Question about JVC KD-SX990 CD Player
Installing a new car radio
Hi how are you?
i am attempting to put a JVC KD-SX990 CD player into my 2002 ford explorer.
are the accessory wire is the same as the switch? and the constant wire is the same as the Battery wire? what is the remote(max 200mA)?
Thanks Dwayne
  • Anonymous Oct 07, 2008
    I cant hook up my radio to my 1995 gmc truck.
    how do you wire it?
    Problem Solver:
  • 7 Answers
If you have a wiring harness al the wires are color coded to match the after market radios colors. the yellow constant wire goes to 12 volt or battery wire. the accessory wire would be the red wire that is the switched 12 volts. the remote is for the factory amp or an aftermarket amp which turns on and off it would be the blue with white wire.
Posted on May 28, 2008
Where do you connect the memory wire on a jvc kd g110 car stero.....what color is the memory wire ?? what does hook red wire to acc fuse mean??? what wire does the red wire on the radio connect to on...
The yellow wire is most likely the memory wire as it needs to be connected to a constant 12 volt source.
"Hook red wire to to acc fuse" means you need to hook into the fuse block under an Accessory Fuse. (ie: something that can't be turned on unless the car is running or the key is in the "Accessory" position)
The red wire is explained above. It does not connect to the harness.
Just remember that the yellow wire needs to be hooked to a constant 12 volts and the red needs to be hooked to a circuit that is only active when the car is running or switched to the "ACC" position.
Mar 02, 2011 | JVC KD-G110 CD Player
I just purchased a JVC KD-S16 CD Player and I can't install it.
Get an adaptor wiring harness. It plugs directly into the plug in the truck. The wires are all labeled and you won't have to hack up the wiring in the truck. You can get the adaptor whereever they sell car stereos.
Apr 01, 2010 | Audio Players & Recorders
How do you hook up a jvc kd-s580 to a 91 ford explorer
Get a wiring plug kit. These are available at any Walmart. They are specific for your vehicle make and not the radio. Radio manufacturers typically use all of the same colors so this should be a matter of matching color to color straight forward. Double check this with yoru radio manufacturer schematic before applying power to the radio.
Here is the wiring diagram for your truck
Jan 20, 2010 | JVC KD-S580 CD Player
Installing a cd player in a 1992 honda accord
The harness looks like what is depicted on this link: http://cgi.ebay.com/JVC--16-PIN-WIRE-HARNESS-FOR-CD-PLAYER-BLACK-BRAND-NEW_W0QQitemZ370214069143QQcmdZViewItemQQimsxZ20090612?IMSfp=TL090612198008r8862
This connector fits the following JVC Car Radio/CD/MP3 Players with 16 pin connection.
All wires are labeled.
Hope this helps....................sodeep
Jul 26, 2009 | JVC KD-G220 CD Player
Where do you hook up the remote wire for an amp in a 1991 ford explorer
You can hook it to any accessory wire on the ignition. <Accessory wire> A wire that comes on with the vehicle and shuts off with the vehicle
Jul 08, 2009 | JVC KD-G230 CD Player
Installing a cd deck into car
BUY THE HARNESS ON WALM MART IS GOING TO BE MORE EASY IS ON THE CAR ACCESORIES DEPARTMENT
Mar 18, 2009 | JVC KD-G120 CD Player
DOESN'T WORK AFTER INSTALLING A NEW CAR BATTERY
did you check the fuse on the back of the radio. it should be a small maxi fuse that might be rated any where from 5 to 20 amps. most of the time it might be helpful to unplug the radio harness and re plug it after 1 minute.
May 27, 2008 | JVC Arsenal KD-AR3000 CD Player
Problem with jvc-avx1 car dvd player.
actually it works better if you just ground the hand brake wire. by securing a section of exposed wir with on of the main body screws.
Aug 23, 2007 | JVC KD-AVX1 Car DVD Player
JVC KD-SX990 CD Player Logo
295 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
