Question about Dell Inspiron 1501 Notebook
The fn key seems to be stuck on in order to get regular results, example f5 refresh, I have to press fn-f5, otherwise I get the below results abcdefghijklmnopqrstuvwxyz normal esc ok f1 monitor options f2 sound f3 battery meter f4 brightness lower f5 brightness raise f6 nothing f7 something to do with monitor concavity f8 monitor concavity lower f9 monitor concavity raise f10 uk f11 uk f12 uk looks like up arrow over underscore eject dvd prnt scrn uk insert uk delete normal `1234567890-= normal backspace normal home normal tab normal []\ normal page up normal caps lock NORMAL ;' normal enter normal page down normal shift NORMAL ,./ normal shift NORMAL up arrow normal end normal ctrl normal fn as mentioned above, when not pressed the function keys give the above values, when pressed the function keys give their normal values windows start windows start menu alt normal spacebar normal alt uk ctrl normal icon like a piece of paper with mouse pointer on the right right mouse button left arrow normal down arrow normal right arrow normal
  • 3,940 Answers
Boot To BIOS and ensure you reset factory Defaults.
If no change try this:
http://www.fixya.com/support/r4510515-when_try_type_ampersand_get_quotation
Posted on Oct 05, 2010
Testimonial: "thanks, I had to figure out how to boot to bios, also defaults wanted to do EVERYTHING, not just function keys, otherwise your advice worked fine"
  • paboylan Oct 05, 2010
    Boot to BIOS worked.
    I restarted my laptop, then the problem was trying to remember how to get into the bios. I had an inkling it involved a function key, but couldn't remember which one.
    I guessed F2. Of course since the problem was I couldn't get function keys to act as function keys without pressing the Fn key, while the computer was restarting I kept the Fn and F2 keys pressed. A screen flashed by that offered F12 for BIOS options, so I exited out of the screen I got via the F2 key, let windows open and restarted again, this time keeping Fn and F12 pressed.
    The resulting screen sure looked like it was the same as the one I got from pressing F2.
    At any rate I selected BIOS,
    System Behavior
    that gave me a screen with 2 radio buttons
    multimedia key first was selected
    function key first was not selected
    I toggled the radio button to 'function key first'
    Then I noticed options at the bottom
    load defaults
    apply
    Since your instruction was 'reset factory Defaults' I thought I'd try 'load defaults', but this gave me a popup 'load all system default settings'. I wasn't sure I wanted EVERY default, so I backed out and selected just 'function key first' and 'apply' which accomplished what I wanted, the function keys f1-f12 now behave as function keys, and now behave as their upper left icons only when I also press the Fn key.
    Since the first radio button is 'multimedia key first' I suspect that that was the factory default, if so in this case I didn't want the default.
  • IQUIT Oct 05, 2010
    On portable systems, almost ALWAYS the default BIOS settings are preferred. I have never encountered a I1501 that needed then changed from default, hence the advice to reset to default.
Dont believe this its just type www.myspavelayouts.com then download and you can choose what you want
Posted on Oct 06, 2010
How do I refresh my browser ?
To restart you browser:
Close it and open it again.
To completely restart your browser:
Restart your PC and open the web browser again.
To refresh a webpage:
press Fn+F5 or F5 depending on your PC and Settings.
To completely refresh a page:
press Ctrl+F5
Mar 20, 2013 | Microsoft Internet Explorer 7
On my HP 3105m I have the FN/F1-12 keys of course.
This drove me batty as well!
When booting up the HP, press the F10 key to enter the BIOS.
There, scroll to 'System Configuration'
where you will see 'Action Keys Mode'
Change this from 'Enabled' to 'Disabled'
And the "normal" function of the F1-F12 key (and your sanity) will be restored!
Aug 22, 2012 | HEWLETT-PACKARD HP 3105M E350 3202GB 116...
Hi i have the asus n53jg laptop. absolutly amazing laptop cant nock it i just have a little problem that i want to get sorted see the laptops function keys that run along the top have shortcuts on them...
The function keys that you have works alone and in combinations. You can press and hold Fn key then tap on any of those keys to get the short cuts. You can also press and hold Alt key and any of those to get another short cut. It actually depends on what you want to do.
For example:
Using single key:
F5 - it will refresh a window
F11 - try it in internet explorer to see the result
Using Combination:
Alt + F4 - it will close an open window
Fn + F3 - it will lock or disable your touchpad
I hope I understood your concern and helped. Goodluck
Jul 17, 2011 | ASUS Computers & Internet
You state to hold the fn, and hit the power button.....OK, whats the ( fn ) key ?
The Fn key is a key found usually on the keyboards of portable computers (laptops, netbooks etc) and sometimes on desktop type keyboards.
It is a key usually marked with a blue coloured "Fn" and is located somewhere on the bottom left row of keys.
The Fn key is used in combination with other keys that have (usually) blue letters or icons on them to activate the special functions (Fn) on these keys.
For example, on the laptop I'm writing this on; If I press F5 the computer would perform the action my software has normally assigned to F5. If however I press the Fn button and F5, the computers internal function for decreasing screen brightness is invoked.
Different computer makes have different assignment to their keyboard Fn so you can't generally say press Fn+F5 to decrease screen brightness, it might be assigned to something else, volume or sleep-mode or even nothing. The "blue" text or icon will give an indication of what it will do.
Hope this helps explain the Fn key ;)
Feb 01, 2011 | Dell Inspiron 6400 Notebook
Fn+f5 key not working....
no there are no drivers for that i think in Toshiba there is different option for refresh... and for F5 go to setting and then you can set the button working
Jul 28, 2009 | Toshiba Satellite 3000-S353 3005-S303, and...
Toshiba fn key problem
this is not a software problem, its a hardware. the keypad membrane of fn+f5 key stucks. need to be service. tnx
Jul 28, 2009 | Computers & Internet
My keyboards shortcuts don't link to the screen?
F5 is the default screen refresh for many laptops. If there is a volume change feature on your laptop which also uses F5, chances are it is a Feature enabled key. To make the volume work, look on your laptop for a key most with blue letters that is printed with the letters "Fn"
Hold down this key while pressing the F5 key. This should adjust the volume correctly. Did it work. Please post your feedback and let me know.
Thanks!
Jun 10, 2009 | Computers & Internet
Dell Inspiron 1501 Notebook Logo
613 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
