG800 or TG800 Chocolate: 1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu. 2. Go to: Settings>Security>SimLock>Network 3. Select deactivate. Enter the unlock code How to Enter Unlock Codes on LG C2000: 1. Insert non-Cingular SIM card 2. Power on the handset - phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM Unlock code 5. Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes on LG U8150: 1. Switch ON your phone with a not allowed SIM card. 2. Compose: 277634#*#. 3. Go to menu "SIM Lock". 4. Enter the unlock code How to Enter Unlock Codes on LG INCITE CT810 Power on phone with original SIM card Type 2945#*810# In the menu that appears select Sim unlock Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG F2250 Power on phone with Orange SIM card inserted While in the Start menu type 2945#*3311# Return to the startup screen Press Menu key Select Settings > Security
Jun 06, 2014 | Samsung Galaxy S GTI9000 Smartphone
I put my sim card in the phone and it say no sim card
Did you mean your phone shown no sim card even your sim card present on your phone?
Yes means,
If your problem persists after trying the first two steps means,Your mobile phone is restricted by some network so try to unlock your mobile phone.You can unlock your mobile phone using network unlock code.It's the best way to unlock your phone.If you need an unlock code for your phone visit
OnlineGSMUnlock.com
Feb 10, 2014 | HTC Inspire 4G Smartphone
Insert sim card
Do you want to insert other network sim or if your Blackberry Curve 8350I displaying insert sim card,if already sim card inserted.Don't worry i will help you.You can insert other network sim card in the phone by unlocking the phone from current network lock.To unlock Blackberry Curve 8350I use unlock code.Visit the site Wickedunlock.com get unlock code and unlock it easily.Then insert any GSM network sim card.If the phone displays insert sim card even though sim card is already in the phone.Please remove the sim card and replace it correctly.It is because the phone didn't detect the sim correctly.After inserting if it is display invalid sim or sim not valid message on the screen.It is locked to some network,you need to unlock it.To unlock use unlock code.Get code from online site and unlock it.
Jul 30, 2013 | Blackberry Curve 8350i
Sim
Did you mean your Samsung S8000 Jet phone displaying invalid Sim card?You need to unlock it from current network lock,to use other network sim card.Visit the site Mobileunlocksolutions.com get unlock code and unlock it easily.Then use with any GSM network sim card.Check whether unlock code is available for your network and country.If it is available get it and unlock it.You can unlock only GSM network locked phone.You cannot unlock CDMA network locked phone.After unlock your phone you can use any GSM network sim card in it.You cannot use any CDMA network sim card in it.
Jun 17, 2013 | Samsung Jet S8000 Cell Phone
I bought a unlock code for my lg gt365 neon and i put a tracfone sim card in it and it says emergency calls only how do i fix it so i can use a tracfone sim card.
First you need to unlock your phone before you put tracfone sim card on that phone. Make sure you have appropriate LG neon GT365 unlock code example : if your old sim card using t-mobile you must use t-mobile unlock code for your phone not tracfone. You can get lg unlock code from online seller with lower price and quick turnaround.
Aug 28, 2011 | LG Neon GT365 Cell Phone
Invalid SIM
If your Phone says Invalid Sim while inserting the Sim Card means It locked to some Network,you need to Unlock the Phone from the Network Lock,To use any GSM network Sim card in the Phone,You need to find in which Country's Network it locked now? then what is Model,Brand ? specify those details and get The IMEI unlock code,i means Network Unlock code from here Mobileunlocksolutions and Unlock it,Using the Unlock instructions You can unlock the phone step by step also correctly without error....You can use any GSM Network Sim card in the Phone after Unlock it,You cannot use any CDMA network Sim card in the Phone after Unlock it...
Jun 27, 2011 | Computers & Internet
Sony Ericsson G502 Cellular Phone Logo
61 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
