Service kit for junkers wr 275-1 water heater
  • titines65 Apr 25, 2009
    necesito saber el esquema técnico para saber donde limpiar para desatascar por llama muy amarilla y humo negro.
    Calentador de agua JUNKERS mod WR-275-1
  • 828 Answers
Www.parts-center.it/Documents%5CRicambi%5Cjunkers.pdf
Posted on May 28, 2008
Can i get a manual on a bosch gruppe water heater
Having problem finding one. Is there a model #?
Also what are you trying to find out? as sometime googling the problem finds a solution faster than googling manual.
Nov 25, 2015 | Bosch Water Heaters
Is the junkers WR 11 Gas water heater ok for outside mounting
No all water heaters need to be mounted inside. Helps with the equipment efficiency, corrosion due to exposure to the elements, possibility of incoming water freezing. It\'s bad on electrical connections, the UV lite is hard on any plastic parts. These things are meant to be installed indoors.
Dec 04, 2014 | Water Water Heaters
Junkers wr11 has no spark and no power
Is it gas or electric? if it is gas and has a pilot, and the pilot is out. If you don't smell gas go through the start pilot proceedure. when the pilot is running it produces a small electric current sufficient to hold the main gas valve open; then the temperture sensor allows the unit to keep the water heated.
Oct 29, 2014 | Water Heaters
Junkers WR11 Water Heater Keeps Switching Off
Do NOT disconnect anything. Has the unit been maintained, cleaned and serviced? There may be a limit switch malfunctioning. Your safest bet is to have it checked out my someone who knows and is familiar with the unit you have, could be simple, but be safe and have it looked at.
May 27, 2014 | Water Heaters
Junkers water geyser pilot is on but main burner will not start
http://documents.junkers.com/download/pdf/file/7181465057.pdf Sometimes there are several parts on this model to find buit beware on some marketing technical made differences inbetween one year of build there can be some modifications inside.
Succes
May 31, 2017 | Water Heaters
How do i change from F to C on this model 1E78-144?
You need to clip or cut the jumper tagged W904 wire.
If you need clarification call WR hometechline 18002842925.
Mar 22, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Faulty Junkers water heater
first find out from your manual what the flashing red light means...that should narrow your search---could be a thermocouple shot,a rubber diphragm in the gas valve has weakened and not operated, or gas pressure into the appliance may suddenly be too low, or springs in gas valve may have worn out---very many possibilities
Mar 02, 2010 | Water Heaters
White rodgers 1F80-51 program
I called a repair man due to the fact that your email response would not accept any passwords I attempted, but kept telling me I was trying to use my old password! Your service will no longer be needed........
Thank you
Jan 31, 2010 | White Rodgers White-Rodgers 1F85RF-275...
No Heat with new White Rodgers 1f85rf-275 Thermostat
My name is Tim Burke from White-Rodgers. If you hear the "click" the thermostat is calling. It would appear that their is a wiring issue to the funace. Please contact our customer service toll free hot line and they will be happy to walk you thru it and assist you. 877-978-7828
Regards,
Tim
tim.burke@emerson.com
Tim
Oct 19, 2009 | White Rodgers White-Rodgers 1F85RF-275...
Heating & Cooling Logo
957 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
