Question about HP LaserJet 6L Printer
HP Laserjet 6L Dark Printing
I recently replaced the pickup, feed, and transfer rollers to fix a paper feed problem. That problem is fixed, but now there is a new problem: some print pages are so dark that the text is difficult if not impossible to read. The problem occurs intermittently. Some print jobs perform perfectly while others have dark horizontal streaks, and still others produce a very dark page. Any assistance would be appreciated.
George
  • George Gallimore May 29, 2008
    Thanks. But I also replaced the cartridge, so that is not the source of the problem. After installing a new cartridge, the "dark" pages just got darker.
    Sergeant:
    Champion:
  • 310 Answers
Check ur cartridge
Posted on May 29, 2008
    Brigadier General:
  • HP Master
  • 3,614 Answers
Check your Toner, and also the thermal roller of the printer..
Thank you
  • micromaster
    micromaster May 29, 2008
    could be on the thermal roller, it does not fit so that it not totally heat the ink pass through it..
My HP LaserJet P1606 does not pick up paper anymore. I grinded somekind of gears, and all of a sudden the pickup roller and associated bar does the rotate enough to pickup the paper when printing.
Open the front and remove the toner cartridge. Turn the paper feed roller by hand until it clicks and goes slack. This is the rest position. Try it again. It doesn't sound good that you said you 'grinded some gears'. You may need HP professional service or a new machine.
HP LaserJet Pro P1606dn Printer Software and Drivers
Nov 17, 2017 | HP Office Equipment & Supplies
Hp laserjet p3005dn printer taking 3 papers
Your problem description is not clear, but based on experience I bet that your printer is taking three sheets of paper at a time. The pickup roller in tray 2 and the separation pad in the tray are probably worn out. They are easy enough to replace. You can verify that printer works properly by printing from manual feed tray and if that works ok then above solution is likely your fix.
Apr 14, 2014 | HP LaserJet P3005 Printer
I have an hp p3005 with the jam code 13.01.00. It has had the feed rollers and sep pads replaced. When it runs it appears to catch on the separation pad itself since it shows a small buckle in the middle...
Replaced seperation pad?. separation pad work is to block multiple paper feeding,but in yourcase paper not at all feeding means paper pickup roller not picking up the papers.replace both 2 & 3 paper pickup rollers..
See the snap shot,view from under.
Pickup roller( red)
Un lock to remove pick up roller(blue),observe the angle of the roller & same way insert new one other wise it wont fix..
Bee care full while removing roller, paper sensor flag should not distubed(yellow)
bee pateince dont do harsh..best of luck.
Oct 11, 2011 | HP LaserJet P3005 Printer
HP Laser 6L - Printer makes a squealing noise but does not advance the paper to complete the print.
Old age printer, it needs to replace feed roller assm,pick up roller & separation pad to avoid pickup issues.must be replace these item at a time to avoid tension.
Sep 23, 2011 | HP LaserJet 6L Printer
Hi, I have a HP Laserjet 6L. I recently made the mistake of pulling a paper jam out incorrectly, I pulled the paper out from the paper feed tray rather than pulling it out from inside once the toner...
One thing pl understand this is old printer, while handling you should be carefully, parts are became delicate because of old age.check that paper pick up roller surface got smoothness or dirty, first clean with wet cloth surface of the roller & check, even its not picking up replace both pickup roller & separation pad.best of luck..Vinay.
Sep 05, 2011 | HP LaserJet 6L Printer
Have an HP LaserJet 6L. Just got through replacing all the rollers inside. Can get it to grudgingly print one sheet, then no printing after that one sheet, it often just grips the paper, but won't...
You need to make sure that you have the clutch that the solenoid interacts with seated properly. I had a tech once manage to get the clutch on at 180 degrees from correct alignment, not sure how he did it, but the printer would not print. It is possible if you are not paying attention to mount the pickup roller in the wrong position which will lead to feed problems. You need to make sure that the highest point on the roller is touching the paper when at the right time.
Aug 07, 2011 | HP LaserJet 6L Printer
Hello. During printing I often can see error message 13.01.00 - paper jam, but really nothing jammed. I have printer HP LaserJet p3005. Thanks
Your printer has a misfeeding problem.
It never fed any paper so the sensor never sensed paper and thinks that there was a jam.
Try using the manual feed tray. If that works, pull out tray 2 and clean the feed roller . Is this printer
up to date on its maintenance? The feed roller might have to be replaced.
Mar 16, 2011 | HP LaserJet P3005 Printer
Error 59.99 for HP laserjet 3550
Thank you for contacting Fixya with your printer inquiry.
nav?h_pagetype=z-001&h_lang=en&h_cc=us&h_client=z-a-r1002-1&h_product=411173
HP Color LaserJet 3500, 3550, and 3700 Series Printers - 59.99.00 Error Displayed on the Control Panel Issue
When faced with a 59.99 error, we have found additional ways to solve the issue since the service manual was written.
Error: 59.99.00 Description: An error occurred in the secondary transfer engaging mechanism. Solution
Follow the troubleshooting steps below:
  1. Fuser seated improperly. Reseat the fuser.
    NOTE: You may hear grinding sounds from the right, rear of the printer associated with this specific failure also.
  2. Faulty secondary transfer engagement sensor. Replace the secondary transfer engagement sensor. (PS16, part of paper pickup/feed assembly)
  3. Faulty secondary transfer engaging solenoid. Replace the secondary transfer engaging solenoid. (SL4, part of paper pickup/feed assembly)
  4. Faulty feed motor. Replace the feed motor. (M1)
  5. Faulty DC controller PCB. Replace the DC controller PCB.
  6. If the 59.99 error only occurred after removing and reinstalling the paper pickup/feed assembly, what may have happened is that the secondary transfer engaging solenoid SL4 may have become dislocated. See figure below. Verify position of tab on top of solenoid.
    Figure (See Link)
    h30499.www3.hp.com/hpeb/attachments/hpeb/bsc-413/.../1/343540.em
    Parts associated with this fix:
    Pickup/Feed Assm - RM1-0765-070CN).(Includes solenoid & sensor)
    DC Controller PCB (RM1-0510-000) DC Controller, CLJ 3500/3550
    Primary Transfer Roller Engaging Motor (M-5) RK2-0139
    Drum Motor (M-3) RM1-0733Drum motor - Provides power to turn cartridge drums
    Delivery Motor (M-2) RK2-0138
    Feed Motor (M-1) - RK2-0137 Located on lower left front of main right side plate assembly
    Secondary transfer engagement sensor. (PS-10) (Part of Pickup/Feed Assembly)
    Secondary transfer engaging solenoid. (SL-4) RK2-0145-000CN
    Formatter Assembly Q1319-67903
    Parts sources:
    http://lbrty.com/Products/HP/parts_hp/pnC3500.html (Very Good Parts Vender Catalog) http://www.feedroller.com/Store/clj3500.php (Parts Vender) http://www.laserprinterservices.com/hp3500/hp3500.html (Parts Vender) HP Customer: To order HP computer parts and printer parts by phone please call 1-800-227-8164 , Monday-Friday, 7:00am to 7:00pm CST.
    Thank you for using FixYa. Hope this helps helps. Please keep us updated and remember to rate this answer.
Feb 16, 2011 | HP Color Laserjet 3550 Printer
Hp laserjet 8100 8150 13.1.42
hp printers typically do not have an error message to cover every known condition, thus if the printer needs maintenance in an undefined area, it will invariably indicate a paper jam. The printer usually responds to the installation of a maintenance kit which will include transfer roller, pickup rollers, and fuser.
Oct 03, 2008 | Office Equipment & Supplies
HP 2420 Tray 2 Open or Empty
Needs feed roller replaced, you can see it when you remove cassette and look up, they wear and tray one uses a diiferent feed roller hence it still works. Cleaning the roller (rag with a little metho) sometimes helps but it should be replaced otherwise it will return.
Nov 08, 2007 | HP LaserJet 2420 Printer
HP LaserJet 6L Printer Logo
359 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
