Question about Whirlpool Duet GHW9150P Front Load Washer
It cleans poorly - Whirlpool Duet GHW9150P Front Load Washer
    Problem Solver:
  • 10 Answers
The drain pump screen requires service. If you are handy and want to give it a shot- remove the bottom cover, you will find a knob looking cover, after spinning it a few times water will leak out and filter screen will be expose- after completing filter cleaning re-install in place. Also, try using: http://www.affresh.com/#/home
Posted on Oct 05, 2010
Replaced motor, starting hard. runs fine . how do I check fuel pressure
Doubtful you have a fuel pressure problem if the car runs well, poor starting can be a few things , poor air circulation air filter needs cleaning or replacing, poor injector flow warn injectors or just dirty fuel additive sometimes clears this , poor spark plugs not firing under pressure ok when started . for diesel cars you don't say what car it is , poor glow plugs . bad fuel filter , air leaks in fuel pump , poor injectors . and especially with diesel poor compression due to worn rings or head gasket failure . You may even have just have disturbed the engine earth strap when you replaced your starter motor .
Jul 03, 2015 | Cars & Trucks
Quality of copies very poor, how do I clean them up
open the buttons cover and underneath there is a rectangle glass surface. clean it and your copies will be ok, considering that the printouts are ok. If both are poor, then the problem is the consumable. If after that still only the copies are poor then its a Scanner problem or motherboard
Feb 19, 2015 | Brother PPF-5750E 33.6K bps Super G3 Fax...
Stanton str-150 - poor sound from left deck
Just make sure all your connections are clean , your tt in horizontal and take a new record, set the azimututh/anti-skate right , use the channel of the deck which works correct if it doesn't you have to measure the voltage coming from the cable, since i don't believe it's the mixer. But pls describe a poor sound, that doesn't say a lot. My tables often make a poor crappy sound , with channels falling out, but that's due to dust on the vinyl and stylus(needle) or a poor connection with my sme connector and then i clean both. Does is crackle and move the rca cable when you're playing, often is that stuck , but if it's on both channels , which sometimes is hard to hear in a little room. It can't be the mixer, cause i told you to test it on the other, good soudinding mixer input. So then it can be your groundwire, There ain't much more. Good tonar, clean sme connector, clean record(take the needle from the right working table). Check if the pins in the sme connector move smoothly.
Goodluck
Jul 21, 2014 | Audio Players & Recorders
The top is not cleaning and the bottom is cleaning poorly
The most likely reason you are experiencing poor washing results with your dishwasher is because the filter on the pump is clogged. This tip i wrote will help ya to take apart the pump and clean that fliter, http://www1.fixya.com/support/r10292354-whirlpool_kitchenaid_kenmore_diswasher
GENE
Sep 20, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Chainsaw will only run with choke on. Carb cleaned, air filter cleaned, fresh fuel.
If engine has poor compression, there won't be enough vacuum to pull fuel into engine. Test for proper engine compression with a compression gauge. Unfortunately, problems like a scored cylinder wall can happen, which will cause poor compression, which causes poor fuel delivery.
Assuming that the carb is clean, make sure there are no vacuum leaks where the carb meets the engine. It's a good idea to get a carb rebuild kit and replace carb-to-engine gasket(s).
Note that there are often small vacuum passages in the carb that are easy to miss when cleaning/rebuilding it. Also, if someone fiddled with the mixture-adjustment screws, they may need to get readjusted.
Make sure fuel inlet screen or filter is clean, and that air-vent into fuel tank is clean. Without spilling fuel everywhere, see if it will run with fuel cap loose or off...this happens if the air vent is blocked.
Oct 21, 2010 | Garden
Poor image
Clean the beaneath the copy glass, clean the laser unit, polish the toner cylinder, and replace toner cylinder cleaning blade.
Jul 02, 2010 | Sharp AR-5316 Advanced Digital Imager...
Dishwasher no longer clean dishes as well as it use to
Hello there
There are several reasons why a dishwasher will start performing poorly and dishes are not getting cleaned here is a list of things to check
It cleans poorly If your dishwasher is cleaning poorly, check these: things that i have listed below by clicking on each one and it will give a description ok? Water-inlet valve Internal filters Drain valve Spray arms Water temperature Detergent cup
I
Apr 02, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Print quality is poor even after cleaning print
your printer catrige has been faulty.pls replace it.
Aug 16, 2009 | Office Equipment & Supplies
POOR PRINT QUALITY
perform a head clean, deep clean through inbuilt cleaning program of your printer
May 13, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Poor color
Mr.Musculo is very helpfull in cleaning head prints.
Jan 11, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
