Question about Sony KP-51WS500 51" Rear Projection Television
We have a Sony 57 " projection TV with the convergence problem you described. Can you tell where to locate the parts inside the TV and do I need anything else other then the stk 392-560. Can I use a Weller electric soldering gun or will this be too big/too much heat? Your help is much appreciated as we cannot afford a new TV and do not want to spend hundreds on this one due to it's age. Thanks
  • Sony Master
  • 5,138 Answers
Mats Electronics 1-800-628-1118
Make ure you CK pico Fuse around the STK ICs,
They are Yellow or Green and look like resistors but are Fuses 6amp 7amp 5amp,ect..
Posted on Oct 05, 2010
Describe your KP-57HW40 57 in. Rear Projection Television Problem I turn set on, screen along with image is blue, there is audio for a few seconds and then TV shuts itself off.TV bought in 2002. Can this...
Good day!!!
The problem of your TV is the color wheel..that is the one that affects the color if you had a dlp projection tv...
If your TV is crt projection the problem could be the convergence I.C (STK###)the common part #...
just replaced it with the same type,ratings and value.
Thank you and hope to solve your problem.
Sep 12, 2011 | Sony KP-51HW40 51" Rear Projection...
I have a sony kp-57ws510 and the colors are fading, the red is the worse one. What Do I need to change or fix?
Tv have a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows or 3D pictures look alike?Tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.The tv convergence board must be replacing these parts to solved the tv convergence pisture problem.You have all the tools and can do basic electronic and soldering.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a tv convergence kit that belong to ur tv model and repair it ur self.The shop will cost u like $300-350 for parts and labors.
Jan 20, 2011 | Sony KP-57WS510 57" Rear Projection HDTV
Seeing triple images of everything
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignmenents,have colors shadows or 3D pictures look alike?The tv convergence board have dead 2 STK Convergence ICS and some or all of it resistors too.These parts on the convergence board must be replaced to fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 03, 2011 | Sony KP-57WS500 57" Rear Projection...
Green and pink wavy lines on screen
Tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows or 3D pictures look alike.The tv convergence board have dead parts.The convergence board have 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Oct 27, 2010 | Sony KP-57WS500 57" Rear Projection...
My Sony kp57hw40 looks like it is in 3d after it has been on for awhile it goes back to normal
It starting to died.It will happen for good.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have pictures colors shadows or 3D picture look like.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The Shop,will cost u $300-350 for parts and labors.
Oct 20, 2010 | Sony KP-57HW40 57" Rear Projection...
The colors aren't lining up properly on my Sony rear projection tv.
Ur tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board it have dead 2 STK convergence ICS and some or all it resistors.These parts,must be replaced on the tv convergence board to solved tv picture convergence.
Oct 06, 2010 | Sony KP-57WS500 57" Rear Projection...
DOUBLE IMAGE
Tv have a problems known as a "Convergence Problems",it dead.The tv convergence board require it 2 STK convergence ICS and some or all it resistors to be replaced.These parts must be replaced,to solved the tv convergence problems.The shop should cost u $300-350 for parts and labors.
Jul 29, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
Sony rear projection tv will no longer focus. tried flash focus & manual focus
Convergence issue. The sony type 1 convergence kit from www.tvrepairworld.com should repair that issue. The kit contains the parts and CD with instructions.
Dec 31, 2009 | Sony KP-57WS500 57" Rear Projection...
Convergence does not work,why not
IT involves getting at the chips as the KP51WS510 uses two of the STK-392-560 CHIPS.
Each chip has about 18 pins that have to be unsoldered and then both chips replaced--most of the time you just need to replace both chips and adjust the set with the Sony remote--sometimes there will be another bad part around them taken out but this is not real common on these sets.
Can you solder? Are you handy if I tell you how to locate the chips and get at them?
I have repaired hundreds of sets with convergence problems.
Confirm actual model number to me and tell me if you think you can do it---if you know how to solder etc I can tell you what you will need and how to do it.
SD TECH
Oct 26, 2009 | Sony KP-51WS510 51" Rear Projection...
I have a sony projection tv and the screen is curved and blurry.
Need new convergence amp ic's and probably a few resistors.
Cost you about $30.00 for parts.
Search for keyword "convergence".
-dan
Jul 08, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
59 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
